-rick-
Everything posted by -rick-
MVHR and cooling
-rick- replied to flanagaj's topic in Mechanical Ventilation with Heat Recovery (MVHR)
These look good. I quite like the idea of hidden emitters as part of a wall. If DIYing likely loads cheaper than fancoils too (though with some likely downsides) -
MVHR and cooling
Noted thanks. Not for systems used exclusively for cooling AFAIK. If you get an A/C system that can heat then you have the issue with BUS. -
MVHR and cooling
Well this sent me down a little rabbit hole with Copilot. Not worth muddying this thread with that though as I think the main point is as long as the system is quiet enough to sleep through any system (water or refrigerant) would work well to offset this. For me personally this pushes me towards wanting UFH for cooling in the bedrooms too to avoid fans running overnight as I'm particularly sensitive to that. I feel out of my depth talking about this more so I will let others address this. Either way, planning permission is still an issue. -
MVHR and cooling
It would admittedly be tricky to find a company to do it all for you within the grant. But more self directed options exist like Cool Energy that you could likely get pretty close to fully covered by the grant. Yes I was thinking of the radiator replacement/wall hung units. Surprised you say they are noisy, as people on here who've got them say they are pretty silent. Personally I'd be more worried about ducted ones transmitting noise between rooms. I'm a light sleeper so personally I wouldn't want any fans running when I'm trying to sleep (I notice even 'silent' ones), but I'd hope in a well built modern house if you control the temperature of the structure during the day then the room should carry through the temperature while sleeping without the unit needing to run. If installing FCUs in a new build at least with a decent amount of DIY labour I don't see why you wouldnt want to run pipes for condensate drains and insulate the pipes well. It's a something you could do DIY following behind a plumber to if you didn't want to do the plumbing yourself (tell the plumber to use preinsulated MLCP and just deal with the junctions). If the FCUs are fully ready for below dew point operation then in the event that a mistake was made in the design and you need more cooling than planned then you always have the option to modify the system to support below dew point feeds to the FCUs (with some changes in the plant room and the tradeoff of slightly lower efficiency). Would suggest you want to size the system to cover heating/cooling needs without operating below dew point though. You'd have to sequence this carefully though as it would be violating the BUS grant. MCS wouldn't install if the AC system was already there and MCS might not want to install anything if they can't satisfy themselves that you have provided adequate heating for all rooms (which you might not if it depends on the a2a system). You would also need planning permission for the a2a system. My thought is if you are going a2a, go the whole way and just do an a2a system (they can heat as well) and rely on immersion HW heating using solar/cheap rate. Don't do both. -
MVHR and cooling
It's available to self-builders too. Search the forum, plenty of examples. -
MVHR and cooling
You can get the BUS grant to install a water based ASHP (including the cost of fancoils if you want). Have to be careful as lots of MCS installers around bumping up the costs to suck up the grant and more. But plenty of experience on here. If you are careful and have UFH downstairs then won't need many fancoils and should be able to keep the costs close to the grant amount so the system will be free or almost free. Referring back to my previous post and your tight budget. The more different things you need, the more quotes you need, the more contractors you involve, all adds drain on your time and the more likely you will get overwhelmed dealing with so many things. When that happens the chances of costly mistakes goes up. Try to keep things as simple as possible. Fewest components, minimal complexity. -
Believe they are concrete: https://nextdaysteel.co.uk/products/concrete-square-bar-spacers-1m-length
MVHR and cooling
There's a lot here that maybe deserves point by point responses but I can't help feeling you are getting stuck into the details without actually knowning the scope of the problem. Have you done the heat loss/heat gain calculations? Before you spend time thinking about how to solve the problem it would seem best to figure out whether you have a problem and, if so, how big the problem is. You have said you are on a fairly tight budget. So if you want to get this project done without delays or blowing the budget I think you need to apply a razor focus on what you actually need vs nice things to have. -
Good result. I assume you are just running the pump in an on/off form. Any thoughts about speed control? Reason for mentioning is when I've thought about what I might want to do, if it ever happens, is that the pump might serve as a useful way to distribute heat/cold between rooms to try and keep things equalised despite some rooms having higher heatloss/gain than others. Edit: Clarification, idea being that to do that equalisation you'd likely want to run the pump more than for a short period every 40 mins. Running slow for longer might be better than more frequent full on pulses. I've done no maths on this as don't want to start detailled work until I actually have a project.
Wiring an outdoor switch....basic question
-rick- replied to saveasteading's topic in Power Circuits
Wouldn't this be a better solution in this case @ProDave? Saves doing anything inside the wall or serial switching. Can still replace the external cable if needed but just use a wireless external switch (they sell IP67 versions). -
I've seen a thread on here in the past about how the insect screens they had installed ended up being about perfect for shading too. Relatively cheap (as its simple roller blind) and maintains the view while cutting a lot of light. There are probably downsides too but worth considering as they will serve a dual purpose (though you will need curtains too if you want to black out the room).
