Pocster
    29
Everything posted by Pocster
  1. Yes . I have swept tee’s for this ( I have no long drops - but would want a nice bend if I did ). On your straight connections @Thorfun I see no swept tee’s which I think @Mr Punter was indicating .
  2. Must admit I did wonder this also ( honestly ! ) . So splat and liquid runs off but solid might linger …
  3. That was exactly my thought with plumbing . It’s a case of get the soil pipe to where it should go and then everything else to it . Like you with mvhr pipes in the way things can get tight and rather restricted ( creative pipework …. 😁 )
  4. Any WC etc in basement I.e below drain level ?
  5. It was Steve Ball ( the company name ) not sure they are still around .
  6. You were at the Blue Parrot last Friday ?
  7. Please .
  8. You can grab my can . Shake it violently then watch it erupt .
  9. You’ve never shaken me ! - but I am sloppy for sure .
  10. I find some guns better than others . I never clean the gun because I’m lazy . For some brands I can use 5/6 canisters of foam before the gun is knackered .
  11. So I should put on as few zones as possible . Lower the pump speed ? . My concern is at a lower pump speed the temperature required might never be met so the pump is continuously running .
  12. My Wet ufh below ground has 6 zones . I’ve setup my automation to come on/ off when above / below temperature. Is it more efficient to have more zones on to heat the area rather than fewer ? I’m not worried about time to get to temperature. Also I can set the pump to a lower speed . So fewer areas ( open plan ) on at once ? . Pump lower speed ? . What combination is most efficient?
  13. Not sure . I’ll go with brackets as I know it will work . They shouldn’t be visible .
  14. Actually I’ll mount that right bolt . Thread the left ( but no nut ) . Take the tile board down on the left ( corner ) . Fit nogging . Then can have 1 L bracket coming out which will support that side and the front . Think I’ll embed it in the wall before tiling .
  15. Yeah I agree . Will do that and a pair of brackets . Really annoys me ! . I expect myself to be wrong ( and fix it ) but when it’s produced like this it’s a joke 😡
  16. Yes . Probably better than faffing around with this shite . VictoriaPlum if anyone wants to know 😞
  17. Might be able to cut that bolt . But it’s going to be tight if I need to get rubber grommet in there also
  18. It’s going in a corner , so I can fit one nut - will ct1 back and corner fixing . Tempted to get 3 small steel 90 degree brackets to go under it ( 2 for rear , 1 for corner side )
  19. Yes also holes are on the piss
  20. Nope it’s a wall mount basin 🙄
  21. The slots on the back of the porcelain aren’t level ( photo to follow ) . I could try your ‘ clamp ‘ idea . Could also cut that wall plate in half so my waste has got a chance to get to the bottle trap . I don’t know who designs these things - clearly they do not try actually fixing them to a wall !
  22. Nope . Manufacture of basin supplies no wall fittings .
  23. Right ! F this wall fitting . Take board off wall - wooden noggins and screw bolts into that . Still won’t be able to get a nut on one of them . ct1 back of sink to tiles ??? At least I can fit the waste correctly then .. f ing rubbish
  24. I said strap band also 🤣
  25. Ffs ! I choose this wall mount system rather than the 2 bolts into masonry because this is a stud wall . Mounting system is causing me more problems though .
