Probably wait for warmer weather.
Or accept that you will need another tonne in future, and have a different, warm, tonne delivered.
Or go get some bags of sand from Wickes.
Light a fire under it. It'll melt the water in the sand so the fire won't damage the trailer...
Honest!
:ph34r:
(Mods, can we have a tongue in cheek emoji please!)
The best I can up with is to cover the sand with  a dark colour membrane, perhaps a bin liner, and hope the sun will heat the sand up a bit. Same principle as a  a solar shower...
3 minutes ago, Russell griffiths said:
I normally put it in the microwave [...]
Well she would get the hump if you heat up one tonne at a time, poor lass.
if you can make a big vegggie tunnel over it even better
heat from ground should do it
Edited by scottishjohn
4 minutes ago, Ferdinand said:
Mortar and pestle?
Digger and toothed bucket: no go
Crowbar and anger: no go
Pickaxe : no go
 ' ... Mortar and pestle... '  southern softies....... ya gotta love 'em
Back the trailer into your garage and put a heater on in there.
Should have put it there to start with, even in this cold spell, my unheated garage has not gone lower than 3 degrees.
Honest!
:ph34r:
I think it is this one.
1 minute ago, ProDave said:
Back the trailer into your garage and put a heater on in there.[...]
Not allowed a garage (Planning) . But I could duct the heater airflow from the digger cabin heater.......... now there's a thought.
Can you back it into a container, and put heat on there?
(Suspect they may all be full of essential equipment and stores.)
(On a smaller scale I have just brought all my bird feeders into the Utility to unfreeze and restock.)
F
Edited by Ferdinand
Down here it looks like it's going to warm up a lot tomorrow.  We had forecast temperatures for this morning of -6°C, (although we only saw about -3°C), but the forecast is for the temperature here to rise to around 10°C tomorrow lunchtime.
15 minutes ago, Russell griffiths said:
as you shouldn’t be mixing any sand and cement in this weather
With me, it's a good idea to check. Thanks.
Our lad needed the trailer....... tough luck
Meanwhile back on Silly Street...
100mm of pir in the base of the trailer topped off with some ufh pipes. Next time it freezes connect to a handy pumped hot water source...home brew bfo solar thermal array?
Tarp over the compost heap, dump the sand on that.....
I’ve just started knocking these out as it goes.
£3k + vat.
“Limited stock remaining, purchase now to avoid disappointment”
