Alan Ambrose
Everything posted by Alan Ambrose
That's a curious ask. If it helps any, my PP has these conditions invented by the LPA: 15. The home hereby permitted shall be delivered as custom and self-build homes in accordance with section 1 of the Self-build and Custom Housebuilding Act 2015 (as amended). Reason: To secure the use of the land for custom and selfbuild housing only. Biodiversity Net Gain The effect of paragraph 13 of Schedule 7A to the Town and Country Planning Act 1990 is that planning permission granted for development of land in England is deemed to have been granted subject to the condition (biodiversity gain condition) that development may not begin until a Biodiversity Gain Plan has been submitted to and approved by the planning authority, unless a statutory exemption or transitional arrangement applies (under paragraph 17 of Schedule 7A of the Town and Country Planning Act 1990 and the Biodiversity Gain Requirements (Exemptions) Regulations 2024). Based on the information available this permission is considered to be one which will not require the approval of a biodiversity gain plan before development is begun because one or more of the statutory exemptions or transitional arrangements is considered to apply.
Thanks, that’s it. I imagine the Ravatherm is totally wrapped in dpm?
>>> Which door did you have in mind? The front door is good - just interested in the relationship between the slab, the supporting insulation and the brick plinth. Probably obvious, but I don’t remember how the plinth works with the door opening.
I’ve used Target in Ipswich for some small stuff and they were v helpful. They stayed open a few minutes late one day so I could pick something up (a cat scanner I think) - which was beyond the call of duty. You probably want the smallest 6m one. Easy enough to drive if you’re careful, but not great visibility, so you need a spotter. Picking pallets off a truck is a bit tricky as you need a coordinated 2D motion to keep the forks level. Probably easy if you’re a video game player. Tru7 is probably the most aggressive price-wise but a bit bolshy with non-trade customers. Worth a visit as they’re close to you and amazing to see their yard - millions in kit there - e.g. maybe a couple of dozen diggers of different sizes. Think Tru7 will supply drivers too if you need. You might have a local company that has older kit and is cheaper. I’ve used Toddys in Martlesham a few times and is a bit like that. p.s. figure the max weight and reach you need to select which model.
Actually, I think that £6.7K for 3P isn't bad, I would have leapt at that. Can you do some or all of the digging yourself (contestable work) - by which I mean get a one-man-band to dig it more cheaply? Re gensets, I recently bougt a Hyundai one which does 3P ~6kW for £1.6K new. Any size bigger than that starts getting a lot more expensive - then you're maybe looking at 2nd hand industrial sets which are physically quite big. They're all properly noisly even the 'whisper quiet' ones. By your calcs, you're looking at 13kW for the workshop. Unless you have big CNC, you won't substantially be using more than one machine at once. Also, the laws of entropy say that your power use all ends up as heat, so that makes 13kW for more than a few minutes unlikely. Also, 13kW is 17HP - that's a lot of big-arse workshop machinery - a bridgeport is still only 1.5-2HP. I think if you look at the average demand carefully, you may find some scheduling / battery time shift will make it all work. Failing that, suggest investigate 'contestable work' and ante up the funds - that's by far the easiest solution. If you have time on your side, you may be able to negotiate the amount - there are some good examples here on 't 'ub of people doing just that.
@NCXo82ike - if it’s any consolation, I’m finding UKPN laughable. I kicked off our install in January. It’s the simplest install of 5m cable from the verge outside our plot to our kiosk, just inside the plot. We’re on a single track quiet lane. Single phase only. We dug the trench and installed their special duct months ago. It should get installed in early August - that is 8 months later. They’re planning to close the road for 2 days for what will be a couple of hours work max. My most recent conversation: Me: I can’t think it will take two days - the whole route is already dug and ducted all the way to your mains cable and has been ready for months. Your guy on the ground has seen it several times, you really won’t need to start with an excavation team for 1/2 a day. UKPN: is the excavation already open? I advise you to fill it back in so my team can excavate it again on the day. Me: OK. (Thinking, I’ve inadvertently fallen into a major role in a play written by Kafka with help from Beckett, Checkov and Orwell.)
Yeah many thanks Paul, that was both interesting and fun to see everyone again. @LSB - you guys were missed. @zzPaulzz poss to get a photo of your plinth / ravatherm / door threshold detail - we need something like that.
