I need joist hangers for two types of job: one to support a flat roof, the other to support a floor.
Looking at the range joist hangers makes me feel like I'm in a toy shop. I like them all, but haven't got a Scooby about which to choose.
Here's an image search for what's available.
Presumably I would not choose a hanger with a top flange for the POSIs which are under the first floor (because it would make the flooring less even).
Bearing in mind the horror stories related elsewhere on BH,  which should I avoid (cheap?). Or is it a matter of  - they are all OK, it's just how you use them that counts?
Face fix rely only on the strength of the nails. Top fix are quite slim anyway and you won’t notice the flanges under the edge of Egger board anyway. They are much stronger imho
DO make sure that you use the correct nails fir joist hangers, I see so many people just use long clout nails, NO, use proper twist nails, that’s what they are made for.https://www.screwfix.com/p/easyfix-square-twist-nails-sheradised-3-75-x-30mm-1kg-pack/12788
i like “fold over the top” type hangers, feels stronger IMO. and they are thin so should not be a problem with flooring.
Edited by joe90
Pretty good advice. Fold over joist hangers and proper nails.
I would have argued all hammers are the same.....but I have found a big difference between end of aisle bargain box hammers in a big diy shed to decent one out of a build merchants.
Edited by Alexphd1
1 hour ago, recoveringacademic said:
Thanks Jo.
I'll need a real hammer then not a nail machinegun
You can get nail guns for fitting metalwork that fire twist nails but they are eye watering to buy and hire.
Decent hammer, nail pouch and fit the metalwork from the bottom upwards ..... when you’ve got a bracket in your hand you’ll realise what that means !!
Remember I have 8 fingers, of which 5 and a half work as advertised.....
  • Haha 1
Going back to your other topic of how to fit your posi joists
if you go for top hung you won’t need any hangers.
Add the cost of all of the hangers up, it could dictate a different way of fitting them.
As posi joists are a bespoke engineered solution i'd have assumed your posi supplier would be specifying and supplying the hangers as part of the package. Don't their drawings spec the hangers, and include a disclaimer against adapting/modifying without consultation.
  • Like 2
