What I did, but added about 150mm. Part of the reason I limited my E7 window to the last 3 hours of the period was because I use most of my DHW first thing in the morning. Since changing my cylinder a year ago, I have not got around to fitting any temperatures probes, should have done it at the time as I don't fancy the doing the job now. One thing I have thought of doing is to fit some probes to the header tank, then I can see how much the temperature varies up there. My summer DHW usage is significantly higher than my winter usage, so would be interesting to see if it actually costs more.
Just had a thought while enjoying a hot bath. Heat loss from an off the shelf cylinder can be quite high. I calculated that my losses where at least equivalent to my usage, and sometimes higher. To get around this I added extra insulation. This lowered the losses considerably, as did lowering the storage temperature. Worth considering the size of the cupboard that the cylinder is in, and how easy it would be to add extra insulation. Not to be outdone on the charts, here is May's mean energy usage by hour. I am usually up by 6AM, so water heating is between 1AM and then. I have limited the E7 window so that it now starts at 4AM.
Land for the Many Report
SteamyTea replied to Ferdinand's topic in General Self Build & DIY Discussion
Yes, I have seen what it has done to my best mate (though he asked me for 50 quid the other day, I refused, and not heard from him since). If we legalised drugs, I am sure we would see the same problems that alcohol causes. Legalisation does not mean safe. Most car incidents happen below the speed limit. -
Ah, Matlab, I still feel the cold sweat of university. ST has a few maintenance issues that need to be considered, PV is, generally speaking, either working or not. Also it is much easier to route cables than pipes. You can use a heat pump to raise the temperature of your mains water a few degrees, then for the final push from say 40°C to 55°C use the immersion heater from the PV. As for the best way of doing this, it is difficult to decide. Two cylinders is probably the answer. A lower temp one feeding the higher temp one. As an example, I have a simple, vented, Economy 7 cylinder with a capacity of 200lt. I run it at 50°C. This is generally enough to for 2 showers and a bath per day. I can raise the temperature up to 65°C when I have people to stay. That gives me more capacity without having to turn the secondary 'top' element on. I had a lodger once that was under the assumption that the time to finish a shower was when the water ran cold, left me with a £2000 water bill. I trained her up to take much shorter showers. It worked, she could wash in 3 minutes in the end. Limit the flow of the showers to no more than 9lt/minute. Mine is 11lt/minute and very nice.
Legalise cocaine and tax it, should bring in a few quid and save prison costs. -
Takes away a lot of of OUR problems building this way!!
SteamyTea replied to Pete's topic in New House & Self Build Design
Takes away the H&S issues too. Have they got all their toes and fingers? -
Thanks for letting me join. Just about to begin building my new house.
SteamyTea replied to dnb's topic in Introduce Yourself
IoW is Up North to me as is Plymouth, Exeter and Bude. -
IoW has an OCGT 140MW unit at Cowes, the Gateway to the World. -
Some years ago I looked at the total tax take of the UK, then worked out the percentage we would have to pay if it was only on income tax. I think it worked out at around 65% on every single pound we earn. But goods would be cheaper and we would not have to pay any council tax, road tax, fuel duties etc... And companies would not be able to avoid corporation tax, as there would not be any. -
I remember that Paul in Montreal (from the other place), did not go for a particular good U-Value when he did his refurbishment. He spend his time and money on air tightness. He got good saving on his running costs. I once started a spreadsheet that balanced the losses from air leaks so that they matched U-Value losses. I never got around to putting in cash values, might have to revisit it sometime.
I wish the only tax was on earnings from/in the UK. Then we would have a much simpler and clearer system. It would also get rid of a lot of opportunities to avoid paying. It seems odd to me that some people can claim benefits while working, or not working, while others cannot i.e. me. But it is OK, Boris is sorting it out for us, he want to reduce tax take for the rich again. -
I feel the same. When he has been on Radio 4, he seems to be pushing an agenda of some sort, not really sure what though. I know it is the job of environmentalist, and I include myself in that group, to set a high bar, but it does piss me off when I talk to people in my profession that seem to be fixated on just one or two issues, especially when they think that it will solve all problems. The use of selective data seems to be worse in the environmental industry than in the medical industry. It is a shame as no matter how much I point out the misconceptions, it just does not sink in. -
Welcome As far as renewables go, look at roof integrated PV and ASHPs. Make the big decisions first and the rest falls into place. Purely as an aside, I have no idea what water and sewage costs on the IoW, but if it is similar to Cornwall, you may want to look at a borehole and sewage plant. May work out cheaper after a few years. Avoid any type of combustion for energy generation, even though you have lots of wood. -
Best way to get hot water in summer - gas or electric?
