Moira Niedzwiecka Posted May 14, 2018 Author Posted May 14, 2018 Brilliant, thanks for the detail Peter.
gavztheouch Posted October 25, 2025 Posted October 25, 2025 Is it still recommend to put the inlet and outlet 2m apart? I see Zhender have a combined inlet/outlet that have the pipes right next to each other. I guess there will be a baffle arrangement to prevent cross contamination. https://www.fastlec.co.uk/zehnder-2x160mm-right-hand-external-wall-grille?utm_campaign=smartsh&gad_source=1&gad_campaignid=17190426677&gbraid=0AAAAAD8Nz9f-3-LzDnHIlsuV-MleAAoms&gclid=CjwKCAjw6vHHBhBwEiwAq4zvA_Lglcqpz9-48JocAj6NXNiC2dTtCF737MkcyS5OSb9FuJkesldSKRoCFYcQAvD_BwE
JohnMo Posted October 25, 2025 Posted October 25, 2025 11 minutes ago, gavztheouch said: Is it still recommend to put the inlet and outlet 2m apart? I see Zhender have a combined inlet/outlet that have the pipes right next to each other. I guess there will be a baffle arrangement to prevent cross contamination. https://www.fastlec.co.uk/zehnder-2x160mm-right-hand-external-wall-grille?utm_campaign=smartsh&gad_source=1&gad_campaignid=17190426677&gbraid=0AAAAAD8Nz9f-3-LzDnHIlsuV-MleAAoms&gclid=CjwKCAjw6vHHBhBwEiwAq4zvA_Lglcqpz9-48JocAj6NXNiC2dTtCF737MkcyS5OSb9FuJkesldSKRoCFYcQAvD_BwE I use similar with zero issues.
Kelvin Posted October 25, 2025 Posted October 25, 2025 38 minutes ago, gavztheouch said: Is it still recommend to put the inlet and outlet 2m apart? I see Zhender have a combined inlet/outlet that have the pipes right next to each other. I guess there will be a baffle arrangement to prevent cross contamination. https://www.fastlec.co.uk/zehnder-2x160mm-right-hand-external-wall-grille?utm_campaign=smartsh&gad_source=1&gad_campaignid=17190426677&gbraid=0AAAAAD8Nz9f-3-LzDnHIlsuV-MleAAoms&gclid=CjwKCAjw6vHHBhBwEiwAq4zvA_Lglcqpz9-48JocAj6NXNiC2dTtCF737MkcyS5OSb9FuJkesldSKRoCFYcQAvD_BwE Similar to ours. No issue at all. Nice and neat.
Mike Posted October 25, 2025 Posted October 25, 2025 2 hours ago, gavztheouch said: Is it still recommend to put the inlet and outlet 2m apart? Yes, unless have a special terminal such as the Zhender.
Nickfromwales Posted October 25, 2025 Posted October 25, 2025 13 hours ago, gavztheouch said: Is it still recommend to put the inlet and outlet 2m apart? I see Zhender have a combined inlet/outlet that have the pipes right next to each other. I guess there will be a baffle arrangement to prevent cross contamination. https://www.fastlec.co.uk/zehnder-2x160mm-right-hand-external-wall-grille?utm_campaign=smartsh&gad_source=1&gad_campaignid=17190426677&gbraid=0AAAAAD8Nz9f-3-LzDnHIlsuV-MleAAoms&gclid=CjwKCAjw6vHHBhBwEiwAq4zvA_Lglcqpz9-48JocAj6NXNiC2dTtCF737MkcyS5OSb9FuJkesldSKRoCFYcQAvD_BwE My PH design guy says 1000mm apart is absolutely fine, and that is fortified in my opinion when you see combination vents doing both the 'inny' and the 'outy'. No need for 2m afaic, and I have fitted a lot of MVHR systems successfully in the last decade+ with excellent results and feedback from clients who have then moved in and are living with the systems.
gavztheouch Posted October 26, 2025 Posted October 26, 2025 My house is 210m2. Anyone else have a similar m2 and if so what diameter of pipe did you use for the external piping. Zhender have a pipe that is pre insulated I think it is 160 internal and around 250mm external. im also going for wood cladding. It’s open rainscreen so I need to make sure I’m weather tight coming through the membrane. What did you use here, I’m thinking an epdm grommet if they come big enough or possible just tape but I think that is always harder than a grommet.
JohnMo Posted October 26, 2025 Posted October 26, 2025 21 minutes ago, gavztheouch said: My house is 210m2. Anyone else have a similar m2 and if so what diameter of pipe did you use for the external piping. Zhender have a pipe that is pre insulated I think it is 160 internal and around 250mm external. im also going for wood cladding. It’s open rainscreen so I need to make sure I’m weather tight coming through the membrane. What did you use here, I’m thinking an epdm grommet if they come big enough or possible just tape but I think that is always harder than a grommet. You need to do the pressure drop calculation really. Depends on flow rate, length and number of bends in the duct. But would suspect 160mm is fine and 250mm overkill. I just taped between membrane and duct (foam ducts)
Nickfromwales Posted October 26, 2025 Posted October 26, 2025 3 hours ago, JohnMo said: You need to do the pressure drop calculation really. Depends on flow rate, length and number of bends in the duct. But would suspect 160mm is fine and 250mm overkill. I just taped between membrane and duct (foam ducts) 160mm insulated is 250mm finished, external dia, as above. Not a 250mm duct
Nickfromwales Posted October 26, 2025 Posted October 26, 2025 @gavztheouch https://www.cableglandsuk.com/products/dafa-renovation-grommet-airtight-sealing-for-passivhaus?_pos=1&_sid=a43c395d4&_ss=r&variant=46767281373408
