Gone West Posted February 14, 2018 Posted February 14, 2018 2 minutes ago, Declan52 said: What did you use to cut it?? Would a diamond tipped blade in a grinder do the job. Do you have to use special screws with it that cut into it?? I used a circular saw with a TCT blade but it ruined it eventually and I pre-drilled and countersunk all the screw holes and used s/s screws.
Onoff Posted February 14, 2018 Posted February 14, 2018 (edited) On thd Aquapanel I used normal Starrett hole saws for the circular bits. I used carbide grit jigsaw blades for the square cut out as recommend by @Nickfromwales: https://www.toolstation.com/shop/Power+Tool+Accessories/d80/Sabre+%26+Jigsaw+Blades/sd2581/Tungsten+Carbide+Grit+Jigsaw+Blades/p67688 No need to countersink the Aquapanel as the screws themselves do it. Edited February 14, 2018 by Onoff
Declan52 Posted February 14, 2018 Posted February 14, 2018 Do you have to use SS screws I would something like turbo gold screws do.
divorcingjack Posted February 15, 2018 Author Posted February 15, 2018 Thanks for all the replies on this, very helpful, chaps. Spent an eye watering afternoon yesterday pricing up Aquapanel, Hardiebacker and Marmox boards. I assume 12.5mm is the thing to use? Some above I notice have done a mix of Aquapanel and MR plasterboard in less "at risk" areas. Is this reasonable, or should we really just do the whole lot in Aquapanel/hardie/marmox and then tank over everything? Cheers, dj PS: If anyone has seen any good deals on this stuff, I'd be most appreciative
Gone West Posted February 15, 2018 Posted February 15, 2018 16 hours ago, Declan52 said: Do you have to use SS screws I would something like turbo gold screws do. Quite possibly, I just tend to over engineer things.
Gone West Posted February 15, 2018 Posted February 15, 2018 16 hours ago, Onoff said: On the Aquapanel I used normal Starrett hole saws for the circular bits. I used Erbauer hole cutters for the pipe cut outs in the HardieBacker but they didn't last very long.
MikeGrahamT21 Posted February 15, 2018 Posted February 15, 2018 2 hours ago, divorcingjack said: Thanks for all the replies on this, very helpful, chaps. Spent an eye watering afternoon yesterday pricing up Aquapanel, Hardiebacker and Marmox boards. I assume 12.5mm is the thing to use? Some above I notice have done a mix of Aquapanel and MR plasterboard in less "at risk" areas. Is this reasonable, or should we really just do the whole lot in Aquapanel/hardie/marmox and then tank over everything? Cheers, dj PS: If anyone has seen any good deals on this stuff, I'd be most appreciative You can use any thickness of the marmox, dependant on how much insulation/VCL effect you want from the product, obviously the thicker it is the better, but all thicknesses are suitable for tile finish. You don't need any tanking with Marmox, its ready to use once fixed, and is far less vapour open than the other products mentioned, which do let water vapour through despite being waterproof. 2
markharro Posted yesterday at 11:49 Posted yesterday at 11:49 I am about to tile onto Fermacell - quite large format limestone. Its not in a wet area - basically an alcove in the hall. Anything specific about tiling on Fermacell to know about that is different to using hardie cement board ? thanks
Mr Punter Posted 20 hours ago Posted 20 hours ago 4 hours ago, markharro said: I am about to tile onto Fermacell - quite large format limestone. Its not in a wet area - basically an alcove in the hall. Anything specific about tiling on Fermacell to know about that is different to using hardie cement board ? thanks Fermacell is Gypsum based, like plasterboard. It is not as brittle as cement board. No special requirements for tiling as far as I know. You have done well if you have managed to line the whole place with Fermacell as it is heavy and difficult to cut and fix.
jack Posted 2 hours ago Posted 2 hours ago 22 hours ago, markharro said: I am about to tile onto Fermacell - quite large format limestone. Its not in a wet area - basically an alcove in the hall. Anything specific about tiling on Fermacell to know about that is different to using hardie cement board ? thanks We used it in a few places but didn't tile directly onto it. One thing I'd suggest thinking about his how porous it is. I don't know what adhesive you plan to use, but I'd guess it would suck a lot of water out of, say, flexible cementitious adhesives. All speculation on my part, so please don't rely on it! 18 hours ago, Mr Punter said: You have done well if you have managed to line the whole place with Fermacell as it is heavy and difficult to cut and fix. Yeah, it's so much more challenging to work with than plasterboard. However, once up, it's dead solid, and you can hang just about anything off it.
Nickfromwales Posted 1 hour ago Posted 1 hour ago Apply a good few coats of primer / water solution on to it a few days before tiling, to ‘size’ the surface and reduce it’s porosity. Mix up some 75% water 25% primer and give it a good few lashings, a couple of hours apart, and you’ll soon see the board becoming saturated. Apply some neat a day or two before tiling, and then tile on to freshly applied wet, neat primer.
