Adsibob
    10
Everything posted by Adsibob
  1. Just to clarify, the system I was posting about is not the ESYBOX Mini 3. It's this thing, which comes with its own 500L tank: https://www.anglianpumping.com/product/mains-pressure-boosting-systems/dab-e-sybox-c-w-e-sytank?gclid=Cj0KCQjw1ouKBhC5ARIsAHXNMI93Qsi2b1wAbDB6E16CY3mmkYWoD3BRsFDhgUbhNJKbrRGgr06Om8EaAkg_EALw_wcB
  2. Whether the contract was oral or in writing is probably only relevant if you are going to sue them. You're not. I say "probably" because it does give you a bit of moral high ground, although if the builder is a shameless f*cker then that won't really count for anything. Personally, I think that the most important thing in my view is being able to trust them. You clearly can't trust these guys. What's to say they don't renegotiate again in a few months time. I appreciate labour is short right now and particularly if you are building with specialised materials, but if I was in your shoes I would prefer to go with someone else, even if it meant having a down time of two to three months whilst I found a replacement. Whilst switching builders midway through is always a bit of a nightmare, with enough attention to detail it can be done. The incoming builder has to inspect everything that the outgoing builder has done before you agree a price so that he knows exactly what is unfinished/done incorrectly and what he needs to finish/remedy it. This happened to me in Christmas 2013. The day before Christmas eve I get a text from the foreman telling me he and his labourers have not been paid by the company I was paying for three months and that if he carries on like this he will default on his mortgage. They went bust and i had to find a new builder. We lost 10 weeks (during which time I got quite depressed, watching the big gaping whole at the back of my property, loosely covered with a tarp) but we ended with a really good result because by that point I was wiser and was able to be much more detailed about the contract I agreed with the second builder. I also lucked out to an extent because the second builder was a top quality guy. It was worth waiting for him to sort out the mess the first guy had left.
  3. Maybe I didn't express myself very well. The point I was trying to make is that if your maximum pressure is X, storing it in an accumulator won't increase that. All it will do is make sure you don't fall below X whilst there is still water in the accumulator tank, in theory at least. But in practice, that sounds dodgy to me. Once water is released from the accumulator tank, won't Boyle's law dictate that the pressure will fall as essentially the extra space created by the release of water will result in extra volume for the remaining water. Now of course one needs to take into account that the space can be refilled by the mains water as it is being used. But without a pump, that will only be coming into the accumulator tank at mains pressure. So if mains pressure is 3.5 bar in the middle of the night, but 2 bar during the peak usage times in the day, then whilst the accumulator can accumulate pressure at 3.5 bar in the middle of the night, if usage in the house is a couple of showers at 7am (time of peak demand in my street) then whilst those showers are running and the accumulator is emptying, it will only be refilling at 2bar, not 3.5 bar. So overall, won't the pressure of the accumulator tank fall to a weighted average of the pressure in the tank before the showers and the mains pressure at the time the tank is refilled (weighted by reference to the proportion of the tank that is being refilled). I'm probably missing a lot of important details, but that's my take on it as layman who thinks he understands how Boyle's law works.
  4. No PV, just a gas boiler system. Not sure how a Hot return circuit pump would fix the issue. Does it just mix the water in the tank so that it is all hot when heated?
  5. Or is it just a case of adding a pump to the cylinder to mix the water and accept that there won't be any stratification.
  6. I'm sure this has been covered before, but after various searches I couldn't find a post on it, other than the odd comment from @Nickfromwales about how horizontal cylinders are okay. I was about to order a horizontal UVC from Cylinders2Go. Spoke to Trevor who was very nice and he asked me why I wasn't getting a vertical one. I explained my space issues and he said if I can squeeze in a vertical one somehow I will have a more efficient system. Now that is a truism, I'm sure. But my question is how much more efficient will the system be? Say with a 400L tank, both the horizontal and vertical one made by Telford is the same dimension and so has the same heat loss of 2.58kW per 24. I get that hot water is lighter than cold and so rises, giving better stratification, but how much is this going to make a difference in practice? I'm sure it means the boiler needs to run more, but how much more? Other option I'm considering is a vertical 380L which is taller and slimmer than the 400L. It would be a real compromise to our house if we have it vertical, but I'm concerned about getting massive gas bills! (Changing to a different energy source isn't an option unfortunately.)
