February 16, 20197 yr After @JSHarris switched to E7 I thought I would look into it, I am with green energy so looked at their tariffs and (if I read it right) E7 gives you slightly cheaper DAY RATE as well as cheap night rate and nearly identical charge per day rate, https://www.greenenergyuk.com/SimpleTariffs They already quoted me £150 to change the meter. whats not to like? Edited February 16, 20197 yr by joe90
February 16, 20197 yr 40 minutes ago, joe90 said: After @JSHarris switched to E7 I thought I would look into it, I am with green energy so looked at their tariffs and (if I read it right) E7 gives you slightly cheaper DAY RATE as well as cheap night rate and nearly identical charge per day rate, https://www.greenenergyuk.com/SimpleTariffs They already quoted me £150 to change the meter. whats not to like? Just had a look. They quoted me 31.74p daily charge, day rate 21.56p night rate 14.71p I pay less than their day rate and a lower daily charge for a single rate supply,
February 16, 20197 yr Author 4 minutes ago, ProDave said: Just had a look. They quoted me 31.74p daily charge, day rate 21.56p night rate 14.71p I pay less than their day rate and a lower daily charge for a single rate supply, Does location make a difference?, they do ask for your postcode!, @ProDave who is your supplier then?
February 16, 20197 yr 8 minutes ago, joe90 said: Does location make a difference?, they do ask for your postcode!, @ProDave who is your supplier then? Yes it does. Currently paying just over 14p per unit and 20p per day with Octopus
February 16, 20197 yr There is a massive variation in tariff with location, and it's not at all consistent AFAICS. I keep hearing about "really great" tariffs, only to find when I check for our post code that they are uncompetitive. The only one that seems consistent over a wide area (it seems to be the same everywhere) is Octopus Go. It's a good deal if you are OK with a smart meter and can shift most of your consumption into the 4 hour off-peak period, from 12:00 to 04:00, IIRC.
February 19, 20197 yr Author Right, finally got to check stuff and Octopus seem great, 21.13p per day against 32.09 currently paying. Day rate is 15.77 against currently paying 21.29 or Octopus offer E7 at 18.7 day rate and 10.45 night rate. From their website Octpus don’t say what it will cost to change the meter to E7 and green energy quoted £150 to do this. Anyone got any better deals out there? (Bearing in mind location might preclude some suppliers).
February 19, 20197 yr So the quick way to get E7 for free is go to one of the big 6 on a standard tariff for a month. Book the switch to a standard tariff - call them and ask for the E7 meter install. Then as soon as it’s installed do a switch and 28 days later you should be on your new supplier.
February 19, 20197 yr Yes, that's what I did, SSE changed the meter for free, no obligation to stay with them.
February 19, 20197 yr 17p day 9p night 19p standing charge Don't know why I went on e7 hardly get to use it
February 19, 20197 yr Since we switched to E7 at the beginning of January (as of lunchtime today) we'd used 58% at the off-peak rate, 42% at the peak rate, so a useful saving by being on E7.
February 19, 20197 yr Author 23 minutes ago, Oz07 said: 17p day 9p night 19p standing charge Don't know why I went on e7 hardly get to use it @Oz07 what supplier is that? (Hope they do my area)
February 19, 20197 yr Author I am planning to heat DHW and UFH by ASHP overnight by using timers which should be the biggest users, on Octopus even the day rate and standing charge is cheaper than I currently pay??
February 19, 20197 yr 23 minutes ago, Oz07 said: What are the official hours 10-5? more like midnight to 7AM GMT varies a bit from region to region If you do switch to E7, then solar PV becomes more attractive as your generation will be offsetting the higher daytime rate.
February 19, 20197 yr 19 minutes ago, Oz07 said: What are the official hours 10-5? Depends on location but is 7 hours between 11pm and 8am. I've got 12:30 - 7:30 for example, but I've seen another that is 12:00 to 7:00 in the same region.
February 19, 20197 yr Try Bulb. Seen many people switch to them and they have offered both the referer and the person being referred £50. I am stuck with my current supplier so can't switch to anyone just now . Still, on the bright side my supplier has screwed up my tariff again after only just correcting it via an ombudsman decision so I'll just refer it back to the ombudsman if they try to overcharge me again. Twats! It's in my favour just now so am keeping QT about it for now.
February 19, 20197 yr Not so many people offer it, but economy 10 gives it's 10 hour cheap rate in more usable smaller chunks including a very useful afternoon period.
February 19, 20197 yr Author I did think of E10, just found this on the which website. “Octopus Energy can accept customers and put them on an Economy 7 tariff but with 10 off-peak hours.”I will contact them and ask if they can supply E10 and what the times and rates are.
February 19, 20197 yr 41 minutes ago, joe90 said: @Oz07 what supplier is that? (Hope they do my area) Octopus
February 19, 20197 yr Author 1 minute ago, Oz07 said: Octopus Ah, your tariff must relate to your area then (Damn). Right, Octopus 12m fixed it is then, I am waiting a reply to see what they charge to change the meter, if they do I will change to EDF with dual rate meter then immediately change to Octopus. also I will ask about E10 (as the above quote from Which indicates they give 10 hours but call it E7 ?????:) I will report back ?
February 19, 20197 yr Author Just found a Which survey about good supply companies. https://www.which.co.uk/reviews/energy-companies/article/best-and-worst-energy-companies/which-energy-survey-results
