Everything posted by Roger440
Largest outbuilding possible with planning permission?
Roger440 replied to optimystery's topic in Planning Permission
30sqm has nothing to do with it. The 50% of garden does. You are confusing two entirely seperate subjects. You can build right up to the boundary if you want, though that does invoke a 2.5m height limit as opposed to 4. Its all in the link posted earlier. The reason most stuff is under 30sqm is to avoid the need to get tangled up in buiding control and the large increase in costs that invariably follow. I say again. planning and building control are disctinctly seperate things. -
You apppear to be fixated on 30sqm. This has NOTHING to do with planning. This is for building regilations approval. Planning is entirely seperate. Providing you stay within the permitted development rules (someone else posted the link), no planning is required at all. But building regs is aplicable over 30sqm. Undersaand the 2 are not related in any way. -
Jeeeez, what is all that for!!!!?!!
My apprenticeship was bloody fantastic. Simply nothing like it available to someone leaving schiool today.
Thats an issue too. But being skilled doesnt necessarily mean you take pride in your work. Its clear many dont. In some respects thats worse. Ie, you know how to do it properly, but you just cant be bothered, as opposed to being so ignorant of the task, you dont know you are doing it wrong.
No qualifications are required to work on motor vehicles. Literally, anyone can have a go. And do. Motor trade is just as bad as building. I should know!
The level of "tech" involved in modern building methods left most builders behind a long time ago Espically the concept of insulation. That appears to be a complete mystery.
Its why, for almost everything, i just do it myself now. Its easier and less stessfull Cant even be worrying about building control anymore. That hopeless too. I can do it right and have no cert, or i can have it done wrong, but get a cert. Lots to do at the new place. Will continue on a DIY basis on almost everything. The lack of pride in your work is the real issue. No one cares anymore. A sad state of affairs.
Missing insulation in vaulted ceiling
Roger440 replied to d87francis's topic in Lofts, Dormers & Loft Conversions
Where does it say they do? Nowhere is the answer. They can, and do, sign off stuff without seeing it. If they werent, that makes it even worse, ie they have inspected a non compliant job, and STILL signed it off. (my garage foundation prep was done by photos. No inspection took place) Indeed, under the new system, alledgedly to stop developrs only having the first house inspected, they now have to submit photos to the BCO. Why do you think that would be. Either way, lots of new build and additions to existing houses gets signed off when its blatently non compliant. (see OP's house (and thousands of others) So, you would agree, they either didnt look at it, or they signed it off knowing it to be non compliant. And there nothing the homeowner can do about it. -
For what? -
They dont need to carry out ANY inspections if they dont want to. They can (and obviously in some cases do) sign it all off from the comfort of their armchair. As the OP is finding out, out in the real world, there is no recourse against BCO failings, be it private or LA. Which as i said before, renders it completely pointless. So the summary is, no recourse through bco, and most builders just dont care. If they did, they wouldnt do acrap job in the first place. Someone else will buy the house. No need to worry about your reputation when its already in the gutter. -
More independant, probably. But equally useless. See my previous posts. -
Stick with what you have. Aside from oil, its the cheapest option in your situation.
It will never happen, because it physically impossible to do. There are not enough BCO's. Given the woeful standard of the people building said estates, you would need as many BCO's as people doing actual work. It cant happen, and wont happen. As long as there are private BCO's it definitely cant happen. And there is zero possibility of the council taking up the slack. Mind you, they are just as bad. They signed off the extension and associated works on my last place. 2 increased size houses plus rainwater were all feeding a pre exsisting cesspit. Which had a hole punched in the side to let the water out. All signed off by the council BCO. Fortunately we picked this up on the suevey, negotiated accordingly and replaced with compliant treatment plant. Mind you, the same guy turned up to sign that off. Tried to give me a lecture on the discharge pipe not having concrete round it at the end. I pointed out it was lot better than the last installation he signed off. He was gone sharpish, sign off came in the post a few days later. As before, system is broken and pointless. -
As i understand it, for england and wales, they only to need to inspect the first of any specific design. So if 4 designs on the development, 4 houses get inspected. Rest are self certify. I understand that loop hole is, or is about to be closed. They will now have to submit photos of each house. No scope for fiddling that at all !!!! -
Never going to happen is it. At best, all you can hope for is that insulation is there. No one is going to check that its all sealed up and air cant get behind it. No BCO is ever going to do that. The builders know that, and the above is the result. And good luck with finding a builder that even grasps that basic concept. Only today a video popped up on facebook, of a builder doing a short tutorial video on wall construction, cavity with PIR boards. Made a point about saying you need to tape the joints, whilst clearly showing significant gaps between the boards just taped over! The system of building regs is broken and utterly pointless. -
Id love to see what they consist of. Being at gradute level wasnt really what i meant, nor did myself. There was bugger all chance of me achieving A level maths, barely managed O level. So by that, id have been excluded and consigned to the scrapheap from day 1. Fortunately for me, the country had not reached that level of daft at the time i was in school.