  7. Okay, that definitely is a selling point of an accumulator. But what still confuses me is whether the DAB E.Sytank (details here), which is a 480L tank together with a clever pump is an accumulator plus a pump or is it not an accumulator at all? Because whilst an accumulator will give you really good mains static water pressure of about 3 to 4 bar all day (or at least until you use up the water in the accumulator) as far as I can tell, an accumulator will do absolutely zero for your dynamic water pressure if you are already dealing with a very low flow in the property. That's why I was looking at pumped systems. The DAB E.Sytank has a tank that appears to boost flow rates by 12 L/min, though I'm not entirely sure. It incorporates a pressure and flow sensor and an inverter. My understanding is that the pump inverter maintains a constant and stable pressure in the system by varying the speed of the pump motor to deliver the same pre-set pressure at the outlet regardless of how many outlets or appliances are in use, up to the maximum capability of the pump. So isn't something like the DAB E.Sytank going to be more effective than an accumulator of the same size tank?
  8. When can I buy these?
  9. But surely the accumulator can only accumulate the pressure one has coming in from the mains supply?
  10. Can any kitchen tap be adapted to do this, or do I need to buy a new tap?
  11. Ah, I see. Thanks @PeterW. So presumably to do that one would need to drain the cylinder. How often would a cylinder's heating element need a service/inspecting? I am currently torn between two cylinders: Telford Tempest 400L like this: https://www.cylinders2go.co.uk/shop/stainless-steel-unvented-cylinders/unvented-horizontal-cylinders/telford-400-litre-horizontal-indirect-unvented-cylinder/ Telford Tempest 380L like this: https://www.cylinders2go.co.uk/shop/stainless-steel-unvented-cylinders/unvented-horizontal-cylinders/telford-380-litre-horizontal-indirect-unvented-cylinder/ The 380L is longer and less tall when mounted. It will probably fit more easily in my restricted head height area and might mean that rotating it isn't required when servicing the element. I really don't need the extra 20L afforded by the 400L tank, but I wonder whether the fact that's it's ratio of surface area to volume is greater than the 400L one will mean that it will have greater heat loss. Can't see the heat loss specs for either the 380L or the 400L tanks on Telford's website: https://www.telford-group.com/uploads/shop/Storage Tank Fiche 2021.pdf
  12. I need to fit an unvented indirect HW cylinder in a restricted height area. Even with a horizontal one, I'm not sure I will have enough clearance to be able to remove the electrical heating element which I assume is removable because it needs to be serviced/replaced every so often. I emailed Telford technical support (I'm looking at their Tempest range) and they said: "The immersion heater is 14” in length so you will need around 14” to remove it. The immersion heater can be moved to help this though". I don't understand the second sentence. Aren't these huge tanks (i'm looking at a 300L or 400L one) very heavy to move? Or do they mean once empty? I called Cylinders2go and asked if they could make a bespoke one which had the heating element at the end rather than on top. They said "not really" but suggested I pay an additional £80 or so to upgrade the heating element to titanium as apparently if I did that it would never need servicing, hence eliminating the problem. Has anybody got experience of servicing unvented indirect tanks? How often does the heating element need to be removed and is it possible to move the cylinder to assist with this, or is that just madness. Thoughts on the titanium upgrade? I should clarify that I will have a salt-based water softener system, so shouldn't really get any limescale.
  13. I'm now having to research this as we finally did a dynamic pressure test and my pressure drops from 2.8 bar to about 1.2 bar as soon as second tap is turned on. Plumber brought a little cup with him to measure flow rate and reckons it's only 11L/min which I found odd because I did an old fashioned test (using a 6L bucket) before we did our building works and got around 17L/min. I'm also considering DAB systems, but my plumber has recommended one that comes with a 480 litre tank, called DAB E.Sytank. It's actually quite compact for a tank that size, because it's cuboidal rather than cylindrical and housed within some soundproofing casing, so the advertised dB is only 45dB. Expensive, but almost £2k less than boost a main. My builder is concerned that we don't have the structural strength in the floor to support something so heavy given that the unvented HW cylinder is going nearby and it is about 400kg. I need to double check, but I think the posis which support the HW cylinder are not the same posis that would support this E.Sytank. If I'm right about that, then he must be worried about the wooden beam that is attached to the wall from which the posis are hung, but that just seems odd. Now need to speak to structural engineer to see if he can find a solution, as not sure I have space for it elsewhere.
