Sticking Aerogel to steel
SteamyTea replied to Great_scot_selfbuild's topic in General Construction Issues
Is it worth it, the k-value is not much better than PIR. Spacetherm is not real aerogel, it is, as far as I know, fumed silica in a blanket. -
Lumberjack -
Usually, polymer manufactures keep to what they know. The properties are probably very similar to the paints in the rest of their range. The three things most likely to change are the surface tension additive, the pigment/dye and the etching agent additive. The rest will be the same. Buy a pot and give it a go.
Bathroom Poltergeist or another issue?
SteamyTea replied to canalsiderenovation's topic in Electrics - Kitchen & Bathroom
Voodoo -
You need to consider your vapour control layer (VCL) at this stage.
Better off getting an air blower to test for leaks as you go along. You can make one with a large fan and a manometer. A simple IR thermometer will tell you most of what you need to know about cold bridges.
Expensive for sure …. Glass ….
SteamyTea replied to Pocster's topic in General Self Build & DIY Discussion
It's the webbed feet. -
Women with stilettos on it. -
Even a bit of miss sized walk on glazing would not do that. -
Toughened glass often has tiny impurities in it. These set up a stress raiser. Then they can just shatter with seemingly not reason. I had sold my car, went out in it the day before the guy was to pick it up. Driving down an empty road the windscreen shattered. Cost me 50 quid. I should have stayed in. -
Do I really need to use treated timeber for framing
SteamyTea replied to ricardo100671's topic in Garages & Workshops
Made hundreds. What timbers (note plural) are you intending to use? White Pine or Teal where our choices for panel saunas and Abachi for the benches. (I have a sauna controller cluttering up the place still, been in a box for over 30 years) -
I used to have the same taps. As other have said. Small screwdriver to get the cap off, you need to push it into the plastic ring a bit. The, you need a Phillips screwdriver, not a Posidrive to undo the screw. Wiggle the knob off, this can be quite difficult as it can a bit corroded. Then you can get to the cartridge with a spanner. I changed all mine to quarter turn cartridges with lever taps. This was because my one armed lodger had trouble holding a kettle and turning a tap.
Europe’s heatwave is the hottest and most humid ever
SteamyTea replied to SteamyTea's topic in Boffin's Corner
A bit about A/C in hot weather. https://www.bbc.co.uk/sounds/play/m002yc9y -
Can home batteries help save the climate and save you money?
Most do, just does not get reported that often. -
Can home batteries help save the climate and save you money? Growing numbers of homeowners are installing batteries that store electricity when it is cheap, which helps balance the grid and cuts emissions, and cheaper plug-in batteries will soon let more people do the same By Alec Luhn 25 June 2026 Home batteries can charge up when electricity is cheap and sell energy back to the grid at peak times Mischa Keijser/Westend61/Getty Images Think of climate solutions in homes and you will probably think of solar panels on the roof. But a suitcase-sized battery in the closet can be a cheaper way to save money and the environment. Although rooftop solar has been expanding, battery storage is now the world’s fastest-growing power technology, according to the International Energy Agency, including home batteries that can power the house and sell leftover energy to the grid. Most of these are paired with rooftop solar, but as energy prices rise, more and more homeowners have been buying just the battery. Now, countries are starting to allow home batteries that can simply be plugged in, rather than professionally installed. “That could be the game changer… that I think suddenly opens it up to a lot more people,” says Iain Staffell at Imperial College London. “Low-cost plug-in batteries could be the next rooftop solar.” More than 40,000 homes and small businesses installed battery systems in the UK last year with or without solar, nearly doubling the record from 2024. Installations of both home solar and battery systems by Octopus Energy doubled from February to March after the Iran war began disrupting energy supplies, and they have remained higher than pre-war levels as Britain’s energy regulator announced it would raise the state cap on energy prices. In the US, home battery installations were up 75 per cent in 2025, even as rooftop solar growth slowed. The technology is also expanding rapidly in places like China and Australia, while in Germany, 1 in 6 homeowners have a home battery, making more than 2 million in total. On a variable tariff, a battery can charge up in the early afternoon or at night, when electricity costs as little as 5 pence per kilowatt-hour in Britain. Then it can power the home when demand peaks from 4 to 7 pm, and a kilowatt-hour can cost 40 pence. Air conditioning and fan use