Adsibob
    10
Everything posted by Adsibob
  1. Got back from a period away from the house today, and apart from discovering Santa stuck in my chimney breast, I noticed that a light fixture we have in our bathroom was flickering. The kids have knocked this fixture a bit, but it’s pretty sturdy, made by Astro, and I didn’t expect a couple of gentle knocks to have damaged it, but I guess it’s possible. Other possibility is that the G9 LED bulb has developed a fault. But it’s been working fine since May, and although it gets used at least twice a day I expected more longevity than this. I suppose no other solution other than to test it with a new bulb?
  2. Or you could level with a self levelling compound. Much thinner than screed.
  3. When you say “wood floor” what exactly do you mean? Engineered wooden flooring? Solid wooden flooring? Laminate? Typically, you would have a solid flat layer under the finished flooring. Laying directly onto joists is not a good idea.
  4. Hopefully somebody can help me as we have something stuck in our chimney breast and I can’t light the fireplace until we remove it. Not helping the Christmas spirit not having a fire. It’s big, red with a white border, although there are two dangly bits that look covered in what appear to be red and white stripey stockings. Leather bits at the end of the dangly bits.
  5. Here’s to more inflation, strikes and prime ministers. All the best, Scrooge
  6. Is this a good deal: 64 x 22L nets of kiln dried “superior”, whatever that means, ash and oak for £485 Inc vat and delivery. https://www.londonfirewood.co/kiln-dried-logs/64-nets-kiln-dried-logs/ difficult to compare like for like as there does not appear to be a standardised way to quantify kiln dried wood. Some sellers describe the nets by their weight, others by their maximum volume. Volume is only a guide as some of the volume is taken up by air.
  7. Not much impact from the extractor on and the window cracked open. But my measurements are not that accurate because my kitchen thermostat (which tracks the data) is actually not in a great location. Much closer to the oven than to the cracked open window. I should probably use a separate thermometer to take measurements nearer the window. I think that as long as you only use the extractor once or twice a day and only for 30 minutes at a time, the impact is largely going to be minimal and partly offset by the heat generated from cooking. But the purist in me wishes we had gone for a Bora hob with integrated recirculating extraction, as this would send the extract to grills by the floor, where they would not be as noticeable as our original recirculating configuration, which is what caused us to change to non-re-circulating.
  8. Following with interest, in case it helps me with this:
  9. Well they complied with this, but I still lost it! Why doesn’t the legislation say something like “No person shall install any installation pipe work in a wall, without photographic records showing the exact position of the pipe in the wall”.
  10. Thanks. There is one socket on the wall, but it is nowhere near the pipe. The plasterboard is mostly unplastered so pretty easy to cut into it to explore, problem is that i think the pipe is behind the Tyvek foil and I don’t want to compromise that. I guess the thermal imaging camera could work, but would prefer a metal detection solution.
  11. Wall has been bordered up and partially plastered. Lost the photo showing location of copper gas pipe. Need to know fairly precise location as wall is to be covered with wall mounted cabinets. I know roughly where the pipe comes into the house from the outside. I also recall it then travels upwards in a vertical line, before making a right angle and travelling horizontally across the wall. But I don’t know the point on the wall where that right angle is. The relevant wall construction is i think the copper pipe is in the ventilated cavity, rather than in the service void. So from the inside of the house, it is behind the aluminium. Potentially complicating matters, we used metal (I presume steel) studwork, directly behind the 12.5mm plasterboard, so a metal detector might not be able to distinguish between the studs and the vertical pipe. I say “potentially” because I’m hoping there are metal detectors which can detect non-ferrous metals such as copper, whilst ignoring ferrous ones such as steel. Are there such metal detectors? Any other tricks of the trade to locate a hidden pipe?
  12. So do we. Laid as herringbone in two rooms and planks in three rooms and a hallway. Manufacturer and supplier insisted we couldn't exceed 27C. We have, by at least 6C and no disasters yet. But I agree with you that if you are seeing stuff in your flow meters, you need to get that fixed first.
  13. How about putting your hot water tank under the stairs, going for one that doesn’t have the highest insulation level and accepting you will lose some heat from it.
  14. I think he's being unreasonable. By way of comparison, i haven't heard from my contractor in a couple of months. Over the weekend, out of the blue, he calls me up and says: "are you in, I need to come over and show you how to drain your external taps". So he did. The cynic in me thought "lucky I happened to be in, he really left it to the last minute", but on balance it shows he thinks ahead (just not a lot ahead)!
  15. This is a good point. My own view is that manufacturers err on the side of caution and so a manufacturer's recommendation that the floor be limited to 27C is just an ideal case scenario. 29.5C or even 31C should be fine. I would start by making sure there are no draughts in that room and seeing if there are any other ways to boost the insulation of the walls, ceilings etc. Then, if still no improvement, try increasing the limit to 29C and seeing if that makes a difference. If not, increase to 30C. Keep increasing until about 32C. After 32C I think the risk of floor failure become more realistic.
  16. Wow @Moonshine, I really feel for you. I think you should get your plumber to fix it for free. He’s really (expletive deleted)ed up here.
  17. Look at aerogel. Your architect is mistaken if he/she thinks it only works in a NASA lab.
  18. The heating for that room was off at the time I took that photo. I agree that to approach something scientific, I should only make one adjustment at a time. But I'm just interested to understand what is the difference between the pump speed and the flow. How would you describe their different roles in the UFH system?
  19. Are you sure you don’t have air in the pipes?
  20. Ah, ok, that makes sense. Well I guess that if you are feeling warmth underneath the ufh system, then the insulation is likely insufficient. Could you temporarily affix some PIR to an area of the floor/ceiling void and see if it makes any difference, before doing the whole thing?
  21. If you insulated that door, I think all that will happen is that stairwell will be a degree or two colder than the rest of the house. If everything else is well insulated, then overall you will be okay. If you are really worried, see if another manufacturer makes an 8kw heat pump. If the window in that stairwell is 2G, could you upgrade it to 3G?
  22. The floor plans suggest you are in France or Canada. If the former, I wouldn’t worry about it too much. You are unlikely to have long hard winters, and this is a corner of your house that doesn’t appear to contain any living space, just staircase. If you are in Canada, that’s a different story, but even then not terrible.
  23. I don’t see what the problem is. Why would you want a bedroom warmer than this?
  24. I think @Dean Mc is more concerned about how to conceal the ducts given he has few void spaces.
