Everything posted by joth
So when is relandscaping a garden or installing a swimming pool financially viable? Things are financially viable when the purchaser has the finances available to purchase it. End of. I think you mean economically justifiable, which is not always the reason to decide to make a modification to a home. Especially those with zero payback like putting in a hot tub or enlarging the patio. To give another view - we put a whole roof of solar on our house (GB sol RIS, picture attached) cost about 16k£ but the whole enerphit+ renovation has added double the value onto our house that it cost to do, undeniably in part due to the current crazy market, but in part because interest in sustainable designed houses are suddenly on the up* in our area and nothing signals this more clearly than a whole roof of solar (in a conservation area where this was not permitted a couple years ago). This is not going to be the common case I know, but done well I do see even the economic value being more than just the reduced electric bill. * I was very surprised - the estate agents we spoke to this week knew very well what a passive House is; turns out in large part because customers are taking about ours as a reference point for the area.
More important is standing losses. The battery should be negligible over a diurnal storage pattern, but the hot water cylinder is not, especially as the loses get worse the more full (i.e. hotter) it is. Topping up the battery before DHW is intuitively a no brainer for several reasons: Assuming optimizing to minimise energy costs rather than simply ensuring every Joule is usefully employed somewhere, the battery storage is far more valuable as it can be used for all import-reducing uses including creating hot water if necessary (even, via a much more efficient heat pump?) but the reverse is not true of hot water storage, that's a one trick pony Factor in the much higher capital cost of a battery and a goal of getting ROI, it needs to be in use every hour it be can to ever pay for itself. Add to that an aspiration of grid independence, and you need the battery as full as possible all the time as insurance against grid outages. Part of the justification for a battery is the freedom from having to analyse usage patterns: just use electricity as you wish and the battery will do the hard work to avoid import. And finally as mentioned, typical household DHW usage patterns (mornings and later evenings) favour topping DHW last thing in the afternoon as it reduces the time the energy is stored for, and hence the standing losses from it.
Moving gas and electric meters - where to put them
joth replied to Porthole's topic in Electrics - Other
That sounds surprisingly affordable! Ours was £1000 for the electrical supply move, and over £2000 to permanently disconnect the gas. Note if that's the quote from the DNO that will be just to move the supply head. You'll also need quote(s) from your supplier(s) to move the meters themselves, and from your own plumber & electrician to move the gas pipework and, probably, the electrical consumer unit. Depending how this lines up, that maybe 6 separate quotes. If ground works (e.g. trenches) are needed and you don't want to pay the extravagant DNO pricing for that, you'll need additional quote(s) for that (normally, via the main builder contractor). -
Aside from still relatively uncommon DC coupled battery, neither the diverter or battery needs to be next to the inverter. I'd site the inverter based on: - simplifying the routing of DC cabled from the panels to inverter, - minimizing the length of feed from meter head to inverter, - cool temperature. For us, these all happened to be the garage anyway ?
Selling or Significantly Renovating Will Mean No Gas Boiler?
joth replied to Ralph's topic in Housing Politics
Following on from my comments about the convenience of gas, there's a pretty good (if long) article on the challenges on Engadget today: https://www.engadget.com/air-source-heat-pumps-uk-120044198.html I think this section hits it on the head, I see the same mistake being made here: that economic savings are the only / prime basis on which sustainability measures should sell themselves and compete against the incumbent technologies. Most mod-cons sell themselves on the convenience and lifestyle aspirational aspects. (It's literally what the term modcon is derived from). While we all like thriftiness, en-masse it's not how the population works. (otherwise, explain all the Sky TV in low income estates) -
I shut off the power to the FTC6, waited half a minute and powered it back up and only then the cooling option appeared in the controller menu. My installer has a little ritual about powering down both the internal and external units, waiting exactly 5 mins then powering them up in some specific order to ensure they reconnect to each other, but I think (hope) that's cargo-cult. if there's a power cut in winter while I'm away I don't expect to have to send someone to dance around rebooting it in a special sequence just to get the heating working again.
