ToughButterCup
    101
Everything posted by ToughButterCup
  1. A good mate of mine is upset: in my estimation, justifiably. Here's why. It would appear that -with impunity- falsified Percolation Test results can be submitted as acceptable, valid evidence in the Planning Process. I hasten to add that this case refers to one outside our Local Planning Authority. What happened? Planning permission was awarded on a plot near his house. A pre-condition for the award of planning was the normal Percolation Test. Because the plot near his house lies on the same type of ground (heavy clay) my mate knows that the percolation test must have failed. But that's not the issue What is the issue? The Ombudsman considering the case says that the simple submission of results (any results, true or false) is the sole responsibility of the applicant. Since there is no system internal to the LPA that checks the test results, any results can be submitted: even false ones. The Ombudsman says ' ...It is important to remember that the obligation to provide accurate information lies with the applicant. If Mr X’s suspicions are correct and a problem arises, it is likely the Council would be able to control it, either through planning or building control enforcement, or perhaps more likely, through environmental health action.... ' So you can build a house based on bogus test results, and sell it before the problem becomes apparent. And everyone around the plot has to suffer the consequences even after the builder has sold the house. How is that system fair?
  2. Most people do not read. Especially on a computer screen They skim, pause, read, skim on. STOP at KEY words. Then think and possibly respond. Look at the dense text you present above. You know it inside out and backwards The reader doesn't, and probably doesn't care either. Your message is a high-stakes one. Sent to someone who doesn't give a toss. She has 55 others to read before having a nasty commute home. If it's a high-stakes message, make it visually easy for people to access your message. Thus 1. The architects drawings (above), refer to details under these headings as do the structural drawings and calculations in terms of charring. External walls within 1000mm of a boundary. and are clad with fire cement tiles and are in line with the architects specification the tile specification will be as Marley Thrutone and are rated CLASS 0 as is required within 1000mm of a boundary. Details here. There are loads of other visual tricks to apply. Here's an online resources which, with a few tweaks, will help Make it easily legible to a tired, pissed off, distracted idiot. Make it easy for a local Donald Trump to read.
  3. Delays can be made to be useful. Plan.
  4. Interesting list @Ferdinand. As a backup to your list, can I suggest this set of lists: I drafted this post out of sheer irritation while in a Parish Council meeting.
  5. That banking 'incidents' skill. Phenomnal. It just taught me to be similarly careful about remembering 'things'
  6. Your architect doesn't have that experience? And nobody else in the practice has experience either? Or your architect doesn't feel able to have a professional discussion with colleagues about it? My (remaining) finger-tips are burning.
  7. Yes, they will. We have decided to build in what the trades call the wrong order. In our case, for the builder, the term 'wrong' meant Not what we always do, and we don't want to think about what you , the customer wants. Out of caution, and in the light of experience locally trying to find labour, we asked our (now ex ) builder to put the roof on first. "Nah, mate, can't do dat. 'S aw rong" "Thats interesting, tell us why? " A quick email to and phone call with the SE, a chat with the architect resulted in a simple drawing from the SE, explaining where the temporary support needed to be installed while putting the roof on before the first floor. Exit the builders stage left : they would not guarantee they could find a roofer before rain ruined the first floor. That flushed them out didn't it? So, it's back to the full-on DIY self-build means self-build experience. If I can't take a joke, shouldn'a started should I?
  8. I bought a puffer as you advised some time ago. But this time, I thought I'd be a smart-arse and get a compressor (my mate was selling his) and so it was 'any-excuse-to-use-it' time. From now on it's Drill Compressor blow Brush out Compressor blow Brush out Puffer In fact, just like it says on the tin. In pretty pictures for idiots like me who don't read. I think I'll adapt a resin nozzle for fitting on the end of the compressor gun so that the jets blow sideways too. Lesson learned. You could get a part time job as a teacher @Onoff.
  9. Welcome indeed. You'll be aware that getting rid of water is the key to any build: all sorts of water: from interstitial condensation to foul waste. We'll follow your story with interest. Ian
  10. Knowing which one to use and why, and much more important, why not to use the others. I'm thinking about (say) a BCO asking me which chemical anchor I have used - and being able to respond to the challenge 'Why didn't you use [xyz]?' And trying hard to avoid the @ProDave scenario outlined above. I've got a few chemical anchor jobs Wall plate for the main roof - (likely the glass capsule idea you outline above) Threaded bar for the edge protection fittings (M12) - might well drill right through the concrete, bolt and plate both sides instead. (Foolproof) Threaded bar for the rim joists (M14 / M16) In terms of making holes in concrete and using chemical anchors , I remembered @Onoff's advice to clean out the holes properly. So I bought a compressor and blasted the holes out thoroughly. Or so I thought. Debbie, bless her, suggested I clean the hole out with an old toothbrush as well. Cue embarrassment. Loads of secret crud came out. Further blasting, more crud still. @Onoff, thanks for the nudge about the pull tester. If I can hire one, great. If not I'll just drill right through the wall and put a large washer under a nut and lock nut. Overall, that'd be cheaper. Thanks very much (as always)
  11. Thankfully SWMBO did ours the other day. I would now have been dead had it been the other way round. Dead. Has been. Ex-alive. Watching with interest
  12. Man riding ? Auto-correct has a sense of humour ?
  13. To date, I've only used Fischer. And I learned the nozzle game the hard way (geddit?) : planning to use a whole tube at once is a bit of a dark art isn't it? I'll look at the Hilti stuff and maybe try some, but I bet I end up taking @JSHarris advice. Our concrete is all bone dry. I know, it's just me: I like to know why I'm doing what I'm doing, and why I'm not doing what I might reasonably be expected to be doing. And that's not a recipe for an easy life.
