S2D2
S2D2's Achievements
Regular Member (4/5)
151
Fitted quickstep here, really easy DIY job. As everyone has said, follow the expansion gap instructions to the letter. I undercut the skirting to keep an expansion gap and clean lines. I didn't want to undercut a tall kitchen panel and cut the plank with a 2mm gap to look good, inevitably that's the one point that made contact in the latest heatwave and that gap needs increasing.
+1 for not ivy, there are plenty of less problematic alternatives. I'm still trying to remove one the previous owner planted and it's relentless.
My waste came with blue rubber blanks that have been useful for this. Or a washer cap from toolstation gives change from £2.
Plug in solar is here (well in a couple of weeks)
S2D2 replied to JohnMo's topic in Photovoltaics (PV)
Source: https://www.gov.uk/government/consultations/plug-in-solar It is currently blocked by G98, but their intent seems clear. -
Also worth noting is that they're allowing one per socket circuit, so most houses can easily have 1600W of generation for under £1k (once they update g98). Really positive news. -
Forgot to follow up on this, I swapped to: https://www.screwfix.com/p/hep2o-hx19-15ws-angled-service-valve-15mm/8634f Which has no leak. The tap connector when tightened was causing the cistern connection move and leak. Wouldn't have been an issue if I could get more tools in to hold it but this was all through a 10x20cm access hole so a right pain. I suspect the cistern leak is what caused issues with the flexi so the other two that I had planned to replace can stay put as an inspection camera showed no leak or corrosion.
Have to say, I'm having the same issue as @crispy_wafer, doesn't seem to be a way to stop it leaking attaching to a plastic cistern feed with the flat washer as per a flexi pipe. Takes a brass stop end with the tapered washer with zero issues, but flat washer and cistern, nope. Starting to suspect I might have loosened something in the cistern messing about with it but that'll be a full disassemble of the unit to confirm.
Immediate failure or at a later date? Thanks both, parts ordered.
Having just discovered a leaking flexi pipe on a toilet cistern, what is the general consensus on best practice here? Replace and set a 10 year reminder or fit something like https://www.screwfix.com/p/hep2o-plastic-push-fit-angled-tap-connector-15mm-x-1-2-/3036f to the cistern and go straight into plastic pipe, even if that involves a couple of elbows? This is all inside a vanity cabinet so not something that can regularly be inspected, it needs silicone cutting back from the toilet to even see.
Is export actually shown on the statement? Import/export can occasionally come through as two different statements for me. I presume you have a smart meter?
Interesting for windowless rooms and I suppose may warrant avoiding specialist solar films on windows? No data on working near a window but I'm guessing that provides way more exposure than a single lamp? Warm leds sit in the same frequency range as cool just with a different distribution so I'd be surprised if that made any difference, but again no data.
Others have covered this, but just to be clear: 9kW heat output / CoP of 3 = 3kW electric import 3kW * 24 hours = 72kWh per day 72kWh * price cap unit rate of somewhere below 30p = £21.60/day £21.60 * 31 days in the month = £669.60 6696kWh of heat per month. The heat pump can keep your house above "seeing your breath" temperature. The real issue is, you don't want to spend £700 a month on heating, which is absolutely fair enough. But it also has absolutely nothing to do with whether the heat pump can heat your property. Now let's back out what you're actually putting in. £70 monthly might equate to around £60 a month on heating in the winter. Don't focus on that number, it's an estimate and we're just concerned with order of magnitude at this stage. £60 per month / £0.30/kWh = 200kWh electricity import 200kWh * CoP of 3 = 600kWh of heat per month About 9% of the rated heat pump output. Of course the house is going to be cold. For reference, I have a moderately insulated house and in the last 30 days it required 2508kWh of heat to hold its temperature. You've input 24% of that into your uninsulated property. Only you can decide how much you value warmth. You have a very wide range to play with for the coldest month of the year, £60 to £600.
Your monthly bill would have to be circa £700 to test this theory. It would be useful to know what your next bill actually is. I'm glad your noise issues are sorted and you've found some balance in the heated hut. If you think selling the house would improve matters then that seems very pragmatic. Do not dig out the floor and install ufh. It's a complete waste of money in your situation. All credit to @-rick- for thoughtful suggestions, unfortunately you're not going to get the answers you need to progress the train of thought, it's just not what zoot is looking for from this forum.
I can't speak for other companies but most Octopus smart tariffs are on the same standing charges as the standard variable tariff. Obviously if you're on a fix the new standing charges will come as a shock, but you'll probably find that either way at renewal. You can also be on a smart electricity tariff and whichever gas tariff you want, e.g. tracker. I factor in 15% round trip losses, which do make a difference, I stopped using Flux because of this. But Cosy/Go still have a large worthwhile saving. The degradation point is an interesting observation, I wonder how the value per unit degradation calculations would come out?
Existing one year fixed tariffs will continue at 15p but they've been renewing onto variable for months now, which is the one that changes in March.
