Hey all !
Right i’ve Got some of this metal stud work to install in my dungeon . Is it best ( does it matter ? ) to fix to ceiling and slab that I drill and use screw and rawplug or drill and just use concrete screws ??
cheers
Actually thinking about it raw plugs might be better as shorter . Ceiling is 100mm thick .
I’ll wait for @Onoff to tell me what to do ... ?
Edited by pocster
I guess it depends what your hanging from the ceiling. Is it a light weight item or is it going to be in the 75 - 150kg range?
Edited by AdamSee
@pocster I think he is asking if you are going to suspend people?
23 minutes ago, Construction Channel said:
What exactly is the ceiling build up? Surely it can't be just a 100mm concrete slab?
Don’t go there !
its not !
( deep breath )
ceiling upwards
100mm reinforced concrete
40mm vac insulation
10mm particle board
failed edpm ?
35mm reinforced concrete
20mm screed
10mm monolithic asphalt type stuff
3mm asphalt protective layer
to be followed by
plastic pedestals
20mm tiles
phew !
2 minutes ago, pocster said:
Don’t go there !
 its not !
( deep breath )
ceiling upwards
40mm vac insulation
10mm particle board
failed edpm ?
 20mm screed
to be followed by
plastic pedestals
20mm tiles
phew !
Are you no longer having the roof as a drive-on area?  Also, are you planning on doing a plasterboard ceiling under the concrete?
Lol
Yes , you can still drive on it - so that area would be
polythene
block paving
I’m planning to have a suspended ceiling somehow ...
Sounds mighty complicated. Ct1 it up. Maybe a couple of screws to hold it in place. Personally I don't like perforating structural concrete things like lintols with screws. Afaic it's just asking for trouble
I eat complicated for breakfast .
I then spew it up at lunch time
Don't ask me, I've gone right off concrete screws recently! Well, as of last night! Got quite a few of these 7mm Easy Drive ones left over from studding the walls out. Even back then I had the odd one not take.
20190502_164807
Thought I'd give them another go battening out the bathroom cupboard. Drilled the requisite 6mm hole. Not a chance were they going in! Makita impact gun just said no! Couldn't be ar5ed going to 6.5mm.
Brown plugs and 6x90 Forge Fast screws for this lot:
2019-05-02_06-36-52
