But it is only using tools and language learnt by 12 to 14 year olds at school. The Learning Style (mine is auditory) has little, if anything to do with it at this level. Claiming it does, is just accepting that failure get a point across is acceptable. "Those that can make you believe absurdities can make you commit atrocities" Volta.
Can you Feng shui my study please?
SteamyTea replied to Adsibob's topic in New House & Self Build Design
I like to look out a window when working. I am a first class daydreamer. https://www.newscientist.com/article/mg23431260-200-how-to-daydream-your-way-to-better-learning-and-concentration/ https://www.newscientist.com/article/mg21428691-900-daydream-your-way-to-creativity/ -
That is a brilliant device. Is it compulsory? We have changeover regulators at work, may see if they do that as well.
My laptop has batteries. In my experience, electrical sockets are never, ever, in the right place. -
If you stick a fridge, freezer, A/C unit in a room, plug it in, switch it on, it will heat the room. It cannot cool the room. So the 'running in reverse' is just wrong. If you replumbed it so the cold part was outside the fridge, and the hot part was inside the fridge, it would still heat the room. What a HP does is draw on an secondary energy source, in the case of an ASHP, external air, a GSHP on moisture in the ground. Then, though the magic of science, or science as I prefer to call it, it captures the higher energy molecules and uses that energy. James Clerk Maxwell had a Daemon opening and closing a door between two compartments in a box. The Daemon did not use any extra energy. When it saw a fast moving, and therefore high energy, particle heading towards the door, it opened it and let it through, if it saw a slow moving particle traveling in the opposite direction, it let that though as well. This had the effect of increasing the temperature on one side, and reducing it on the other. This was a thought experiment to show the limitation of Second Law of Thermodynamics. No one has shown it to work at the 100% efficiency level because of entropy. Now this is all getting quite complicated and hard to explain. So just use PV/T=C and explain it with a bicycle pump, or compressor. As you compress the gas it gets hotter, as you release that compressed gas it gets cooler.
But it is not a scientific description, it is a description said by lay people, to lay people. And wrong. Here is the Scientific description. PV/T = C where: P = Pressure V = Volume T = Temperature in kelvin C = A Constant. The scientific description is shorter, easier to say and more correct. Why complicate things.
can i put a cat flap on an internal door (which is wood and 4 panel)
SteamyTea replied to TryC's topic in Decorating
Selecting DHW cylinder for ASHP + solar thermal
SteamyTea replied to muhrix's topic in Introduce Yourself
And emojis as well- 25 replies
- ashp
- solar thermal
(and 2 more)
He is a brave GasSafe man then.
Are you going to just jigsaw it in place. Video it for us all. -
Move in and shuffle things around until you feel comfortable. I worked in an office where we all had our backs to each other. I put silly pictures on my screen saver, then got told off as it 'lowered the tone of a professional office'. -
Solar PV and Heat pumps - the economics
SteamyTea replied to MYLOUBYLOU's topic in Underfloor Heating
You are not typical though, you try your hardest not to export. How much would you have got if you had exported half your generation. And how much more would that have been if you lived in Cornwall, or East Anglia. -
That is a bit sexiest, there are female gods as well. https://en.wikipedia.org/wiki/List_of_goddesses
Just draw a picture of a person on the foot. The big toe is the head, heel is the feet. Then claim that bruising the tendons is 'breaking down the crystals'. Still, I bedded a blonde by massaging her feet on a first date.
Would a bigger pump compensate for small pipes?
SteamyTea replied to Hogboon's topic in Air Source Heat Pumps (ASHP)
Read this https://www.degreedays.net/ Fairly simple to DIY it all. -
Well don't, because it is a misleading description. It works just like a fridge, except the cold part is 'the outside' and the warm part 'is the back'.
Too true, they think it is a 'religion' and all disciplines are basically the same. Good example of a scientist arguing back on this weeks Now Show. 6 minutes and 8 seconds in.
Why not buy another door of similar design. -
Sadly not, there are a few on here that struggle to understand it. (and yes, I do see the pun)
As long as you show the monthly output in Kw/h. -
I heard, like swimming pools, it is one of the worse things you can have when it comes to selling. -
God I hope not. -
You can always use more hot water, that makes the numbers look better. -
Got visions of a young Barbara Windsor now.
Digital Bath Filler? - Press & forget?
SteamyTea replied to Andeh's topic in Bathrooms, Ensuites & Wetrooms
6bit resolution in your case. 10 for the rest of us.