I’ll be there @G and J can give you a lift if you want.
Rear extension and nasty neighbours!
Alan Ambrose replied to Millymu's topic in House Extensions & Conservatories
That’s tough stuff. Building work seems to bring out the worst in some neighbours. Stay as calm and polite as you can, stick to the facts and process and you’ll win in the end. -
dimensions on planning as opposed to reality?
Alan Ambrose replied to mjc55's topic in Planning Permission
This has been discussed a few times on ‘t ‘ub already. If I remember rightly, the subtle difference between footprint and overall dimensions might help. Also, by convention, the planning drawings are an approximation e.g. they don’t include drainpipes, TV antennas etc and so some interpolation is allowed and expected. Also, a lot of drawings say ‘you shouldn’t take dimensions off the drawing’ or some such which gives you a little more scope. As always, planning enforcement is just your lovely neighbours. You could always put in a non-material amendment if you want to be squeaky clean. -
Sweet spot when buying a digger
Alan Ambrose replied to Post and beam's topic in General Self Build & DIY Discussion
There’s also quite a lot of skill required to use one well. Another vote for hire and see how you get on. Unlike a lot of hire rates, the rates for excavators seem pretty reasonable to me. -
The hive mind on ‘t ‘ub regards SAP as currently necessary but useless and counter-productive. Will Ecology accept the PHPP result instead? I second your thoughts re typical contractors / consultants. There are some v good ones, but for run-of-the-mill ones, I figure I can usually equal them the first time out and then do a better job the second time. Sure, there are some skilled trades e.g. plastering, cabinet making etc where I figure I don’t. Also, you know what you want - so you avoid the communication problems and having to argue them back from their standard ways of working. Sometimes the latter takes months. Also, I’m quite pernickety so I’ll make the extra effort to get it right whereas it’s not the contractor’s house so they usually don’t. The problem then is that there’s a tendency to do everything, so I’m trying to be more conscious of supervising the bits more closely that I care about.
Yeah, second the safety concern - I think that’s a much too lightweight construction. I’m sure proper SEs will be along shortly… Maybe you can use some off-the-shelf cages and ask the manufacturers if they have any ready-made designs for the height you need? You may also need a proper base to stop the whole thing swivelling over on the corners. I see in the example Gone West gives a link to, that the posts are in 0.6-0.7m or 35-60% of the height of the fence. Seems to me that that’s a bit of a generalisation given you could be building on rock or sand.
Cable for 24v Electric Gate motors and sensors
Alan Ambrose replied to Shropshire_Lad's topic in Power Circuits
Is the minimum spec of the cable not in the instructions? (Tried calling the distributors?) Suggest current rating of cable should be twice the demand, just as a safety factor. And yes, regarding signal and power in the same cable, you can largely please yourself with ‘extra low voltage’ - although you should be professional enough to ensure the cable doesn’t overheat by having enough capacity. -
I vote for Paul’s place - probably much more interesting at the moment.
An IP17 meet, or is that too far east for everyone? I have a concrete slab and tea making facilities to show off. Attractive, no? Anyone else have another offer?
Another way of looking at the situation in the South is that the landowners take 100% - 120% of the economic gain out of the PP uplift. Because of the v low supply, the landowners price for the people with more money than sense - making any build marginally economic at best, a money loser in most cases.
>>> you have not read enough Buildhub Maybe there should be required reading of specific threads followed by a test to ensure the information has been fully understood and retained. A key part of that knowledge would be the difference between KWH, kw, kW and Kw 😄. Also thermal mass being measured in kg.degree K.
Those all sound very reasonable given the kit and skill involved.
@zzPaulzz - sorry I forgot to answer your question. I use a co called Alco Eng https://alcoengineering.co.uk for laser and bending sheet, usually stainless. And purpose powder coating https://www.purposepowdercoatings.com . But that’s largely out of habit and knowing they’ll deal with small (rather than industrial) quantities. I generally supply a design in pdf and dxf allowing for the bending characteristics, but I think Alco will do that bit too for a fee. I’m sure there are loads of other good companies too.
That graph is for the US?
>>> Seems a shame there isn't a way to run wet underfloor heating in a way that would cool the floors ? There’s lots of info here on ‘t ‘ub on running heat pumps in cooling mode. Some do it out of the box, some can be configured, some can’t.
