Everything posted by Pocster
The inter screws come with it . But yeah some timber box underneath sounds good
Getting ready ( ok it’s months away ) to fit the kitchen . All easy enough I think but there is a long worktop run around 3m with a return of around 1m Right in the middle of the room so not a lot to fix to . Can’t bolt to the floor as ufh . Was thinking of some kind of timber brace that runs under this run - but not sure of best approach. Appreciate once quartz worktop is on it ain’t moving anywhere but feel much happier if this L shaped set of units is mofo solid without worktop .
I knew his ‘ wine room ‘ would turn into a ‘whine room ‘ aka sex dungeon
Yeah it’s rice . Once all the curry ( sauce ) etc. is gone it’s just dry tasteless shit on a plate .
I think it’s an accumulation of rice . The ‘concrete ‘ or whatever it was seemed to be blocking in the bend - causing a matter ( like rice ) to get caught there and build up . Think the best solution is no cement down the drain and not to eat rice . Fillet Steak , homemade chips , garlic mushrooms and wine tonight . Drain will be safe .
Torch your (expletive deleted)ing house with suggestions like that .
I’ll wait patiently for my invite
Can I ask which brand ?
Yeah I was thinking about that . Any recommendations ? . Will chop up human remains ? ( asking for a friend )
A dish washer and washer do feed into it aswell . But not via the trap just direct into the saniflo unit .
No room for a pumping station under kitchen unit . Do have a pumping station externally for below ground WC - but that’s another story . Which was added afterwards 😩🙄🙄🙄
Top of the class for @ProDave I couldn’t resist undoing the sink trap …. What was in it ? Rice ( said so ! ) and erm cement or something … 🙄
Yeah I suppose it could be the sink trap blocked . I guess you are presuming pump would keep running if outlet blocked ? The saniflo unit feels heavy ( as though it’s full ) . Tomorrow will dismantle trap and see . Saniflo should put legs on unit so it’s easy to get a tray under to drain . Also a screw thread drain not a plug so controlled release of water .
No . It’s draining REAL slow . So every 20 mins or so the pump kicks in for a second . I presume the inlet / filter on the pump outlet pipe is blocked ( bet it’s rice ! )
Sink U trap with drain also ? . My plan is when sink is empty to disconnect then I can get some height under the unit and get a tray in .
Should have fitted a tee on the outlet ( only temp kitchen so no a real issue ). If I take that plug off I’m going to flood shite everywhere Photo from internet
Perhaps a tap with a tube to the front of the cabinet ? . So I can drain in a controlled manner ??
This a plug or a screw ? - I think it’s a plug ! So perhaps in the future raise the whole unit a bit so I can get a tray under it ? . Perhaps a ‘channel ‘ that takes the water to the front of the cabinet so easier to empty into a bigger tray ??
We are below ground level . Saniflo blocked - it’s grey water so presume just food waste . In the future though what should I do ? Currently it is draining but real slow ( like hours ) . Should I put some ‘tee off ‘ or something in the outlet pipework so I can drain it ?? As you can see even if I drain the sink I’ve still got a nice vertical pipe of stuff to deal with …
Excuse me ! . Unlike beer you don’t drink wine to get drunk . Wine is a biblical gift to find deeper meaning in oneself and save humanity .
Thought I was dreaming … “ A wine room “ - heaven does exist on earth .
I guess the ‘best’ I.e cheap and not internet dependent ( unless for remote access ) no subscription would be a zigbee hub and trv’s .
