PhilT
Everything posted by PhilT
13 hours mid rate tariff = standard rate, 8 hours at half price, 3 hours at 1.5 times, so it's a no brainer, even without a battery or any scheduling.
Mine does that in the earliest part of the heating season Sep/Oct - it shouldn't be doing that during the last 3 days - In/Out flow temp should be more or less constant, apart from the occasional defrost:
I take it you mean 55kWh PER DAY (= 385kWh/week)? That sounds about right compared to 180kWh/week during the first half of November, which was around 10degC warmer. My usage has also more than doubled over the last 3 days compared to the first half of Nov.
Some basic HP questions for those in the know
PhilT replied to Gordo's topic in Air Source Heat Pumps (ASHP)
Yes to both, it depends on how much you enjoy the tech involvement. I paid extra for a smart thermostat so I can set to auto adapt, which incorporates load compensation, to take care of everything for me in the most efficient way possible, but I have rads, it's an unknown quantity with UFH. Others prefer managing the tech to achieve a "Goldilocks" WC setting. Either system can be made to work well. -
What does this +5 do to water law, Samsung ashp
PhilT replied to Andeh's topic in Air Source Heat Pumps (ASHP)
Ah yes of course. I must admit I was doing a lot of this until the temps dropped below zero then I gave up. Especially when I saw the power spikes after several hours off, even with adaptive, which is a lot gentler than straight WC -
Could you please clarify what this is saying exactly? -
I have Cosy but in these cold temps I'm running mine 24 hours a day at a very steady 20 room temp. I still get 8 hours at half price. The extra cost of the 3 hours 4pm to 7pm is partly offset by the better efficiency of constant running and the comfort of constant warmth and not having to worry or fiddle about with the controls and timer -
If your Water Law (WC) with no adjustment was, for example, set as:- Outside 15>>>>>>>>>>>>>>>>> -2 deg C Flow 35>>>>>>>>>>>>>>>>>50 deg C your adjustment of +5 to the flow temp takes effect across the whole range, so the Water Law becomes:- Outside 15>>>>>>>>>>>>>>>>> -2 deg C Flow 40>>>>>>>>>>>>>>>>>55 deg C so either you should be feeling a lot warmer, or your room stat cuts the heating sooner, or both. -
Vaillant ASHP Subpar CoP Investigation Help.
PhilT replied to suspicious_squirrel's topic in Air Source Heat Pumps (ASHP)
Yes this might happen the first time but that's why it's called "adaptive" - the idea being to leave it for however long it takes (a few days, a week maybe) in a steady state at your chosen room temperature setting, so it can "learn" from the micro-incremental temperature changes how your room temperature reacts to your flow temperature, with reference to your target room temp. If, the first time, the flow temp climbs too fast, the next time it will choose a more gradual increase in the flow temp, and repeat this "learning" until the flow temp behaviour achieves a steady state vs. your room temp target. Then if the sun is shining through your window it will reduce the flow temp further according to the higher rate of room temp increase. -
that's precisely why adaptive is more efficient -
Are you able to activate? This mode is designed to operate the compressor in the most efficient way possible given flow, outdoor and indoor temps. -
could i use my existing UDHWC with proposed heat pump?
-18degC that's what the met office weather record is for Northern Ireland -
Neither can be justified on purely financial grounds if you have any kind of export and off peak tariff. It costs me 4p/kWh (12p/COP of 3) to heat my DHW. I get 15p/kWh credit for excess solar exported so it would cost me 15p/kWh to heat my DHW if I used a diverter, not to mention the up front cost. The up front commercial cost of a battery just takes too long to pay back, but do the spreadsheet to satisfy yourself that is the case. -
That would be risky in an area which gets as low as -11°C to -18°C. The heating would be off for much of the time during lots of defrost cycles and while the heat pump struggles to get your hot water up to temperature. You talk of "payback" but what value do you put on comfort, convenience and lack of worry? -
Nibe (or any heat pump) water scheduling
PhilT replied to SBMS's topic in Air Source Heat Pumps (ASHP)
Or maybe there's a forum member who can help if nearby, in which area are you? -
There are also 2 of us and the domestic hot water takes 30 minutes each day to heat up for everything we need, that's it. I don't think you have a problem. -
21kW ??? You could try one of these in each room! https://www.hotspotenergy.com/DC-air-conditioner/#:~:text=An all-DC system means,for many years without maintenance.
Mini Store - Heat Geek / Newark Cylinders for ASHP
PhilT replied to Nick Laslett's topic in Air Source Heat Pumps (ASHP)
I would also very much like to get rid of ghastly tank in loft. I have a heat pump but the 2nd video in the original post specifically refers to a gas boiler application at 09:00 -
Banning R32 seems like a sledgehammer to crack a nut, because there are well established processes to recover the miniscule amounts of refrigerant. I worry that it will screw the already fragile UK heat pump market unless the site location regs for R290 are relaxed.
The base Cosy calc at the moment uses the % hour split but it matters not - it's just another scenario. Interesting to play around with the numbers
Cosy 2 is a no brainer for me, at least for the room heating months anyway. I used Cosy 1 when it was launched but that extra 22:00-00:00 low rate makes a useful difference. Re the spreadsheet I reckon I will still export around 50% of my solar, without the battery, at 15p/kWh, but obviously most of that will be in the summer months.
One other thing I just noticed is that Cosy cheap rate hours I think are 8, not 7? Definitely useful as a directional steer, obviously you can debate the assumptions till the cows come home but that's where the "modelling" bit comes in based on your own particular circumstances. O
Ah, VisiCalc, the first commercial spreadsheet. I used it on an Apple IIe. Cue jokes about 5" floppy drives.
Good effort. Cosy "normal" rate = 25.81
Take a lot of time and care in working out the justification for a battery. With no export it is marginal at best so why go through all the hassle to install a potential fire bomb in your house. With export I would say impossible to justify on purely financial grounds. If someone has a spreadsheet which proves otherwise, more than happy to concede
