nod
    72
Everything posted by nod
  1. nod
    UFH
    Heating nearly down 14 tons of screed ordered for Monday 12 ordered for Tuesday That’s if I can get out of bed Tuesday morning How hard can it be 😁
      • 4
      • Like
  2. I do protected fire escapes as part of my business You would be fine doing that But there’s quite a bite of work involved creating a box that will give you 90 minutes fire protection
  3. We put 63 sheets of insulation down yesterday at £43 per + per sheet I tried everywhere to get it cheaper Even the online seconds where more expensive once you added delivery I settled for a local insulation supplier where I already have an account When we did our previous build 6 years ago There was a fire at the factory in Germany tgat makes the stuff and it doubled overnight It never came back down
  4. I’ve noticed a lot of water around one of the Atlas boxes Time to dig up and have a look Has to be one The most crappiest jobs I’ve done nightmare to get the pipe ends out I’d missed putting a 50p stiffener in one of the pipe ends
  5. It is normal I pointed this out and was told I hadn’t supplied all the information that they hadn’t asked for till I mentioned the eight weeks
  6. The simpler option would be to speak to your neighbor and offer some cash It’s a big job to move everything and your neighbor probably doesn’t want the disruption either
  7. We’ve had two sites held up due to TF companies go into liquidation Both large companies But to be fare There are quite a few companies in general struggling with cash flow I find it outrageous that companies ask for all the money before they arive on site
  8. But there not a good as solid built Certainly not worth the extra cost 😁
  9. Great advise TF companies are going bust on a weekly basis
  10. 150
  11. Manufacturers tend to do this with instructions in case a five year old is reading them Base prep will be the same as your builders always do Full bed of mortar and don’t hit the to hard is common sense SBR slurry should be painted on to the back of anything that’s laid on to mortar Sealing them is very important They should be dry and clean Perhaps worth doing this yourself a day or two before Fill a bucket and wipe both side with a sponge 🧽 Let them dry then repeat Limestone will bleed through if not sealed correctly We have a flat tray that we part fill and lie the slab or tile in for a few seconds
  12. Yes it’s curled behind the up stand In any case it’s all below dpc There will be an apron of dpc around the perimeter taped to the high load damp course Then two more membranes No chance of anything coming through
  13. Nothing above the upstands Last time I just ran the tile matting over them and tiled on top
  14. Just thought I’d post this as it crops up as a question regularly I knocked the block work out around the five openings today
  15. I think it’s the other way round Plaster holding the arcs off Or have I misread
  16. Another option is to cut your arcs to size and pencil line round them Trim the excess back This works up to 5 mil But any more than that you would be better following Tony’s advise and put a deeper lining in
  17. nod
    Heat Pumps
    Exactly what I thought
  18. Corse thread for timber Fine for metal 👍
  19. Presuming timber 35 for walls 45s for ceilings For MF 25s
  20. Bit confusing none of the younger ones call it scrim Use what you have pictured on everything
  21. It’s all the same regardless of colour Scrim is what was use prior to fibre tape The name just stuck No pun intended 😁
  22. nod
    Heat Pumps
    A locally company came out to quote for a HP 12 kw Mitsubishi and cylinder 12k Less the 5 k grant I wonder what they would charge if there was no grant My mate who is an heating engineer reckons if he installed it with me there would be a lot of change out of the 7k and warranty implications also Any thoughts
  23. Mapei waterproof Flexi grout Is what I always use
  24. nod
    Stairs
    Go directly onto the screed for anything other than tiles
