Pocster
    29
Everything posted by Pocster
  1. So, My tenants have blocked the toilet. Naturally although I look can I find a plunger ; of course not. So off I trot to the BM expecting the 'conventional' plunger. This is what I get!!!!
  2. Does it work? Does it F....... IMG_8940.mp4
  3. Well! Got it working but not sure how/why. After messing around I finally removed the main devolo plug from the extension lead. As it can't be plugged directly into the socket (the socket is installed up side down) I plugged it into ANOTHER extension lead on it's own. WORKS! (I think ).
  4. Thanks man!. That means a lot !
  5. Primed and ready to go !
  6. Yet but your bathroom has cost 60k ! ?
  7. Going to mount my walk on glass in a vertical frame and make a ‘rustic’ front door ?
  8. My response was based off my experience. If the build exactly matches the drawings then yes it’s all perfect . If the contractor messes up even off accurate plans then their fault .
  9. You are wrong. The fact it's based on my experience - shows it is real advice. Not what I think but what I expereienced. Take the timber frame. I measured it to get a quote. The company then measured it "properly". When it was delivered was wrong!. But they measured it wrong not me. Imagine if that had been the other there way around - liability would of been with me. I'm probably going to have 40k worth of glass. If a company ( after my initial measurements ) can't be bothered to send a sales rep to measure ( so they accept liability ) ; then I'm not going to risk 40k. You could argue measuring for windows is a much simpler thing i.e. the size of the hole. Quite probably if you measured yourself all would be good.
  10. Measuring and getting it right can be open to interpretation- I shoukd know ? Once example was our structural steels ; easy to measure but I got a firm out to measure ( and charge extra for it ) . In the end their measurements were different to mine because they took things into account only a steel fabrication firm would know . With Windows I take no chance . If they can’t be assed to come out and measure forget them
  11. Excuse me it’s Saturday night ! So ?, ? and ? not bleeding mastic and grout
  12. Yeah . All plugs have latest firmware As I said , it worked perfect for a month . Not sure what to do if these fail and the AP units failed , what other options are left .
  13. Yeah but it all worked great for a month . I’m checking tenants rooms Monday making sure nothing dodgy ( electrically ) isn’t plugged in
  14. Yeah . I know that’s a ‘bad’ . But worked perfect before . Also the plug socket for reasons unknown upside down so I can’t plug the devolo direct into the socket . i think Monday I’ll plug the devolo direct into a wall socket ( no extension lead ) then run a long rj45 to it .
  15. With just the main plug and one other get poor speed one way . Main plug still flashing red home . Even tried another one there - did the same
  16. Hey So I got rid of my AP units and installed devolo plugs so WiFi is great and a wired connection is available. Today no joy ( been working flawlessly for a month now ) . Main devolo plug wired direct to router always goes to a red ‘home’ light . Suggesting I think low bandwidth. Electrical interference ???? Not sure what the issue suddenly is !!
  17. Yeah I did do exactly this first of all . Shoukd of videod that really . Anyway the 2 sent back ...
  18. Yours does indeed work . You must use special stud !
  19. Ok - I’m going there !
  20. Lidl’s , Aldi EU muck ! I blame brexit
  21. Headaches subsided ? But so’s the grouting ??
  22. Even the “Tesco’s Finest” wine I have here tastes ropey . Bloody Brexit strikes again ( there’s only so much I can say about stud finders so I’m trying to move with the times )
  23. Determined to find one that works . Given myself until March 29th , after that I won’t care .
  24. Others are all eBay so refunds in progress .
