Roger440
    7
Everything posted by Roger440
  1. Given your intended use, i think you would be nuts not to fit a DPM. But then, id be insulating under it too if it was mine and going to the lengths you are.
  2. Are you sure? General rule of thumb for any installer ive come across is 150mm if its reinforced concrete. All the ramps ive had put up, none had, nor specified 200mm. None fell over either. If it really has to be 200, then as suggested thicken in the appropiate area. Going to save a heap of concrete. 200mm is total over kill for something that will only see cars. Ive also installed a 2 poster on 4 inch non re-inforced concrete. But it did have an H frame. Which substantially reduces the floor rerquirements. Have you considered changing ramp supplier?
  3. It made no sense, because you justfied it on financial grounds. Which clearly dont stack up whichever way you look at it.. However, if you are doing it for ideological/ecological reasons, then fair enough. Thats entirely your choice. But you made no mention of that. Had you done so, then the responses would probably have been different. Mine would have been. Ill duck out now.
  4. Still makes no sense. The payback period will be forever. Made worse but borrowing the money to pay for it.
  5. Good link. I love this bit at the end: Alternatively, you could make this a DIY project. Often the best installations are completed by homeowners who have taken time to install materials correctly. The most important skill needed is care and attention to the intricate details. You must also follow the appropriate health and safety measures at all times. We would be pleased to support you with further installation information if DIY is an option for you. If ever there was a vieled reference to crap workmanship by builders, this is it. Still at least they know what actually goes on in the real world.
  6. Why are you actually doing this. With so a low heat load, i struggle to see the logic? As steamy said, what is your actual consumption? But if the boiler is only own for 2 hours, it really cant be very much.
  7. Indeed. So companies owned by "chums" can harvest some more money. I just need to find someone willing to leave all the gear for me to fit, but claim they installed it anyway. Or let them install it, then take it out and do it properly once they have gone, and reconnect my oil boiler as back up.
  8. Are the joists located into the brickwork, or on joist hangers? Im assuming cavity wall? If the former, then you do definetely run the risk of moisture forming at the interface with the cold brickwork which will struggle to evaprate, wool or otherwise If on joist hangers, you may still have the problem. Obviously you could pay someone to do a proper analysis, but my take is that it is a high risk solution. Its examples like this that just demonstrate the practical difficulties with insulating older housing stock. That you are asking puts you way ahead of the other 99% doing this stuff.
  9. But not on supply only i presume?
  10. I intend to do do exactly that. But thats because i have a resonable level of understanding. Were i an uninformed average customer, that wouldnt happen. They would get to pay twice. Ref oil cost, i dont think it will. Certainly not anytime soon. They either have to increase oil prices or decrease electricity. The latter clearly isnt going to happen. Will be a brave government who choose to increase, artifically, heating oil given the usage profile and low number of affected household. Worst case is, its the same price as road disel. If it was higher even, than that, id just use road diesel or red disel if that still exsists by then instead. As will most people pushed that far. Which at current prices would be circa 16p per kwh. So even if it does get to that, the difference wont pay for itself in my likely lifetime. Ill probably be dead before then. Of course, they may forcibly install one, as the new legislation gives them the right to do. Not much i can do about that.
  11. Well im glad im not the only one that completely confused as to what the OP is asking!
  12. Its an oil boiler, not a combi. When the power goes off, i go outside, pull the main fuse, and start the generator. Problem fixed. Would be better with a battery, but that rather less straight forward, see previous post.
  13. This^^^. I think, especially on here, this is lost. ANYTHING that isnt a case of selecting the desired temp, is going to get a bad reputation. Im a pretty practical kind of guy, and pretty much do everything myself. But i read stuff on here regarding heat pumps and related stuff like solar and batteries, and to be honest, struggle to make sense of it. And im WAY more advanced that the average person, who just wants a heating system. Aside from my cynicism about targets, likely cut off dates and all the other guff, the sheer complexity of any "new" system, in particular getting it specified and set up, simply steers me to keep my oil boiler long term, even though i will be doing a fairly major amount of work on a rather old house including ignificant reconfiguration of heating. The idea of paying, the frankly bonkers numbers to have a HP system installed rules that out. And they will still be more expensive to run than oil. Granted of course that may change a bit.
  14. This^^^. I think, especially on here, this is lost. ANYTHING that isnt a case of selecting the desired temp, is going to get a bad reputation. Im a pretty practical kind of guy, and pretty much do everything myself. But i read stuff on here regarding heat pumps and related stuff like solar and batteries, and to be honest, struggle to make sense of it. And im WAY more advanced that the average person, who just wants a heating system. Aside from my cynicism about targets, likely cut off dates and all the other guff, the sheer complexity of any "new" system, in particular getting it specified and set up, simply steers me to keep my oil boiler long term, even though i will be doing a fairly major amount of work on a rather old house including ignificant reconfiguration of heating. The idea of paying, the frankly bonkers numbers to have a HP system installed rules that out. And they will still be more expensive to run than oil. Granted of course that may change a bit.
  15. Because it works, and to all intents, lasts a lifetime. I wouldnt entertain anything else.
  16. All that will happen is the installers will do a worse job. Because if it costs a fortune to run, who cares? No comeback. All paid for by someone else (us) Harvest the subsidy and run for the hills. I dont think your idea is grounded in reality. The wheels will come off heat pump installation as soon as the first blackouts occur. Surely, only a matter of time?
  17. It's not even cheap compared to where I was in bucks. Cheaper, yes, but not enough if a difference to be relevant. Hence gave up and went to Wales. Just wondered what had changed planning policy as pre COVID it was something they were encouraging.
  18. Do you know why. When I was looking for something with a big shed I saw quite a few. It's a nonsense really. Surely working and living in the same place is the most environmentally sound approach? No need to travel. But just more evidence it's about the money, not the environment.
  19. Late to this, but at that age, it definitely shouldnt have solid walls. There must be a cavity?
  20. Worcester have already announced had they plan to spread that 3k accross everything they sell. I think smeone posted there press release on here. The jist was, there insufficent demand for heat pumps to make a credible business. Sounds like a another bunch of reasons that will stop anything other than a full priced (overpriced) tax payer funded bodge job. Ie, no DIY. Because it cant be "verified" as a qualifying installation. Indeed, i suspect, and logically it must, lead to heat pumps only being available to professionals who can produce the necessary paperwork to back it up. Maybe im too cynical???? Looks like another oil boiler for me......................................... Edited to add, they are not going to break the price link. Way to much money being made.
  21. Sadly, thats not been installed with any thought to insulating. Many are too clodse together. If you are expecting the plumber to do it, i fear you will be disappointed. Id be very surprised if there werent gaps all over the place. Rather defeating the point. Bit like builders do with insulation...............................
  22. Not in the south east they dont. Bugger all chance of that. That concept seems limited to the rather less economically well off areas, like cornwall. Where, it seems to be a thing.
  23. Correct. I built a 70sqm garage without planning. Dont even think about planning for extraction. Dont give the council a sniff of your plans. Wont happen in a domestic setting. For my paining i put a filter on the outlet so there is zero overspray. If you need to eliminate the smell, add a charcol filter to the output. Not cheap, but, trust me, much better than what will happen if you go down the planning route. Tell nobody anything.
