Everything posted by JohnMo
Good one
ASHP in cooling mode, warned off the idea
JohnMo replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
Forgot to add, I work on the principle that I try to keep the house cooler than outside as long as I can. Once it cooler outside than inside, cooling is switched off and doors, windows opened. -
All depends on how you cool. Due point is really only an issue when cold hits the atmosphere. I use it in UFH, I flow down to 12 degs, which is at or just below dew point. But I don't run all the time. I will do about 3 hours in the morning and then about 4 hrs in the afternoon. Floor surface gets to about 19ish, so well above dew point. It doesn't make the house cold, it tempers the temperature, but more importantly feels cooler than it really is. UFH radiates heat at you, in cooling mode it suck heat from you, so you feel cooler. If you have radiators don't bother it doesn't work. If you have fan coils you can have a nice cool house. Ignore the nay sayers, they probably have never tried. If you want cooling on all the time you need to be careful with flow temp and about 1 Deg above dew point should be fine. -
Go to the builders merchants and whichever they have most of, that is possibly the one you need. Get a small tin of 3 in 1 oil to lube the wheel bearing they sweek often. Beware the only thing stolen on our site was wheel barrows (X2), so don't go wild.
MVHR specification?
JohnMo replied to Philxyz's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It's basically tells you that you only need one duct run to each terminal point. As your max target is 100Pa and you are well below that. So your number ducts is now decreased to one to each room. You now need to look at the kitchen living space and assess if you need supply and extract. If the living space doesn't get a cross flow from elsewhere, you need a supply duct there and an extract in the kitchen as far from each other as possible. -
Fire protection of steels and this example?
JohnMo replied to Alan Ambrose's topic in Building Regulations
Do you need fire protection if you don't have an upstairs? It could just be roof above? -
Can you do a contemporary self-build on a budget?
JohnMo replied to flanagaj's topic in New House & Self Build Design
You must be tired? That's a long build. But your not the only one here. I took time away from work so worked full time - I'm older and was quite happy to take a break from the daily grind. -
You obviously wanted a silvered weathered look - I wanted the exact opposite. Buying green wood allowed me plenty of time to do the cladding without getting the weathered look. Ours is now oiled to protect it from weathering. All stainless fixings etc. I could have gone to Russwood to get exactly the same profile with trees from the same forest. I didn't want kiln dried, most of my wood came in 5.4m lengths, couldn't get that from Russwood (at the time), even if I wanted, the trees were cut specifically for me from a wood 20 miles from the house. I took your point it wasn't missed, just explaining a different way around things and keeping inside a £1500 m2 budget. -
Simple answer is yes. You need to target how you design, how you purchase, make little or no change during the build. We got green larch direct from the mill for about 1/3 russwood prices. Generally keep things simple, UFH in screed is cheap and easy. Do you need multiple zones no. Spend on insulation , airtightness and quality of finish. Design of house really makes very little difference to build cost, efficiency of design and how you build it is where cost savings come from. Choose a build method that is cost effective. -
Mini Store - Heat Geek / Newark Cylinders for ASHP
JohnMo replied to Nick Laslett's topic in Air Source Heat Pumps (ASHP)
Think all industry is the same in the UK now, we have become a culture that changes black boxes, with little or no thought - computer say... they do and don't look much further. -
What to do with MVHR for final airtest
JohnMo replied to PNAmble's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It was just ready to plasterboard, all insulation, vapour and airtightness done, but with access to fix stuff. So service void battens on walls and ceilings etc. Holes through wall for mvhr were blanked off at the wall. -
Getting broadband/WiFi to my garage.
JohnMo replied to Russdl's topic in Networks, AV, Security & Automation
I have WiFi in the summer house which about 25m away. I use the plugs you stick in at both ends, one end connected to router. Seems to work just fine. People will say it needs to be on the same circuit, but mine goes through 3 consumer units and still works fine. -
Not really re inventing, just a variation, like spoked becoming alloy wheels. Does the same thing packaging slightly different. -
All rooms are vaulted. Vapour and airtightness layer then 50mm service void and plasterboard, taped. -
Sorry you may need to expand, not sure what you are asking? -
More to the point do you need or is it a good idea at all. It provides zero movement tolerance, which isn't good. For context My frame is sat at indoor ground level, we have oak flooring glued to screed, there is only 45mm of frame showing at the bottom.
Or if you're considering a combi boiler, fit a system boiler instead and a HG small cylinder where you could, way better performance than a combi, hot water to the tap as quick as an UVC cylinder, indefinite hot water, just set heating system as PDHW. -
Thermal bridge wide looks good. Upstand, can be PIR to save money and get as good or better performance. Don't like the angle steel on glass
Help designing our home network
JohnMo replied to MechanicalBuilder's topic in Networks, AV, Security & Automation
We kept it simple No BT or openreach to the house, although I did lay a cable to outside the house and the nearest pole (in same trench as power) just in case it gets better than snails pace. We just got a 4G router and a cat5 or 6 cable to each room, two to office and two to living room. Not sure why they need internet, but I am sure someone will come up with a good reason. But while you are digging things up may be useful in the garage. CCTV is all wireless. Yes. -
Think that's the advantage of the smaller cylinder, as with the smaller volume and height you are able to to get to decent flow temperature and replenish quite quickly. My 210L slim line, completely destratifies as soon as the reheat cycle starts. I think it's more about making heat pump accessable and installable for combi replacement. Think the practically and consequences are different. This HG cylinder is in a closed system with a given volume of water spread across the whole house. It's at a pressure of around 1 bar gauge. The cylinder has an open end so any expansion can more outwards to the rest of the heating system which would act as heat sink. An UVC has a blocked discharge i.e. taps are closed, it has check valve in the inlet. It cannot allow expanding water anywhere to go. -
Really depends on spec PEX based UFH pipe isn't UV stable, however pert-al-pert is. So just depends on the pipe you've used. If it's underground it should be ok, not so sure how frost tolerant it is however.
In the short term it should be ok, but over time and as rusting increase it could start cracking in the concrete. Corroded Steel takes up 6x the volume of not corroded Steel. Laser is the way to go. I would say no, you are not supposed to back fill foundations. There's info in building regs on what is allowed and not allowed. As this will also be an inspection point for building control. Get it right know the facts.
We have an allowance each, I spend it whatever projects/tools I want she spends it on clothes etc. I don't bother what she spends her money on, she doesn't care what I spend my money on. Works well.
Solar thermal is a water based system and it requires a coil to transfer the heat to the cylinder water. However a solar PV system is an electric system, so provides main voltage electric. The only practical way to get heat into the cylinder is via the immersion heater with PV. So the diverter goes between the your consumer unit and the immersion isolation switch. With a CT clamp on the tails to electric meter, when it detects outward electric flow (export) it switches on power to the immersion. So if you are exporting 1kW it diverts 1kW to the immersion.
