Everything posted by Tony C
Hi, Can I ask self-builders what U-value you went for for Floor/Roof/Wall ? Is it worth spending more money on insulation to achieve better U- value than Building reg spec to save some heating cost (and of course good ecologically)? I am going with UFH and it is a single story detached house with plenty of outside walls, it would be great if someone could quote the example result on heating bill, house size and U-value combo.
Yes, it is expensive for the connection less than 1 m away. But not much we could do.... We thought about installing the supply where it will be going in the end, but logistic wise it was not possible. (The GPR would be on the access way, as we are building one house on the street front, one more house on the back of the site.)
Hi, we have just installed temp builder supply with DNO UK power networks for the first step of our build! This is how it went and the cost explained. 1.UK power networks cost - £2257 to bring the electricity from the pavement. 2. DIY digging - breaking up the concrete with Hilti 1000 (bought from ebay £350, planning to sell again after the build). Hiring the generator to power Hilti £48. Digging the trench 600mm deep. 3. Made box for casting the concrete base - using cheap pine floor boards from selco. Place the pipe (supplied by DNO) for the connection (right), also the short pipe (left) so we can place the earthing rod through to the ground. Pore the concrete mix (ready mix type, 3 bags) and waited a day to set. Material for above £38 from selco. 4. Screwed down the GRP box bought from ebay (£320 + VAT, but we could sell this on ebay for £180, so the real cost would be £160) UK network specify larger GRP box than this, but they confirmed that this size (W750xD450xH1250) is fine. 5. DNO came and installed the power cable though. They came 3 times - day1= digging only. day2= make connection, day3= filling back and make concrete surface (including our side as well, kindly) 6. We got SSE to install the meter (free), and electrician to install the consumer box and a socket. (installation £250) Toolstation - MK consumer box £58, double socket £12 Screwfix – eatrhing rod £2.50 Screwfix - Earth Rod to Lug Clamp 3/8" £1.80 We have put large MK consumer unit as this will be moved to the house once it built. I would not recommend SSE, as they did not turn up twice and wasted our time...! They are now installing 2nd Gen smart meter, which is much better than 1st one, you can move supplier and smart meter would work with the new supplier.
If you are after the slimline sliding door, try the Spanish company Cortizo. The sliding door system called Cortizo cor vision looked good on architect's house I visited. https://www.cortizo.com/en/sistemas/ver/55/cor-vision-sliding.html I have been quoted recently £450 per sq m (+VAT) from https://doors-direct.co.uk/
https://www.idealo.de/ good price comparison site in Germany. I am looking into buying from this place. https://ssd-armaturenshop.de Does anyone has any experience with them?
I had quotation to fit 14 no. of sprinklers to 120m2 house in 2016. The price from this firm was £3k. www.nationwidefiresprinklers.co.uk Btw this price is for assuming your main water pipe has enough pressure. It will cost more to include tank + booster system to increase the pressure. They recommended to install 50mm main pipe if you are in the position of installing new main water supply. I think the mist system considerably cost more. If you are installing only one mist in one room to solve the fire regulation, it will make sense, as it will cost £2k per mist head.
You can seek some advise on this gardenlaw forum : https://www.gardenlaw.co.uk/phpBB2/viewforum.php?f=8&sid=7dae257514e863b42909b2a6bcf2adad Right of way which is established on the deeds won't to be extinguished even if it is not used for long time. So your neighbor will be obligated to re-open the right of way access. But as other people will point out, how to negotiate with your neighbor is the another question!
Hi, just called HMRC this morning regard to VAT refund and CGT. Our case description : building two - one for ourselves to live in, the other for rent. HMRC response to VAT refund on self-build - they said it is fine to claim VAT refund on the self-build house, even if two houses are built together. HMRC response to CGT - CGT will be only applied to the house for rent, not applied to self-build house. I am planning to write to HMRC and get response in writing.
Thank you for your post, it is very useful as I also got PP for 2 house, which one of the house I intend to live in. Most likely that 2 houses will be build sequentially. CIL - zero on our self build house , there is a CIL chage on the 2nd house. LA confirmed that is fine. VAT reclaim - Does this mean that I can not claim VAT on self build house? Oh no! CGT - I was not aware this too... !
Building Control - Private Company and Local Authority
Tony C replied to Tony C's topic in Building Regulations
Its for 2 houses, but still expensive... -
It would be £2.5k saving. I have to talk to my architect as they have to do extra work over the Full plan stage with LA building control. -
Tony C posted a topic in Building Regulations
We have opted for Private building control, as the layout of the house has complication over the fire regulation. But we are thinking to switch over to Local Authority building control to save money. So effectively the Private building control take care the Full Plans stage , and Local Authority building control take care the Inspection Inspection stage. Has anyone done this before? Any thoughts? -
Our RiBA architect charges 15% for all the stage 1-7. I think it is pretty normal for well established London Practice. I know it is costing so much, but hopefully it adds some value when it comes to sell some day.
- 2 replies
- architects journal
- architect fee
- (and 2 more)
Sorry for the delay, https://www.3dhubs.com/ the website you can compare the 3d printing prices.
Its for 10m borehole drilling, 7 trial pit digging (currently 4inch concrete surface), and chemical test, and reporting.
Update: SE was originally thinking to go for piled foundation (expensive!), then opted for the trench fill foundation. So the final spec for the SE changed to : 1 x 10m bore hole , and 7 trial pits (examining existing foundations) and associated soil chemical tests and report. We had quotes from SI company which varied 4-7k for this, and in the end I went for someone MikeSharp01 recommended. Thanks Mike!
I was planning the electric moved from temp builders supply to new house with UKpower network. It sounds like the VAT will be charged then....
If you image search on google "kingspan timber frame" , you will get some section images of Timber frame and cladding (are you cladding with timber? or metal sheet?). I am building Timber frame + corrugated metal sheeting with an architect, but they have not done details drawings yet...
Hello, my husband used the service for making knobs for the music equipment. I think the different plastic available - some softer, some more brittle. You just send 3d file and then get printed. I think its good idea to make one to test it then print lots. I can ask him which website he used.
It seems to be always the big unknown is to do with a groundwork....! Our build will start this year and planning to have a 25m2 basement. How large is your basement? Is there any chance you can share a bit more breakdown of the ground work cost? There might be some lesson to learn. Big thanks in advance. It might save some cost to have Ikea kitchen unit with custom design doors. https://www.reformcph.com/en/ https://www.nakeddoors.com/ikea https://superfront.com/uk/
Extractors: Gaggenau vs Bora vs Miele
Tony C replied to curly's topic in Kitchen & Household Appliances
Teppanyaki? I used to live in Japan, and people there would use something like this on their dining table. https://www.amazon.co.uk/Electric-Teppanyaki-Griddle-Camping-Festival/dp/B00W0CVSAM Friend of mine managed to buy Boffi kitchen with all the Gaggenau appliances with good discount, I think it was ex-display.- 39 replies
Best simple ideas and concepts to design in to new build
Tony C replied to albert's topic in New House & Self Build Design
I was thinking 2 washing machines side by side (white and colour wash at the same time), but have not thought about 2 dishwashers, how CLEVER!