Size and layout of your networking cupboard?
joth replied to puntloos's topic in Consumer Units, RCDs, MCBOs
Kitchen is less of an issue, unless you intend to leave 3kW burning running 24/7. It's venting into a larger space for a shorter period, so the roam can absorb the blast of heat and distribute it widely around the place. A cupboard has maybe 10th the power but it's on for 20-30 times longer per day and all caught in a smaller space. Also the kitchen normally has a double extract. I guess that's another option to try in the AV room. -
It definitely would. I'm piping it through a fancoil unit, that has a condensation drip tray and waste water pipe attached. All the supply pipework is continuously armaflex insulated, but I do get a fair bit of condensation on all the pumps and valves etc in the plant room that I'll need to work on improving the insulation around. (My original plan was to tank the plant room and install a drain grate in the floor, but this was removed for cost. Wish I had, as as well as allowing condensation to run free on the various plant equipment, it would also have made installing the overflow pipe for the water softener far far simpler).
Interesting - the keystone jacks I have use punch down not RJ45 style crimp connection. That said, I have successfully crimped oversized (CAT6A 24AWG) solid cores onto RJ45, just have to use the correct sort of jack designed for the larger cores, that have staggered entry holes. Excellent point about the stranded patch cables. I had assumed by opting for CAT6A patch cables I'd get thicker core cross section, but looks like they're only 26AWG equivalent (happily I've used the shortest ones I can, most are only 20 cm long so probably fine as you say) I'd be very wary about relying on MVHR for active cooling of a machine room like that. When all the gear is on I expect you'll have many hundred watts of heat being dumped, and MVHR will only shift 10s of watts at most. It's effectively useless for equipment cooling. I put an MVHR extract in the AV cupboard (with much less gear in it) and supply right outside it, and it's overheating (an, I believe, overheating the bedroom next to it - thread) so I've actually pulled the MVHR vent out of the AV cupboard ceiling and replaced with a larger extract fan to dump the heat directly into the loft. Up there I have a fan coil which provides active cooling (fed from the ASHP). I've also started relocating some of the worst offenders for heat generation out into the loft (the windows box running Blue Iris is particularly bad, and the Virgin modem and Unifi Router are also pretty poor). Regarding the slide a turn racks - I got one of these, but then had cold feet about putting the patch panel on it as I wanted the solid-core installation cables terminated in a fixed location where they'll not get flexed. Whereas the rack does get moved in and out a fair bit as I do like to tinker with the installed gear (and, I don't have the luxury of a dual access cupboard) -
New heating for terraced house in London
joth replied to Ferdinand's topic in Central Heating (Radiators)
Ours is 1m from a boundary (in a conservation area, no less) and certainly haven't had environmental health out yet. The road and 24hr train line is much louder than the heat pump, even stood right by it. The neighbours boiler flue is about the same noise.- 42 replies
- terraced house
- london
So true. Unless the home really is insulated well, with an ASHP you really need to design in some sort of time shifting for heat energy (e.g. storing heat in a thick UFH slab), and using direct resistive heating just increases that need (by 3x), which means much more disruption for any retrofit than the insulation & airtightness alone. Storage heaters largely fell out of favour due to the need to plan usage patterns and not just "turn on the central heating" when needed for instant warmth. (Remember all the Bob Hoskins "Don't you just love being in control" adverts?) So IMO any electrical low carbon source either needs to solve time-shifting in the home, or depends on grid-scale storage, to actually deliver on its goal -
Most patch panels and wall sockets (keystone jacks) use an IDC punch-down connector, and it'll be a miserable job terminating flexible cable into those. Aside from that, I'm curious what that reason is that installation cable is normally solid core? (Same for mains cable) -
The dip switches are on the PCB inside the FTC6 controller case. You remove two screws to pop the lid off the case, and they're right infront of your nose (along with various live terminals) Note the system needs to be powered down and back up to notice the dip switch change. Yes, it will heat DHW even when the controller is set to operate in cooling mode. Obviously only one or other at a time Make sure it has been plumbed correctly with a 2 position valve to send water to the heating or cylinder circuit but not both together.
