recoveringbuilder Posted October 13, 2018 Posted October 13, 2018 Anybody have any experience of installing a sewage treatment tank, in our previous builds we had a normal septic tank with the outfall going to a soak away which my husband did himself however this time we have to install a sewage treatment plant, no soak away, straight to the burn running through our land, just wondering if there’s a lot of difference in the installation method
Nickfromwales Posted October 13, 2018 Posted October 13, 2018 The search engine is your friend. And plenty more where that came from ?
Stones Posted October 13, 2018 Posted October 13, 2018 Treatment Plant install will be similar, i.e. set plant to correct invert level. Whether the outflow level matchs the burn is another matter, worst case you might have to discharge into a chamber and a float switch pump will shift the treated effluent into the burn.
joe90 Posted October 13, 2018 Posted October 13, 2018 Yes I have just installed a treatment plant, had to get permission to drain to ditch via the EA. As the ditch is dry a couple of months a year had to instal a rumble drain (pipe from plant to outfall full of holes and trench full of gravel). My treatment plant has an air pump fitted above it so power was required at the location. Simple to install, mine was in concrete as the water table is high.
ProDave Posted October 13, 2018 Posted October 13, 2018 Treatment plant discharging to a burn is a delightfully simple system. You will need a discharge permit from SEPA and they don't like giving them unless this is the only option. We had to prove, buy proposing 2 other schemes first, that discharge to the burn was the only option before they would allow it. now it is installed is is wonderfully simple with nothing to go wrong. Make sure you use one of the air blower type treatments plants. I would not personally choose one of the type that has rotating mechanical parts in the brown smelly stuff.
Redoctober Posted October 13, 2018 Posted October 13, 2018 A timely thread as ours is going in this week - a bio-pure treatment plant. Installation instructions are [or seem to be] builder friendly and SEPA [Scotland] have insisted on an additional soak away pit before we tap into a field drain leading into a local water course. High level overflow drawing SEPA.pdf Bio-Pure 1 Tech Drawing PDF.pdf
recoveringbuilder Posted November 4, 2018 Author Posted November 4, 2018 @Redoctober wondering how you got on with this, ours is still ongoing, no diagrams available regarding the air duct connection from the outlet end to the blower housing, any help gratefully received!
joe90 Posted November 4, 2018 Posted November 4, 2018 38 minutes ago, Christine Walker said: @Redoctober wondering how you got on with this, ours is still ongoing, no diagrams available regarding the air duct connection from the outlet end to the blower housing, any help gratefully received! What is the make of your treatment plant Christine?
recoveringbuilder Posted November 4, 2018 Author Posted November 4, 2018 @joe90it’s called a Clearwater E6 but made by kingspan
Redoctober Posted November 4, 2018 Posted November 4, 2018 6 hours ago, Christine Walker said: @Redoctober wondering how you got on with this, ours is still ongoing, no diagrams available regarding the air duct connection from the outlet end to the blower housing, any help gratefully received! Hi @Christine Walker Ours is now safely and securely installed - The electrician, who failed to show all last week is due to site Monday 5th Nov to wire it up amongst other second fix installations. Unfortunately, other than what I have already posted, I haven't any other guidance - sorry. 1
recoveringbuilder Posted November 4, 2018 Author Posted November 4, 2018 Had a look at your pictures, it’s the blower unit we aren’t sure of, I see your hose coming out the outlet, our instructions say to put it through 110mm duct from the outlet then through the concrete base for the blower unit into unit, all sounds very confusing without a diagram!
Redoctober Posted November 4, 2018 Posted November 4, 2018 2 hours ago, Christine Walker said: Had a look at your pictures, it’s the blower unit we aren’t sure of, I see your hose coming out the outlet, our instructions say to put it through 110mm duct from the outlet then through the concrete base for the blower unit into unit, all sounds very confusing without a diagram! Yep it does. The hose coming out of my inlet was simply there to fill the tank up with water in order to assist with weighing it down for installation purposes. Perhaps others more knowledgeable could assist. 1
joe90 Posted November 5, 2018 Posted November 5, 2018 (edited) I tried to search for a diagram on tinternet but could not find one (I am laid up with an injured hand and ordered to rest ?) I only found this which has a drawing showing a pipe exiting the plant to connect the blower, page 3, hope it helps. https://mpcservices.co.uk/media/wysiwyg/Clearwater_PS_2011_8pp_1.pdf Edited November 5, 2018 by joe90 1
Pauljg79 Posted November 30, 2018 Posted November 30, 2018 Is this now sorted? I can offer advise if not. I've attached the latest drawing i had on file for these. It's still not very clear. Let me know if you need any help. Best wishes, Paul DS0968P-03 - E6 E12 Gravity.pdf
recoveringbuilder Posted November 30, 2018 Author Posted November 30, 2018 Yes all sorted now @Pauljg79 thanks anyway
