Pocster
    29
Everything posted by Pocster
  1. Fussy (expletive deleted)
  2. Run the 15mm pipe . Stick the shower on the end pointing into a bucket . You’ll see the result for real . All this blended BS is 💩; so I have to wait 8 seconds for my shower to get hot from the uvc - who cares .
  3. Must admit I didn’t bother with any of that . I had a new water main put in ( assume you did also ) . Instantly I could see how much better the water pressure was ( we used to live next door to the plot and water pressure was ok ish - old pipework )
  4. My shower is around 16m away from manifold . 15mm pipe no issue
  5. 15mm everywhere . That’s means you purchase one lot of pipe and fittings . Easier if it’s all one size and (expletive deleted) anyone else who says different. I’ve built an entire house on 15mm ( as advised on this forum ) so why change . THERE ! I’m right again .
  6. My most favourite shit shop ( after Primark )
  7. My pipes go where ever the (expletive deleted) they want . Does it effect the size of my penis ? No .
  8. Saniflo Compact is very quiet
  9. I know . I’m a qualified plumb (h) er and no one listens .
  10. 9mm and Climafkex . The heat loss even over 20m is low but I still think worth it .
  11. Ffs . I asked about lagging and everyone said yes for the hot especially if it’s a long run . For the small cost lag all hots . THERE ! I am right !
  12. (expletive deleted) off and put your ufh on; oh wait a minute...
  13. Yes. Effectively you don't need a macerator if you consume that delicious mush.
  14. The man with no knowledge will achieve more than the man with knowledge because he understands nothing and therefore fears nothing . Though I made that up it does sound kind of like some famous historical quote !
  15. The thing is with no calibre everything appears easy ; until you actually do it of course …
  16. It really is quite quiet . Also the motor doesn’t run on for long .
  17. Easy peasy lemon squeezy
  18. Wired up the saniflo compact . surprised for a macerator how quiet it is . How easily it shifts a big 💩 though has yet to be tested !!
  19. Keep fighting to push forward - respect ✊
  20. Cheeky (expletive deleted)ing useless counting twat mother (expletive deleted)er slit (expletive deleted)ing shite basted chicken licking (expletive deleted)
  21. I guess it depends if you can get to those joins in the event of an issue . 95% of mine I can . But ; I’ve yet to have a Hep2o fitting fail !
  22. My view on this is simple . Had a manifold of manifolds and run a pipe to every outlet . My backs (expletive deleted)ed so I can think of nothing worse to getting under a sink etc. to isolate it . It costs more in pipework ( but less in fittings if you just let the pipe ‘ go where it wants ‘ . For me to isolate in 1 place is fantastic - and I use this facility easily . I’ve just added an outdoor sink and broke my own rule ; branched off the kitchen hot and cold - it just wasn’t worth the effort of 2 new feeds . So in hindsight; an ensuite for example could just be 1 hot / cold feed rather than be a feed for each outlet I suppose . I guess it depends as well if you are living on a building site ( like I am ) ; the convenience of isolating each thing is great .
  23. F all wrong with it
  24. What is wonk ?