during the current heatwave has driven that price up to nearly 50 pence. While homeowners in the UK currently spend an average of £9400 on a battery system, Octopus’s forthcoming plug-in option will cost less than £300. The size of a shoebox, it will only store 2 kilowatt-hours, enough to run a fridge for one to two days, but it will allow renters to get in on the game once approved for consumer use, which is expected to be in 2027. “You’re going to get return on investment in two to three years,” says Phil Steele at Octopus. “That should make it a no-brainer.” Home batteries also cut greenhouse gas emissions by reducing consumption during peak times, so power companies don’t need to burn as much gas to supplement low-carbon sources of energy. On those windy, sunny, low-demand days when Britain’s grid briefly runs on almost 100 per cent zero-carbon sources, storing energy in a home battery can help the climate even more than generating unneeded energy with home solar. Last year, the UK paid wind farms £379 million to shut down when the grid couldn’t handle that energy, a surplus that could have been partly stored in batteries. If half the homes in Britain had a 5-kilowatt-hour home battery, that would meet the government’s 2030 goal for battery storage, most of which is expected to be delivered by grid-scale batteries. As the average share of solar and wind in the energy generation mix increases, home batteries will be even more crucial to balance the grid and even better for the climate, according to Staffell. “Probably solar is better at the moment, but fast-forward five years, the batteries would be more important then,” he says. However, the manufacturing process could lessen home batteries’ climate benefit, according to Aritra Ghosh at the University of Exeter, UK. There’s also currently no infrastructure to recycle millions of home batteries at the end of their lifespan, which Octopus expects to be at least 12 years. A recent study found that producing a lithium-ion battery emitted about 150 to 200 kilograms of carbon dioxide equivalent per kilowatt-hour of capacity, about as much as driving a petrol car 1000 kilometres. This could be greatly decreased if hubs like China were able to decarbonise heavy industry, but “currently we are not even close to that scenario”, says Ghosh.
I am going to have to get back later as we are opening early, and finishing late today. Something to do with a game. But just to say that reductionism works very well. When the unexpected happens, it is generally found what caused it by reducing the components even more. -
Quite hard to answer that. I suppose critical thinking, and lots of reading about the subject, and the topic authors/institutions is all I can easily suggest at this stage. Yes and no. At the level of climate change, which is based on basic physics i.e. laws of thermodynamics, chemistry, atomic states, there is no need to get too deep into the philosophy. If you can imagine, experiment, observe/measure and test, most of the mystique is removed. No need to confuse it with Latin. -
You really are showing your ignorance now. He was highlighting the difference between real science (physics in his case) and social science, which tries to use scientific terms and techniques to give it credibility, but is not a science, it is opinions. -
I think it does. It was not until my third year that we covered Philosophy of Science, even though we had it drummed into us that the data shows the results, even if you don't like them for the previous 2 years. Those two years were really leading up to how to design and manage good experiments that left little opportunity for error and ambiguity. All the theory, mathematics and statistics, previous research and, sometimes, unrelated topics (for a broader view) were just there to make our lives easier, though it did not seem it at the time. There are bad scientists, but they tend to be caught out early on, and very really get published. The ones that do slip though get caught out later. When it comes to Climate Change Science, the old trope about the planet going into a new Ice Age is usually dragged out from the coffin. What happened there is that rather than a binary, or absolute figure, bring out on an outcome, a number of scenarios are modelled, each scenario has a probability factor attached to it. The extremes, i.e. ice age, 12°C extra warming had very low probabilities, about 2.5% each, of happening. What then happens is that those extremes are highlighted as an example of science being fundamentally corrupt. The people that want to go along with that are called (expletive deleted). -
@Spinny You really do not understand the scientific method do you. Have you thought of going to university and studying it for several years? -
Yes they did, and for very good reasons. Basically India and China are going to burn less coal than original thought. Unlike your opinions, scientist change their minds as new evidence appears.
