Square Feet
    1
Square Feet last won the day on December 13 2023
Square Feet had the most liked content!
1 Follower
Personal Information
  • Location
    Southern Scotland
3867 profile views
Square Feet's Achievements
Regular Member
Regular Member (4/5)
128
  1. I am meeting Gus Potter of this parish (SE) on Monday and that will be amongst the topics of conversation.
  2. I'm hoping to make my insulated slab entirely myself using sheet materials so I would say No 3 and bash on.
  3. Square Feet
    Form factor
    Nope, cos that would make it a bungalow *shudders*
  4. Square Feet
    Form factor
    Thanks @JohnMo that's really helpful. I'm thinking mine will be around 110sqm with a lean to of around 9sqm for the plant room/mudroom/porch. There'll be 2 good doubles and a study/small 3rd bedroom. I think that'll be enough for me. Good info re the insulation, thanks. Yes, I'm planning on having most of it vaulted.
  5. Square Feet
    Form factor
    Hi @ProDave Thanks for your comment. Yes I did look at your build and others of a similar roofline too but if I'm completely honest I just don't like them. As I said I am also very tight on finances and taking the upper floor away will be the compromise that is needed to ensure this house gets built, finished and ticks all my comfort boxes. I've seen so many episodes of Grand Designs where people say 'I've got £150k to build a house' and end up spending £300k with a massive mortgage they have to work into their old age to service. A lot of the floorplan of my current flat is taken up with gear for hobbies etc that will live in the garage in my new house, so I can afford to go a bit smaller without it feeling cramped. I read a comment you made somewhere on here a while ago about how you built your first home as a 5 bed and then realised you didn't actually need one that big so built another smaller one down the road. To avoid following the path of building something bigger than I need and then having to go through it all again to get what I actually need I am just going to build smaller from the start. I really like a lot of single storey houses - here's a few examples...
  6. Square Feet
    Form factor
    This month I've been working to figure out the form factor of the house I will build. The options were: 2 storey 1.5 storey with dormers 1.5 storey with Veluxes 1.5 storey with mezzanine 1 storey with vaulted ceiling 1 storey with flat ceiling Local planning vernacular is for 1.5 storey with dormers, which I really don't want to build. The dormers are expensive to construct, feel pokey inside and are tricky to detail for airtightness and heat loss. They will also cause issues with solar panel layout and shading. Looking at the topographic survey, it is clear that I am never going to get permission to build a 2 storey building. The massing is just too great on an elevated plot like mine. I played around for quite a while with the 1.5 storey + Veluxes option, but I think if I am completely honest even that is going to stretch me too far financially. Ultimately I have settled on a single storey with vaulted ceiling. I've seen a lot of examples of this which I have found myself really drawn to. They feel spacious inside and should solve a lot of the issues (such as ceiling height) which I was trying to solve with other styles of building. Advantages of single storey I can have a 2 or 3 bedroom house instead of feeling forced into a 4 bed by the ground floor footprint. As I want a downstairs bedroom and bathroom for 'future proofing', the floorplan inevitably leads to 3 beds upstairs - far more than I need at my time of life. There is more roof on single a storey building. Whist this means poorer form factor for passive qualities and more roof material it is balanced by more solar being possible. No upper floor to pay for - saves on ceiling boards and flooring, posijoists, staircase etc. Less glazing to pay for. Less scaffolding - it should be easier to construct a building with a lower ridge height. More even heat throughout from UFH. Less bathrooms and one or two less bedrooms all saves money. Less plumbing cost, less electric costs, less MHRV ducting costs, less doors, skirting, walls etc. Less visual impact with a lower ridgeline. I can get a spacious, airy house without needing a lot of wall height in the ground floor - this should save on materials. It might be easier to tailor the roof angle to optimise for solar gain. I can argue for planning that this building is better for future-proofing as I get older. A smaller, more modest house suits the ethos of 'just enough'. I don't need a McMansion and I can't afford to saddle myself with something I can't afford to live in. I would rather have more disposable income every month to enjoy life with. My finances are very tight and I need to be realistic that costs will inevitably rise during construction. The best example of a single storey, 'just enough' house that I have found is Old Holloway in Herefordshire. It is passive certified, 3 bed, 99sqm internal footprint and built with straw-filled panels. It cost £135k (after VAT refund) to construct in 2017/18. Using Old Holloway as a starting point for the design shows that passive can be attained using this form-factor. The Old Holloway blog contains a wealth of data regarding solar generation, heating, cooling, and heat demand which will take a lot of the guesswork out. I don't want to build that exact house, but it's a good place to start from. I feel pretty good about this decision. It's taken a lot of the financial stress away that was nagging away in the back of my mind. Just please don't ever call my cool, funky house a bungalow - it won't be - bungalows have flat ceilings.
  7. Great, thanks. That makes sense.
  8. Not me, but just in case you haven't seen it.....
  9. This looks like a painting on the wall. I thought this was a modern take on Constable's Haywain when I first saw it.
  10. It's looking great. The shower room looks very smart. Can I ask what might be a daft question - why do you need to tape and fill the boards so carefully if they are getting plastered later? Is it an airtightness thing?
  11. Maybe that's why I reacted so badly to this one. I remember getting stung inside my nostril a few years ago whilst cycling and it was a sore one but not that bad. I was thinking maybe this time was worse cos I was already awash with histamine from the barley stubble I'd been walking through all day (I'm not allergic to many things, but barley is one) and the numerous nettle stings I'd picked up at the fencelines. I probably couldn't have picked a worse day to wear shorts.
  12. Ok thanks. I guess I am not so much worried about damage as attracting the little buggers. It's been years since I was stung and I seem to react badly now.
  13. Last week I was stung on the hand by a wasp, which made it swell up like a balloon. It wasn't a lot of fun. It must have been stripping wood from a fencepost that I put my hand on to help me lever myself over the fence. It got me thinking about timber cladding - do they chew that as well? I know their nests are basically wood-mache - I've watched them stripping wood from an old outdoor table before. The last thing I want is to construct a large wasp buffet box. The types of wood cladding I am looking at are Scottish larch or that Japanese method of burning wood (shou sugi ban) to preserve it. If I use larch I would seal it as I don't like it when it goes all grey. I'd use something like Ronseal clear wood preserver rather than something naff like varnish though. Anyone got any experience of this? I am not asking re cavity closing mesh etc - just wasps chewing the external cladding.
  14. Looking very good. Thanks for the info re the tape.