Its one of mine too! The good news is, out in the real world, the penny is starting to drop. Plenty of youngsters doing degrees coming out of university, saddled with debt and unable to find a worthwhile job. While there school mates are a few years ahead, earning good money and have no debt because they chose to lean a skill. In a lot of cases those with debt and later into the jobs market will never recover that gap. Thats not going unnoticed for them However, nothing changed that i can see in the mantra, "degree is good" everything else is bad message from government and education types. Thats before we consider the diminished vale of a degree as a consequence of the past 20 years or so. It was so obvious what has happened would happen. But it seems those making the rules seem to be totally incapable of imagning he effects of the changes they make. I dont know why, because its not hard. Which brings us back on track, because Jamespa doesnt seem to be able to grasp the motivation element that inevitably going to be required for the various paties involved with his proposals. As a wise person said to me a long time ago, people will respond to the motivations they recieve, motivate people to do the wrong thing, and they will do just that. Low profit/ high risk jobs will not motivate the kind of people you need. Ie, competent people with real long term businesses with reputations. Protest to the contrary are just deluding oneself.
The message is, if you are going to do practical work you are a failure. It was when i was at school in the 80's, and its much worse now once Blair got the whole "you must have a degree" bandwagon rolling. The single best thing i ever did was ignore everyone and get a proper apprenticship. Sadly, even now, if you are just coming out of school, where are those proper apprenticeships that give a good engineering grounding. I dont know of any outside the MOD. Just watered down training schemes to get you earning money for the employer double quick. Usually focused on a very narrow range of tasks. Which of course increases the chances of staying tied to the employer. Even if this mindset changed tommorow, it will be 10 years plus before we see the benefit. The message today still is, if you go into a trade, you have failed. And the industry training schemes seem to focus on those that have failed acedemically. Thats why we are where we are, and why the fabled 1.4 million heatpumps wont happen.
Again, you have taken what i said out of contect. Im not arguing we shouldnt install heat pumps because the grid cant keep up. Did i? My position is simple. 1.4 million installs wont happen. You made a statement that it will expand to meet demand, as though this were an inevitable outcome. I think there is significant chance the grid output wont match demand, primarily because the country is run by morons. I believe that enough to have bought a gen set. The two positions are in no way related. I repeat, again, i have no vested interest. I sell car parts. Please stop replying as though i do.
Cant do multiquote so: So you know how hard it is to get a good builders or electrician the?. Because standard are so high there too! Not going to argue the point. You are just wrong. You say you can distinguish between the good and bad trades. Please do put us in the picture how you do that. I think theres a fair few on this forum, never mind the public at large who would love to hear about it? Im not sure why you think im involved in any way or pretecting myself? I dont do plumbing, or heating or anything else on houses. What i do have though, is a lot of expreince to working on relatively complex stuff for retail customers. So when i see some of your ideas, my natural instinct is to think about the consequences. Because the consequencers are what your workforce need to factor is. And do. The bit you are really not getting, is that your "cheap" boiler competative installations put significant risks on to the installer. Where is the motvation for the installer to take on these low cost high risk jobs? Throught this thread, you have not answered this. And unless you do, you wont have your manpower to do the 1.4 million installs. As i said, i dont believe you grasp this element.