The German population has a lot of experience with secret police from their history (East Germans it's often history they lived, West Germans history their parents/grand parents told them about). Obviously plenty of other countries have similar histories with secret police and the political systems they operate in but the Germans more than most have historically focussed on avoiding a repeat. One of the ways that manifests is in a much more privacy focused approach. They are the among the main drivers of European privacy law and have historically been the ones to block privacy invading proposals.
Wouldn't have thought of it if it wasn't for your thread. Very nice BTW.
Do you already meet Part O? If not, then heatpump driven cooling is unlikely to cut it and you need to think about what other changes to make. If you do meet Part O already and are doing UFH downstairs just set up cooling there. Upstairs if using radiators consider switching to fancoils in the same place. Pricier but probably cheaper than lots of other solutions. Adding separate A/C units in addition to your heating solution probably doesn't save you money (especially as the £7,500 from the BUS scheme might be more complicated if you plan to use it) but it's an easy option you could add in future if everything else doesn't work out. If you aren't planning UFH/heat pump heating then normal A/C units might be the easy option (but then maybe reconsider UFH). As far as other changes go, dropping the cladding as per @IanR might be cheaper than brick (unless you go from being able to use a single standard length of board for each column or the extra trim around the windows is costly) so doing that you could fit 'for but not with' external blinds. Alternatively, consider planning for a wooden pergola in front of the main downstairs windows. Even if you don't do it during the build it could be a DIY job later. Of course, if not part of the build couldn't count on the solar shading for Part O. Adding an overhang on the roof to provide some shading for the upper windows might also be relatively low cost but if you basically have none right now might be difficult with planning. Shrinking the height of the windows upstairs (remove from the bottom) would likely save a lot of cost and reduce heat gain. You'd lose getting sun on your feet as you stand by the window but you could likely lose up to half a metre without substantially reducing the feeling of a big window.
An aside: the German justified fear of the secret police (causing resistance to digitisation, credit cards and strict privacy laws) may be a hindrence to efficiency but I suspect without them the rest of us would be stuck with privacy laws much more in line with the US than we have. I know people think of it as German engineering but I think the reputation is more from having the Mittelstand as a supported and succesful part of the econmy. Lots of smaller companies competing with each other vs a small number of huge companies helps improve overall quality and service. Can always be unlucky though and more recently China seems to be eating their lunch so might be so good going forward.
Nursing a fridge/freezer through these temps
-rick- replied to -rick-'s topic in Kitchen & Household Appliances
Well it's definitely dead. Not really cooling at all at this point. Ordered a new one that's coming tomorrow. Freezer compartment still maintaining some ice though a thermometer says the air is -5C so I predict a day of batch cooking tomorrow -
As long as there wasn't grit left in the refridgerant circuit I think you are right. But with the very rough quality of the unseen bits of this Beko I wouldn't have put it past them to have not done a great job there. You'd hope so, but after I posted 10 mins ago that it's back on, it now appears to be off again and on again so I'm increasingly sure it's dying. Normally not a problem but with these temps I have been doing two ice cube trays a day (though with my shopping yesterday theres no longer room for that). -
Yep, it's a cheapie Beko, bought during COVID when availability was limited. It seemed to start working last night and its contents froze properly. This morning seemed dead again (and it was cooler here). Overnight, I was thinking maybe I was unlucky and just happened to catch the end of a defrost cycle. Waited about an hour and it's come back to life again so maybe just saw another defrost cycle. 4 years isn't long, but I did read at the time that Bekos at the time didn't necessarily last more than 5 years (though they now seem to offer a 10 year parts warranty) -
Its an integrated unit so a right pain to get out (given its full of food). But I've put a borescope back there and it looks almost dust free. -
-rick- posted a topic in Kitchen & Household Appliances
My fridge/freezer seems to be struggling to keep up in these temperatures, especially as it lives in the hottest room of the flat which gets a lot of afternoon sun. Does anyone have any tips on helping it cope? It's an integrated unit, theres a decent amount of space behind it but a limited low level vent to let air into the air space behing the unit (it's fully open at the top). I've removed the grill and stuck a fan blowing air into the hole. Tempted to try an remove the kick plate entirely but last time I did that (elsewhere) the plastic clips broke so resisting the urge in the first instance. Of course it's sods law that I only noticed as I got home with a stuff it to the gills amount of food to put in the freezer! 🫣 -
All in all a good result then with aerobarrier. When I first read your post with results I thought 'not great, not terrible' but given where you started 1.4 is a good result.
Use a wide scraper. Even if it takes off some of the primer you'll save clogging a load of sandpaper.
What type of construction? What were you aiming for (both before + after treatment)? Did they find some obvious oopsies or is the bulk of the improvement from the spray process? Put another way how much work did the spray process do?
Hang on a minute. Are you telling us that you've just finished a true self build of a large property between you and your wife, while doing a full time job AND looking after a 2.5 year old? How??