Boiling Water taps. What and where to buy.
joth replied to ProDave's topic in Kitchen & Household Appliances
I assume you're looking at multifunction mixer taps with boiling water. If you get a tap with boiling water only, not a multifunction one, it'll work fine as they just need a mains cold water supply. There's many to choose from. If you would prefer multifunction look at the Quuoker Combi, as this does it all from a cold mains feed. -
Haven't tested the limit yet, but 5°C is the minimum setting the UI allows Yes, mentioned briefly upthread, but with ecodan FTC6, the call for heat dry contact inputs become call for cool when in cooling mode. The challenge is switching mode: can be done in the Mitsubishi controller UI or their phone app, but not via a simple electrical input. However it does have a cooling mode active output, so I'm thinking about feeding that back to loxone so it at least knows what result it of going to get when it calls for heat or cold, and locks out the other logic as appropriate. If I can fix the missing feature in the home assistant plugin I maybe able to programmatically change mode too.
On a ASHP this is quite achievable: on the Mitsubishi FTC6 you flip dipswitch SW2-4, power cycle it, use the controller to set it to Cooling rather than Heating mode, adjust the flow temperature as desired. Cooling, with no hands waved. There's basically places the condensation can form: on the emitters, and on all the intermediary pipework. If putting cooling through the UFH, there's a small risk of condensation forming in the screed or between screed and finishes. This can crack or rot wood etc. Bad bad, must be avoided by running it no colder than about 14 degrees IIRC Pipework condensation can be designed out: make sure it's all installed with high quality contiguous thick insulation, e.g. armaflex, no air allowed to touch the pipes, and there shouldn't be any way for the condensation to form. The fancoil linked is not so much about either these issues per-se, as it's just more effective and comfortable to use. In our house the downstairs remains fairly cool, and the ground floor floor-finishes themselves doubly so. The overheating occurs high up on the first floor. Much more effective to drop cold air from above on the house than try and cool it from below. Also, yeah the fan coil has a condensation drip tray and can run at 5 degrees C fine. So I plan to only use UFH for heat and the fancoil to cool. Unfortunately, there's no way to set this in the FTC6 -- both zones must be in heating or cooling, can't mix, and there's no electronic input to select hot vs cold, so I'm left doing an annual manual switcheroo from heat mode to cooling mode and back again. (The MELcloud API obviously supports doing this as the Android app does let you do this remotely, but unfortunately the home assistant plugin doesn't support it. Maybe before heating season starts again they'll fix this, or I'll see if I can!!)
Green Home Grant application - have you had a response?
joth replied to joth's topic in Environmental Building Politics
GHG just confirmed my installer has been paid! He was ready to do the install this time last year ago, but our build wasn't quite ready, then they announced GHG. I applied on the day the scheme opened. So basically 8 months from application to payment. Amazing. Can't complain though: with the grant the whole system 8.5kw ecodan, 300L OSO Geocoil tank, install inc. fancoil+UFH hookup, and more certificates than I can count, cost me just over £3000. I should be able to claim more than back in RHI (If I can be bothered with 7 mores years of admin) -
If it's either/or then this is exactly the right decision. The insulation will last many decades, not be obsoleted by new technology, and would have been significantly more expensive to retrofit than do as you build. While I'm really happy with our ASHP, I couldn't promise any of these points about it. In 10 years I expect they'll be more efficient and cheaper
Texecom connects to internet via the "SmartCom" Connect gateway https://www.texe.com/uk/uploads/Connect_SmartCom_Leaflet_WEB_4.pdf This is exactly the piece that failed in my installation a month ago and I just replaced yesterday. Despite having only had it a few months, I really wouldn't wish this system on anyone. I really do hope Ajax gains more traction with installers. In theory self-install is not allowed if you want remote "ARC" monitoring with police call out. A requirement of the URN process is the alarm is professionally installed and maintained under contract with a SSAIB/NSI approved installed. If you don't have remote monitoring, anything goes, but the manufacturer may want to limit who installs their stuff for market control reasons. (Seems increasingly popular in all forms of tech - our Solar inverter and MVHR both have locked out menus that me - as owner of the install - isn't even supposed to be allowed into according to the manufacturer. It's a crazy world).