  14. Or perhaps I should have written: Choosing the correct one isn't easy I need to embed threaded bar in non-cracked concrete. That's why SEs and others say 'You need a chemical anchor'. Have you looked at the range of them on offer? Which does what for whom under what circumstances isn't made clear at all. So it's off on yet another electromagnetic adventure: and apart from suppliers websites (which I automatically distrust) there's precious little to engage an interested but skeptical customer. True enough, I did find this . But the authorship of the site isn't made clear and there's a lengthy disclaimer. (at the bottom of the page). I trust that just about as much as I trust Donald. Screwy's , TS, and local BM sites and others aren't interested in anything other than sales. Fischer do a technical support site (just a phone number), but they only focus on .... you guessed it. Why does styrene matter (as in styrene-free) ? Is generic stuff just as good as branded ? Who or what is Vinylester? (yes it's is a resin produced by the esterification of an epoxy resin with an unsaturated monocarboxylic acid. but what the Hell is that? What's the difference between high performance and normal stuff? Why is there such a price range? Cheap = bad, expensive = good ? What's good enough (for my job)? Does anyone know of a site which simplifies this mess of advertising claims erm, (sorry) , information ?
  15. Scaffolding, with buried HERAS (rubber block) feet, scaff clips and effort. The key word is temporary isn't it? I'm assuming the end in mind is the Habitation Cert; pretty, nice later. Bury (fairly deep) HERAS feet at suitable intervals (second-hand £5 each) , and slot the standards in the central hole of each HERAS foot. Backfill the hole: no need to use concrete. Clip the ledger (handrail) as appropriate. You might well need brace the standards. That way, everything can be made to disappear (Kerpow!) later.
  16. Since you are going to need scaffold later, try a bit of kwikstage. Buy four casters and you have yourself a mobile platform, like this.
  17. @readiescards, how much time do you have? We are on Glacial Till overlaid by Made Ground. We like you are also on slope. The first thing I did with the digger I bought was to dig a deep hole (as deep as the arm would reach), mark and cover the hole with railway sleepers. And left it for a year. Each month, I'd take a photo of the water level in the bottom. As @ProDave suggests above, that job established the winter and summer water table. (For that year only: but it gave an indication of an average level at that location) We did the same at another location and the level was a little bit different, but not much. That exercise provides us with fairly hard evidence of where to put in land drains: and where to duct the water. On the basis of those results we have a plan for a 'wet area' for our GCNs. When that overflows, it'll trickle off into the surrounding fields.
  18. Given that I'm deeply into the full-on DIY experience and DIY kwickstage experience to boot, the next practical challenge is to reduce the number of solo trips up and down the staging I have constructed. Which makes look interesting. My first thought is 'weather' I'm thinking of being creative with an suitably adapted empty plastic barrel pressed into service as a housing. But I bet someone has solved the problem before.....
  19. The only reason I can see to replace my current helmet with another one (dropped and deeply scratched) is the slots which allow ear defenders to be 'parked' on the helmet, and visor be slotted to the front. I love the bump cap I bought for Debbie. Don't tell anyone, but I wear it when shes not on site. And nobody points and laughs. Mostly the bump cap does what it says: stops me bumping my noddle on the scaffold. Whereas my helmet is just big enough to make me duck a bit more than I normally do - slips around when I don't want it to; and while its quite light-weight its a bit of a pain. Mostly I'm on site on my own; mostly I nut myself gently (but painfully) on bits of scaffold. And nobody is going to drop a spanner on my head. Cap or helmet?
  20. Well, ya learn summat every day
  21. Yessir! I'd better get into the Regs hadn't I? Oh Gaaauuuud it never stops does it? Ian
  22. Yes. Presumably they don't dwang in Wales? (This might well go downhill from here....)
  23. Get yourself a twisting tool as suggested by @JSHarris. I have had one for years and I use it regularly. You can more than double the strength of wire when you use it to twist a long length, or just tie off the short ends super quickly. It takes a bit of a knack getting used to, initially you break (over strain) a few strands, but you soon get a feel for when you're going to break the wire.
  24. At the risk of sounding like I know what I'm talking about, should I dwang my joists? All those in favour say 'Aye', all those against say 'Nay'. Where's he dug that up from then? Here This is the relevant passage. '... The slimmer JJI joists have been plated at their ends and dwanged (horizontal braces) to form a rigid structure. Two thicknesses of 12mm plywood will cover the ends, followed by the green vapour membrane being folded up over to give a vapour barrier. Insulation board of 140mm thickness will be fixed on top of that to bring it flush with the Durisol blocks below.... ( https://edinkist.wordpress.com/diary-of-the-build/)
