ultramods Posted May 16, 2019 Posted May 16, 2019 I need to cut the plastic plenums that are fixed in position, can anyone reccomend the best way to do this? I was thinking of buying a cheap reciprocating saw like this one: https://www.diy.com/departments/performance-power-700w-220-240v-reciprocating-saw-prs700c/3663602796176_BQ.prd Or should i just use a fine toothed hand saw?
scottishjohn Posted May 16, 2019 Posted May 16, 2019 need a lot more info than that to make a comment how big are holes needed , or is just trim what is sticking down in picture?
lizzie Posted May 16, 2019 Posted May 16, 2019 Installers cut mine off with what looked like an oversized electric carving knife, bit like the thing in your link. It was a very quick job. 1
ultramods Posted May 16, 2019 Author Posted May 16, 2019 4 minutes ago, scottishjohn said: need a lot more info than that to make a comment how big are holes needed , or is just trim what is sticking down in picture? It's not cutting a hole, the 125mm hole has already been cut. It's trimming the end off the plenum (125mm diameter) flush with the ceiling so I can then attach the air valve
ultramods Posted May 16, 2019 Author Posted May 16, 2019 6 minutes ago, lizzie said: Installers cut mine off with what looked like an oversized electric carving knife, bit like the thing in your link. It was a very quick job. Thanks, I was thinking it would make it a lot easier than a hand saw
Jeremy Harris Posted May 16, 2019 Posted May 16, 2019 I did mine with a multitool, as it will cut flush to a surface. I only have the relatively cheap Bosch one, but it seems to be OK (even if a Fein owning guy on site looked down his nose at it a bit). 1
vivienz Posted May 16, 2019 Posted May 16, 2019 All the ones in my house were cut with a multitool. 1
ultramods Posted May 16, 2019 Author Posted May 16, 2019 16 minutes ago, JSHarris said: I did mine with a multitool, as it will cut flush to a surface. I only have the relatively cheap Bosch one, but it seems to be OK (even if a Fein owning guy on site looked down his nose at it a bit). 2 minutes ago, vivienz said: All the ones in my house were cut with a multitool. Thanks, multi tool does look like a better option is terms of getting a flush to the ceiling cut.
scottishjohn Posted May 16, 2019 Posted May 16, 2019 21 minutes ago, ultramods said: Thanks, multi tool does look like a better option is terms of getting a flush to the ceiling cut. its very versatile tool --you need one anyway
dimpsy Posted May 16, 2019 Posted May 16, 2019 https://www.amazon.co.uk/Stanley-015252-FatMax-Reversible-10-inch/dp/B002KHJYBM/ref=sr_1_1?keywords=stanley+dovetail+saw&qid=1558022304&s=gateway&sr=8-1 I had one of these which did the job 1
Russell griffiths Posted May 16, 2019 Posted May 16, 2019 Buy a cordless one, so much more manoeuvrable than with a cord.
Bitpipe Posted May 16, 2019 Posted May 16, 2019 9 hours ago, JSHarris said: I did mine with a multitool, as it will cut flush to a surface. I only have the relatively cheap Bosch one, but it seems to be OK (even if a Fein owning guy on site looked down his nose at it a bit). +1 for multitool. TBH, as the cover fits over, doesn't matter if the cut is a touch rough. Only suggestion (too late for you) is to cut before skimming - I also did this after and would have had a smoother finish around them if I'd cut after boarding. 1
ultramods Posted May 17, 2019 Author Posted May 17, 2019 @JSHarris, @Bitpipe can you recommend a cutting attachment please as there are so many to chose from?
Bitpipe Posted May 17, 2019 Posted May 17, 2019 1 minute ago, ultramods said: @JSHarris, @Bitpipe can you recommend a cutting attachment please as there are so many to chose from? I borrowed my sparky's Makita with whatever cutting tool he had on think it was about 50mm wide. The plastic on those plenums is relatively soft and easy to cut, I just plunged the cutter in and out in a circle, took a minute or two for each one. Again, doesn't matter if the cut is perfect as the ceiling fitting covers it up completely. 1
Jeremy Harris Posted May 17, 2019 Posted May 17, 2019 As above, I think I just used the wood blade, like this: BTW, I've found Saxton blades to be good value and better quality than the blades that came with my Bosch multitool. 1
