Everything posted by Onoff
Help with kitchen renovation/ 1st house.
Onoff replied to zoothorn's topic in Bathrooms, Ensuites & Wetrooms
You can with induction. On ours we can set it to "pulse", even has a pause button. Auto shuts off in the event of a pan boiling over etc. Mate's missus just gone from gas to induction and loves it. -
I've got to knock this wall out a bit more on the left, only by about an inch. Chain drilled it originally.....just not enough. SWMBO has a thing about dust...weird... So how to move a large volume of dust? Going to chain drill again then comb chisel it. This thing connected N/LA for the fast speed should help with a bit of a cowl and some 63mm duct out the window. -
Attaching Christmas wreath to powder coated front door
Onoff replied to Jude1234's topic in Doors & Door Frames
Can't you CT1 a wreath to a spare bit of glass and just "get a man in" every year to swap the panels over? -
Enjoy: https://www.mig-welding.co.uk/forum/forums/woodburners-stoves.73/ Specifically: https://www.mig-welding.co.uk/forum/threads/waste-oil-heater.57695/
Make a bfo warm air panel heater from scrap and strap to the side of the shed. Some of the lads here have snow on the ground: https://simplysolar.supporttopics.com
Is the shed atop a slope? You could diy a bfo solar thermal panel and use that for the UFH. Get the heights right and it'd thermosyphon.
Can't help feeling that should have "tuck" on all 4 sides of the upstand. As if you'd put say a 20x20 batten around the shuttering before you cast it. Something for the asphalt to key into. Like my little hand sketch a while back. Then you bed the skylight on whatever goop you're using.
Welcome. Can't beat going off piste I say!
You could load Remix OS on a Windows laptop and get the full Android experience...
No Android device?
Lots of solar pv apps on the Play Store.
Unistrut? Or one of the cheaper clones. Galvanised, lasts pretty well down here as long as you galv spray the ends.
Basic advice of block construction and timber cladding please.
Onoff replied to Tony99's topic in Brick & Block
Put simply it has! https://www.homebuilding.co.uk/does-triple-glazing-make-sense/ -
Problem solved! https://m.ebay.co.uk/itm/LED-Lightshow-Projection-Plus-Whirl-a-Motion-Static-Wreath-Red-White-Green/123210588060?ul_ref=http://rover.ebay.com/rover/1/710-53481-19255-0/1? -
Yes, grab adhesive, many names/makes. Even saw one in the Pound shop yesterday. No Nails Pink Grip Grip Fill I Can't Believe It's Not Nails No More Nails Sticks Like Sh!t Sikaflex EBT CT1 Etc, etc Your cables I'm guessing are two 6mm2 twin and earth. One comes from the consumer unit (40/45A breaker) and the other goes to the cooker. Do they come into the rear of the back box or top and bottom? I've foamed a loose back box in temporarily before (now taken out): This same wall had hollow blocks in. So hollow that the permanent fix to fit the 47mm back box was to first fit curly wurlies meant for pb then push the whole lot into mortar pumped in with a mortar gun. -
What 5-core cable? Just No Nails around the sides of the back box if room then. -
Void behind socket? Socket loose? Get the Hoover in there and suck out what loose crap you can. Pump No Nails or similar in thru the screwhole. Push a Rawlplug through the back box hole into the No Nails. Allow to set. Put screw in. Or redrill where there is something behind the back box. -
Or casting your own even...
I looked at their wall hanging WCs I seem to remember... Duravit-D being their low end range?
What's a stilted tile?
I'm lost...aren't you having block paving atop the asphalt? With the top of the glass level with top of the blocks? Need a section view to remind myself.
If you get sick of looking at those missing tiles on the left just glue a strip of stained timber up there. Just a blob of silicon on the tiles and you can remove later if you get access to a tile cutter. Btw, what size are those tiles? Mate has just done his kitchen in white subway tiles though I can't remember if they're bevelled. I could get one, cut a couple of slivers and post to you. -
Screed to falls...that was a bloody good idea! Got a pic of the problem area?
For someone with no tile cutter well done that man! -
Plastic coated door? Suckers! Random eBay image: eBay, Amazon, Wilco etc. Available in different diameters. https://www.wilko.com/en-uk/wilko-suction-hooks-30mm-20pk/p/0344714?