It took them a further fortnight to turn it around but I did receive the replacement yesterday and all working again now. So 3/10 for manufacturing reliability, 7.5/10 for service. I have to take some blame for purchasing it via an unreliable online outlet I guess, the reviews are fairly clear on that: https://uk.trustpilot.com/review/cctvbuilder.com Yeah it was via the forum that I first confirmed this SmartCom had failed. The PSU was quick to diagnose by the original installer, but as I hadn't purchased the panel through them they were (understandably) not willing to take on the warranty claim for it, and I just couldn't be bothered to follow it up myself over the £40 they charged for the replacement.
Electric supply single vs three phase
joth replied to WWilts's topic in General Self Build & DIY Discussion
In that case you might as well get UKPN to put in the 3 phase head whatever, if it doesn't cost much more. All my research (talking to UKPn in particular) was that you can definitely get any supplier to put a single phase meter in on it, but having the 3ph head now will give you future flexibility should you ever need it. -
Note you don't have to be on SMETS2 meter to get vector sum / net metering. e.g. Sprint 211 supports it. (But conversely, having a SMETS2 is a good way to ensure it, as it's part of the SMETS2 spec) Most meters support multiple modes, and on a domestic supply it should be possible (pandemic aside) to find a supplier that will put you onto net metering. When I spoke to my supplier about this a couple years ago, they admitted they often get this wrong at first install and need to send a technician back multiple times to get it right. YMMV -
Yeah I've turned it from "Adaptive" to "Fixed" temperature profile, and *think* I've forced it into "summer" mode (it's rather ambiguous, as normally it won't start summer mode until mean outdoor temp hits 15ºC minimum, and we're still only at RMTO= 10ºC, but in the app there is a "start summer now" button I pressed, but it doesn't give much feedback it actually did anything when RMTO < 15) I then set the "Cool" temp profile to target 19ºC, and as it's always at about 21ºC indoors, this means it's pretty much always in 100% bypass mode, just adds in a little heat recovery overnight when the outside temp really drops Downside is we can regularly have >22ºC upstairs yet <20 downstairs, which together with the ground floor having a lot of porcelain flooring means there's still times the UFH might want to come on, but yet the MVHR is in bypass mode, which is obviously nuts for energy efficiency but we have to get the place comfortable before really starting to optimize this. But for all that, even with the supply temp now at 13ºC overnight and the bedroom supply vent opened right up, the room still rose from 21 to >23ºC last night, pretty much proving that it doesn't matter what we do with the MVHR temperature, it's the low flow rate that makes it insufficient for dealing with body heat. Yeah this is another avenue to look at, although it does feel a bit like failure to start down that path, I'll try that when other options are exhausted. Indeed. It was just aimless musing really, but the thought was an indoor to indoor heat pump that constantly collects the gathered heat from upstairs and relocates it back down into the ground floor slab.
yeah I knew well enough it wouldn't be sufficient for dealing with summer overheating and crazy solar gains, but honestly hadn't considered it's an order of magnitude too wimpy to deal with a single sleeping human. Wish I'd done the maths in advance. This is really helpful to confirm that you see the same issue and have had to make a solution for it. Unfortunately this solution doesn't work well for us - we are in town with a train line one side and sometimes busy road the other, and part of the inspiration for MVHR and passive-house design was the great sound proofing that insulation and the 3G windows bring. (And it does work great for that, modulo the overheating) Time for me to start designing secondary ventilation I think! We do have a fan coil in the loft, but issue is we need bedroom cooling even when the rest of the house is borderline needing heating on. It seems mad to enable active ASHP cooling during the heating season. (And, it's not that easy to do this dynamically with our heat pump). So need to figure another plan. Ideally I'd have a water to water heat pump that could cool upstairs while pumping the heat down into the the ground floor UFH First, I think I'll see if I can get some stack ventilation working through the room and out to the hallway vaulted ceiling.
