AdamD Posted 4 hours ago Posted 4 hours ago Plug broken so doesn’t work properly but unfortunately it’s been pushed down a bit too far, absolutely no idea how to get it out - any ideas appreciated! thanks
AdamD Posted 4 hours ago Author Posted 4 hours ago 18 minutes ago, Mr Punter said: Is there anyone around that you can blame? The kids, but being 4 and 2 I can blame them but not much they can do 😂
AdamD Posted 4 hours ago Author Posted 4 hours ago Just now, JohnMo said: Go from underneath take the u bend off to get access. Yeah I assumed that, take it off and just push it all up?
JohnMo Posted 4 hours ago Posted 4 hours ago Or just unscrew the whole metal piece and replace with new assembly - you seem to find spares for this stuff
AdamD Posted 3 hours ago Author Posted 3 hours ago Can’t seem to get the mechanism out. Haven’t got a spanner big enough to loosen the black bit - any ideas?
Gone West Posted 3 hours ago Posted 3 hours ago 6 minutes ago, AdamD said: any ideas? https://www.screwfix.com/p/magnusson-water-pump-pliers-10-254mm-/1791v
AdamD Posted 3 hours ago Author Posted 3 hours ago Once I’ve got that loose, should the whole mechanism come out fairly easily?
Mr Punter Posted 2 hours ago Posted 2 hours ago I think if you unscrew the white waste pipe - which you should be able to do by hand - you may be able to get to the waste from underneath. Failing that, you may need to replace the waste. Is it a clicker one?
Russell griffiths Posted 2 hours ago Posted 2 hours ago Easier and quicker to go and buy a new pop up waste and fit it, 15 minute job.
AdamD Posted 2 hours ago Author Posted 2 hours ago 26 minutes ago, Mr Punter said: I think if you unscrew the white waste pipe - which you should be able to do by hand - you may be able to get to the waste from underneath. Failing that, you may need to replace the waste. Is it a clicker one? Yeah clicker one. Took the waste off but couldn’t get to it, argh!
Onoff Posted 1 hour ago Posted 1 hour ago 2 hours ago, AdamD said: hanism out. Haven’t got a spanner big enough to loosen the black bit - any ideas? Buy a 3D printer and print a spanner!
MPH243 Posted 35 minutes ago Posted 35 minutes ago If you can turn the push down plug bit it can be unscrewed to change the push bit. A suction cup might pull it up if it's strong enough?