  14. Fair enough. It does make your house more appealing to a wider market, I agree.
  15. My plumber wants to use a combination of copper and plastic pipes. He says he prefers copper for the ends of runs where he connects to a cylinder, taps, shower etc., but that he prefers to use plastic for the long runs. I asked if he would be using hep20 (because I had heard good reviews of it on this forum) and he said he prefers to use Buteline. He says it's much stronger and has no rubber parts. Googling around I found this https://community.screwfix.com/threads/well-done-wavin.186552/ which reviews the Buteline system highly (see second post and video contained therein). The test in the video is a bit irrelevant as we are struggling to get above 3 bar let alone 30! Any experience on this forum of using buteline? If I go with buteline, which pipe diameters do I want to use for HW secondary loop? (22mm?) HW run from secondary loop to showers? (16mm?) HW run from secondary loop to basins (10mm?) Cold water run to basins (10mm?) cold water run to shiowers (16mm?) I was surprised that the plumber recommended "15mm" for basins, because I thought the advice here was always to use 10mm to reduce build up of cold water in dead legs. From the info below (taken from Buteline's website), the 10mm seems to have a tiny ID and even smaller ID of fittings, so maybe that's why he prefers 16mm (not "15mm" which doesn't seem to exist). But he also said that all taps these days have narrower hoses so it doesn't matter if we use 10mm or 15mm, but I think he's not thinking about dead legs.
  16. I always find this kind of assumption very defeatist, pessimistic and generally avoidable. Unless you are already severely challenged in mobility terms, there is no reason why one cannot take care of one's physical health so that one doesn't grow frail. Old yes, but not necessarily frail. There are things one can do to stay mobile. Walking up and down stairs is one of the most important. Use it or lose it. A simple series of exercises to keep the leg joints working doesn't take longer than 10 minutes a day. If you have a joint issue, invest money on a good physiotherapist who can rehab you and then get you onto a good gym programme that will get you fit. I have several back and joint issues and a nervous system issue that requires some pretty strong anti convulsive medication. If i don't do my exercises I spasm in pain, but if I do i get by okay and have no reason to believe I won't be able to climb up and down stairs until the day I die. See this for info, particularly the bit about exercise: https://www.england.nhs.uk/ourwork/clinical-policy/older-people/frailty/preventing-frailty/
  17. I've never seen a concrete lintel that big. Is it going to be reinforced with metal bars? How does it compare to your structural engineer's design? You have got a structural engineer right?
  18. They're very nice. Really happy with the frames. Some of the glazing units had to be replaced though due to some issues. Mostly boarded up now, but once we unboard I'll post some pics.
  19. We have posi joists under the first and second floor, so this will help. The internal walls are all studs, so that too will provide a void for services. As for the channels within the external wall, I'm not sure! I need to double check, but I'm hoping the builder and/or architect has thought about this!
  20. Thank for reminding me about this. It is a spec that the surveyor recommended, just the architect forgot to include it on his drawings.
  21. https://www.dupont.co.uk/products/tyvek-supro.html it is vapour permeable, breathable and water resistant No idea I'm afraid. My architect designed it, I then asked him to run it by a RICS surveyor who designs these sorts of things and he made some tweaks and this is the end product. Couldn't tell you which way is the right or the wrong way to do these things. Why do you think having the membrane floating between the batten and counter batten is wrong? Yeah, that's a good idea. The only downside is that if I don't end up needing to install radiators, we'll end up with pipes sticking out the floor. Because of aesthetic and cost reasons. We are having crittall style windows made by MetTherm. We really liked their slim frames, look very much like the original steel frames, but made from aluminium and much better insulated than the steel ones because they are thermally broken whereas steel are not. They don't do 3D so if we had insisted on that, we would have had to go with something very bespoke to achieve the same look. We have fairly large windows on the rear elevation, so we will get some heat loss vs 3D, but that will be partially mitigated by the solar gain, as most of the windows get good amount of sunshine. It's not a passive house, just a refurb of a very poorly maintained 1930s house.
  22. Didn't realise there was a difference. Good to know. So can you recommend a quiet sump pump?
  23. Hi @Oldsteel after the survey, how long did it take to get the work done to actually connect it?
  24. Rainwater.
  25. So would you recommend Wilo for other pumps which should be quiet as well? I need one to pump water from a soakaway to a sewer on an ad hoc basis, and I need another one to pump my secondary loop for a minute or so every 20 minutes