SteamyTea replied to Mr Punter's topic in Boilers & Hot Water Tanks
I use E7 with an additional timer that limits the E7 window to the last 3 hours i.e. 4AM to 7AM. This helps limit standing losses during the night and gives me enough DHW for a day. I use about 3 kWh/day for DHW. So about 30 pence worth. My water and sewage costs me about 50p. -
Better off taxing vehicles on mass rather than peak power, that is real the physics. This is going well off topics. Time to go out in the sun.
What are those problems, every day, the world gets a better place to live in. If we only focus on the big personal disasters, we miss the bigger picture. It is true that we can do things better, but we are slowly working our way towards them. Global infrastructure change does not happen overnight. All my life I have been told by the older generations that the country is going to the dogs. Where are all the dogs (or hand carts, rack and ruin, or other doom monger scenarios).
Does that not include energy prices then. China buys in a lot of coal and gas from Australia and Russia. A lot of other things can be done too, export guarantees, government subsidies, different employment standards, pension payments (good reason to not limit population). If life was as simple as just taxing and subsiding the bad and good, then we would have sorted this back in Roman times. Just not as simple as we like to think.
OSB VCL and foams vs natural materials & moisture open wall
SteamyTea replied to joth's topic in Damp & DPCs
Good old Tom -
No it isn't. The Earth can easily support 3 billion more people. Been shown in so many studies. Not just the cost of energy is it. As an example from the automotive world. Tesla started work on a new Chinese factory back in February. They hope to make cars in it come this December. The UK would not even get a planning decision is that timescale. Plus they have a well educated and skilled workforce.
Do ground mounted systems
Not if the developed world keeps using the up supply of renewable technologies. What you have done there is to look at one metric, CO2/Nation. How about looking at CO2/Land Area, or CO2/GDP, or CO2/Goods Export Value. In a globalised world, something that many do not like apparently, it is wrong to compare at a national level when we buy in the goods they make.
As for the economic arguments, they tend to be way off the mark as people seem to look only at the cash side of it. There are 3 pillars to environmental economics, financial, environmental and social. It is impossible to get they all to balance. Once that is accepted, game theory can be used to get the least worse option. This casts a very large net across the planet. Most people accept that burning coal to generate electricity is not a good thing, and with current technology, probably unnecessary now. But I don't want to be the person, or government, that denies Sub-Sahara Africans an improvement in life because the Developed Nations have nicked all the resources. Climate change, environmental pollution and poverty are a global problem so we have to be equitable about it. It seems odd that we are now, in the UK, trying to use as much of our self generation as possible and whinge that we are not getting paid much for exports. Globally we would be better off paying to install a system in a country that has less restrictions, as it is cheaper to do so, and all the generation would be used all the time. But that isn't going to happen anytime soon.
That is it really. I am no fan of regulations, but they are needed. We can't have a free for all when it comes to installing micro-renewables, the local grid was just not designed to handle it. As an example, when I worked for a PV company, we installed 4 systems in the same street. That attracted the attention of the DNO, who warned us that we may be liable for a transformer upgrade. The odd thing is that if 4 different companies had installed the same system, then the DNO was liable for the upgrade. It is also not, as Jeremy points out, just to do with the electrical safety. There is mechanical safety as well. None of us want PV modules falling off roofs in a storm, or a leaky roof for that matter. There is also a certain need to protect ordinary customers. We tend to be out of the ordinary on here, and some if us are capable and qualified to do an install. But my neighbours aren't, so I don't want them thinking they can jump about on the roof, with a drill, fitting a PV system.
