Russell griffiths Posted January 27, 2019 Posted January 27, 2019 G,day looking for a supplier for our underfloor heating design, pipe, manifold, pipe clips and any other bits you think I need. Cheers peeps.
newhome Posted January 27, 2019 Posted January 27, 2019 All mine came from Wunda but I think others have shopped around on a mix and match basis to get the best price. 1
PeterW Posted January 27, 2019 Posted January 27, 2019 Design ...?? DIY, download loopcad free for 30 days. Bits ..? WundaTrade are good, save the hassle and go with the Wunda self adjusting heads and only play with the flow temp. 1
nod Posted January 27, 2019 Posted January 27, 2019 33 minutes ago, Russell griffiths said: G,day looking for a supplier for our underfloor heating design, pipe, manifold, pipe clips and any other bits you think I need. Cheers peeps. Warm up will supply and design Pretty easy to deal with also 1
Russell griffiths Posted January 27, 2019 Author Posted January 27, 2019 4 minutes ago, Onoff said: Our very own @Nickfromwales? Yes, he’s on my to do list, saving up for all the pies.
Onoff Posted January 27, 2019 Posted January 27, 2019 7 minutes ago, Russell griffiths said: Yes, he’s on my to do list Just sounds so wrong... 2 1
PeterW Posted January 27, 2019 Posted January 27, 2019 Whilst a couple of people have shopped around for bits to save a few quid, I know of a number of issues where one or two pieces haven’t worked and it’s difficult to get to the root cause of the issue. For the sake of £100 or so which is normally the difference, buy all the manifold components - that’s manifolds, blenders, actuators, pumps etc from the same supplier as you have one throat to choke. Pex pipe is standardised so you can get that pretty much anywhere. 1
epsilonGreedy Posted January 27, 2019 Posted January 27, 2019 10 minutes ago, PeterW said: Pex pipe is standardised so you can get that pretty much anywhere. Is this prowarm pipe a deluxe option or does the commodity stuff have the same cross section?
Russell griffiths Posted January 27, 2019 Author Posted January 27, 2019 19 minutes ago, Onoff said: Just sounds so wrong... Never tried welsh before. 1
PeterW Posted January 27, 2019 Posted January 27, 2019 13 minutes ago, epsilonGreedy said: Is this prowarm pipe a deluxe option or does the commodity stuff have the same cross section? All the PEX/Al/PEX and PERT/AL/PERT stuff has the same build up - a pair of plastic pipes bonded to an aluminium layer. It’s all 16x2 which is near enough a 1mm plastic sandwich either side of a layer of aluminum foil a few microns thick to create the oxygen impermeable layer. Target prices are around 42-45p/m ex VAT if you shop around. 1
PeterW Posted January 27, 2019 Posted January 27, 2019 14 minutes ago, Russell griffiths said: Never tried welsh before. Probably like chicken ... 2
dpmiller Posted January 27, 2019 Posted January 27, 2019 I've had positive outcomes dealing with both PSW Trade and Heating-Instal. You'll find them both on Ebay and elsewhere and they are very competitive. I've also chanced buying some pipe from one of the Chinese shopfronts on Ebay, it arrived quickly and is (most likely) the same product everyone else is flogging anyway... 1
Nickfromwales Posted January 28, 2019 Posted January 28, 2019 On 27/01/2019 at 14:25, Russell griffiths said: Never tried welsh before. You've never lived...…
Onoff Posted January 28, 2019 Posted January 28, 2019 On 27/01/2019 at 14:25, Russell griffiths said: Never tried welsh before. You just know that something good is going to happen, they've the freshest moves you've ever seen...
