Cpd last won the day on August 12 2022
Cpd had the most liked content!
Personal Information
Location
Scotland
Cpd's Achievements
Advanced Member (5/5)
759
So after many years ignoring my dreadful windows my sister offered to buy me new ones as a belated 50th birthday present š I am happy to fit them myself as the detailing inside will be tricky due to different wall / insulation thicknesses. There are only 4 windows all approximately 700x1200mm. I am in an extremely exposed location facing the sea. My house does not have mega insulationā¦. 70mm pir retrofitted to the inside but no floor yetā¦.. the retrofitted insulation was detailed very well so no gaps and fully sealed. The old windows were split into upper and lower panes but new ones should be be single pane to let more light in. I would like to keep the frames as small as possible so there is as much glass area as possible. I am based on the west coast of Scotland I. Argyll. My questions are. 1. recommendations for window supply only 2. anything I should be aware of ⦠pitfalls 3. type of window I should get 4. have I missed anythingā¦. thanks for any advice. photo is two of the old windows, the other two are the same.
Can I buy a cooker hood without a fan ? Just the grease filters ? I want to install an inline fan away from the kitchen to keep the noise down or am I over thinking it⦠its going in a tiny house thatās going to be used as temporary accommodation by my parents while I complete works on a cottage I am renovating for them. As itās such a small space I am concerned they wonāt use a standard hood if itās to noisy. Do I just buy a hood of the shelf and disconnect the existing motor and then wire in the new inline fan to a separate switch? Has anyone got experience with doing this ? I have plenty of space outside the tiny house for duct work and mounting a fan as there is a large covered over lean to. If this is not feasible then what sound rating should I be looking for on an all in one set up ? Any advice would be great. Thanks
I have recently built a 20 meter x 6.5 meter polly tunnel and itās just survived one of the worse winters we have had for years, one wild storm after anotherā¦. The footings are all concreted in every 2 meters and there is a post driven in between each 2 meter section, I also have wires going from the bottom of each footing up to the top ridge and back down the other sideā¦.. x 3 ridges and loads of cross supportsā¦. Itās in an extremely exposed spot in Argyll. It is possible to make them work if you have no other choice ( I already had the frames so was committed to this set up) but if money was not a problem I would go for a more ridged set up so that I could get more sleep in the winter storms - rather than constantly going out in the middle of the night to check !
I had problems getting my Airbnb cabin insured but then went to my local NFU who I already have my house and car insurance with and they were very helpful, definitely more expensive than others but at least itās done.
I expect itās because itās the coldest, most unventilated area you probably have and is damp through a mixture of interior condensation and moisture coming in from the outside, a quick option is to clean it with a bleach / anti mould solution and then paint with a bathroom anti mould paint. Then leave it open so that itās well ventilated and warm. If this fails then I would consider levelling back the surface and fully bonding on some ridged insulationā¦. This may just move the problem to another section of the room but heat and ventilation will really help. I have lived in numerous houses with this problemā¦. Total interior insulation has always resolved the problem for me , But I donāt know your situation.
I have had my house insured by the NFU for the last 10 years but this year the policy renewal has gone up from Ā£358 to Ā£472 the policy is for replacement cost of Ā£182 thousand I donāt have content insurance. just looking for any recommendations on other firms, I have never made any claims on any of my insurance policies such as car / business insurance. Always been happy with NFU but maybe itās time to look around. Thanks
I am just about to buy a new set, as my old ones are pretty knackered, after a bit of research I am heading for the following. We will seeā¦.
I only have a very large septic tank but I feed it with āmuck munchersā every month, itās been installed a few years now and I took the lid of to check it recently , virtually no smell at all, just some dark water and no scum layer. No maintenance beyond feeding it monthly, and no electricity usage š I understand itās not possible for everyone but for me it works just great. KISS - Keep it simple stupid was what I based my design on, but I have plenty of land for a leach field which most plots donāt have.
Total cowboys šā¦ā¦.
How does your garden grow?
Cpd replied to recoveringbuilder's topic in Landscaping, Decking & Patios
Not been keeping up with the forum as I have been so busy all summerā¦. One of my long standing projects is the construction of my polly tunnel, 8 years ago I planted the wind brake and last year I excavated the site and this year I got the frames up, hopefully get the rest of the structure up In feb and plastic on in April. -
Same experience here, happy to pay if it keeps things smelling good and my worry at bay.
Great youāre back up and running mate !
I wanted to buy the same machine as you, live near oban with an Aldi ā¦ā¦ no chance š”
ššššššššššššššš
