SteamyTea
    200
  1. Probably more than 35p/kWh Was chatting to my MCS contact last night, he has just put in a 5 kWh battery system at his own place, cost him £5k. He only did it as he wanted to know more about them.
  2. @Adam2 Just a thought, you don't have underfloor heating in the gym do you?
  3. SteamyTea
    Cabin builds
    Shhh, keep that quiet or the trolls be be along telling you how wrong you are. You going to start heating your water with an EAHP. May be worth looking into as you can heat the house with A2A, at CoP 4, then heat the water with EX at CoP 3. If you remember the old story about the sound cancellation machine by Arthur C Clarke in Tales of the White Hart, you will know what happens.
  4. Especial when close to 50° North. Thankfully it is usually cloudy down here.
  5. If you can find latex sheet in the colour you like, you could glue that onto black mats.
  6. That can't be right. Copper HW cylinders are routinely encased in sprayed-on PUR foam. Silicone sealant is slightly acidic, perhaps your plumber was thinking of that? He could have been thinking about copper pipes going though granite, that corrodes pipes pretty fast. If you got a bit of plastic conduit (LSF) and slit it lengthwise, you could fit it over pipes and cables, maybe even wrap it in self amalgamating tape. Then get happy spirting what you like into the hole.
  7. I just did a search X rubber gym mats where X is the colour. (expletive deleted)ing loads.
  8. Not from large suppliers that offer reliability and flexibility, but small domestic suppliers are probable a pain to them. As well as that, domestic suppliers are often trying thier hardest to not export. The idea of SEG, FiTs and previous schemes (ask @DamonHD what he has) was to help start an industry, not reward purchasers. The UK is currently trying some very complicated and difficult schemes (just look at what Octopus are doing) to understand. This is mainly because we are trying to shoehorn a distributed generation system onto a centralised generation system, and the easy way to do that is to cut usage, not increase generation.
  9. So did the Dutch, a few of the places we lived in had wall carpets, even in the Dutch East Indies (Indonesia).
  10. Read your meter every time you get in, or when you leave, for a few days, see how much energy you are using. There will be 3 readings on it, Total [t], Day [1] and Night [2]. We can probably estimate DHW usage quite well. Does seem like your place is under insulated.
  11. My larger ones does that, 2 to 3°C difference between the centre and edges, when measured on the top of the front face.
  12. They are a bit bigger than my living room one, but about the same input. 3.4 [kW] x 7 [h] = 23.8 kWh If that stored energy is released evenly over the next 17 hours, that is a power output of 1.4 kW, which is not that high. As you have two of them, you will get double that, so 2.8 kW, which is about the same as a 3 kW fan heater would churn out. 36.5m2, so almost as large as my house (which is 48m2 over two floors). As you say, one heater is attached to an outside wall, not the best place for them. I moved mine to the party wall, but never actually bothered to measure the performance difference as I did it as soon as I moved in. They are easy enough to move. As your are in the frozen north, I suspect that they are undersized for a proper cold spell. I had a house in Aylesbury and during one exceptionally cold spell, the gas CH could not get the house warm and I had to get some electric heaters, as did my neighbours. One thing that can happen to SH is that they heat up to maximum before 7AM, then shit down and the output flap reopens (it closes when being charged up). It then starts to heat the rooms up but does not loose enough energy to have to recharge before the E7 window closes. This may mean you are loosing 2 hours of time shift. This can be caused by either a faulty input thermostat, the automatic output flap not responding to the charge period (it is a bimetalic strip that gets separately heated when they SH is charging up), or a stuck open output flap. You can sometimes hear the output flap slam shut (a good thing) but you don't hear them slam open. What I suspect is happening is that they are a bit on the small side for really cold weather, it is what usually happens. Do they work fine come April?
  13. There is enough knowledge and skill on the is site to build a very good house. Just needs organising.
  14. If you want low energy, then it will be a basic, 4 sided box. If you want 'eco' then it will be timber clad with grass on the roof.
  15. 14 quid each. Can I sell you some.
  16. Really down to lack of use. Not many of us need to do basic algebra every day, so we forget the basics, then get confused when we try and do them. There is also the 'mental arithmetic' issue. Some people are very good at holding information in their heads and then retrieving it quickly and accurately (I am not one of them), this does not mean they cannot do arithmetic, just that they need to write down the appropriate numbers as they go along. Spreadsheets help a lot here. When a maths teacher puts up an equation on a board, then shows how it is calculated, they are not doing mental arithmetic, they have learnt how to do that example by rote, like an actor learning their lines. It does get a bit more complicated when indices are used, but there are rules that are easy enough to implement and if you use them often enough, they make life easy. If you don't do them often, you forget them. So the trick is to use algebra and indices as often as you can, and do the calculation with pencil and paper, then do the final bit (the actual numbers) with a calculator. You will generally, intuitively, know when something is not right, best thing to do then is start again. It took me over 20 years to get to grips with a text book example about calculating maximum volume possible for making a container, from a single flat sheet of material, using differentiation. I have never had to do that at work, but once I did it, it became a useful tool. I now know that it is possible to model this before it is made, even if I cannot, right at this moment, remember how to do it.
  17. SHC of water is 4.18 kJ/kg.K Fusion is 334 kJ/kg Air pressure will make a difference, but basically, if you have are trying to get the air dry, it takes a lot of energy if the temperature is above 0.01°C
  18. Should be obvious to everyone that has been to school. Time = s Distance = m Mass = kg
  19. Which seems to be happening now according to the news.
  20. Possibly, but if you are buying shares, they value may be different.
  21. I seem to remember from business studies that with an investment, you get your capital back as well as any interest or dividend payments. It may seem a minor thing, but that is why it could be a risky speculation, rather than an investment. There has been talk, for decades, about getting local communities to pay for local wind turbines or solar farms. These schemes usually involve a large developer selling a turbine to some sort of community interest company. It may be attached to planning as well.
  22. Yes. Just a light-hearted quip about soft drugs and glue sniffing.
  23. Glue it in place with Bostik
  24. I find a joint after 3PM relaxing.
