Everything posted by Pocster
Do you mean your router has the default username and password for login? - this is NOT the same as the Wifi password! 2 different things! Once you do have the admin login some routers allow schedules so you can block your son's mac address (mac is a unique code for a device ). Perhaps enable it when he's been good!. You will be in control. CONTROL = POWER!
Excellent!. I'm up there Monday and will check that.!
It appears that the router can add it's own port forwarding rules for such things as WhatsApp. So it's possible there is no unauthorised access. Be real nice though if the router firmware actually said "I ADDED THESE'! https://www.homenethowto.com/ports-and-nat/upnp-automatic-port-forward/
Yeah I'm not totally up with this. Need to do some more googling!
But they would need the router admin password - which of course isn’t the default . Also one of the port forwarding entries was for WhatsApp . Why add that when you access the WiFi anyway ? Another was labelled as ‘xbox’ - no one in house has an Xbox . Thing is I was in and out the port forwarding pages everyday whilst fiddling with cameras. Only went in today because they aren’t working . Does anyone know if it’s possible to login to a router remotely? E.g <global ip>192.168.1.254 / admin/ <password> So I can at least look at the hubs settings remotely...
Did you change the admin password or just WiFi access ?
Also the culprit port forwarding rules are in a different colour - not sure of the relevance of that .
Ok ! Had all these issues with the 2 UniFi AP u it’s so removed them . Today my up cameras don’t work as though the dns isn’t working . I go to the property login to the port forwarding page . Everything seems fine ; but 3 extra port forwarding rules have been added !!!! No one knows the router password though - and it’s none of the tenants. So how was it done ? Whilst fiddling with the AP units for days I factory reset them many times . It’s not possible from their default password to access the router somehow is it ? For now I’ve left the router as is - take my Mac there Monday when hopefully I have more understanding of how this was done. Any help appreciated cheers
Best simple ideas and concepts to design in to new build
Pocster replied to albert's topic in New House & Self Build Design
Sorry meant Qubino !! -
Ceiling speakers in all main rooms wired back to a single source ( multiple pi’s ) . Quintec lighting for sure - all linked to a z wave based hub . Electronic ‘catch’ on door so can be unlocked from another room . Cctv external and some internal ( hallway face recognition) . Some old iPads wall mounted for control ( not everyone likes shouting at Alexa ) . Led strip lighting at bases of stairs ( z wave controlled of course ) . Cold water tap where that big American fridge freezer is going for inifinite ice ! ) . Qooker Tap as mentioned . -
Easy wipe blinds ...
That’s what my misses tells me !
Managing build myself, all advice welcome
Pocster replied to Wagas's topic in Project & Site Management
Must admit I did get around 20 quotes also for the ‘dig a big hole and not cause surrounding houses to collapse ‘ . As it was a non standard request and as the quotes varied wildly I needed more to find the average price . The lowest quote was 7k ( which is impossible) . The highest just short of 100k !!!! Most seemed to get in around 25k ish . In the end went with gut instinct and choose some guys for 18k -
Did all the requirements for the roofer . Upstands another 50mm higher . Causes problems at the house as effectively I’ll have to raise the floor I.e thicker PIR below UFH . But have plenty of ceiling height to spare . Roofer has no spare men at the moment and snow is forecast - so need to wait patiently...
Pocster replied to Onoff's topic in Bathrooms, Ensuites & Wetrooms
Fair enough ! So now if you enter the bathroom whilst SWMBO is in the bath and the lighting is red ; you are in trouble . Red = anger ! -
Should of done RGB LED then you could change the 'mood' when you're rub a dub dub in the tub! -
Yep. It's very very hard to actually 'trip' now. Much happier with this arrangement.
Don’t go creating scenarios! . I’ve dealt with knife attacks , drugs , alleged rape , drink , police - that was just all from 1 tenant and lasted 3 months . If they trip and land on a knife in the dishwasher then I’ll eat my shorts !
Builders done a good job on the ‘bar’ - step is no longer a hazard . Have put up a ‘mind the step’ warning sign anyway .
Easiest solution is dig all hers out and redo . Why isn’t hers smooth ? @Onoff you are employing shoddy labour !!!
Ahead Warp factor 5 Mr. Sulu -
I’d just board up the window rather than having cheap eBay dolphins shitting at me .
Looks bang on too me . Can’t wait for you to do ( start! ) mine !!
Yep ! Im sat here and I can see one of the guys has put his push bike on the front garden path and gone in the house . Not a problem ; but he’s asking for it to be nicked !!
Oh we’ve been there ! luckily with geniushub and say a heater in a room the graph does a nice linear line - so you know there’s an issue . Also suspicious when room is set at 20 degrees ; rads off but rooms at 24 degrees . i know all their tricks !
