Tuesday at 11:015 days Get some tape on the ends of those pipes as you uncoil it before any shite gets in them.
Tuesday at 11:325 days Author 30 minutes ago, Russell griffiths said:Get some tape on the ends of those pipes as you uncoil it before any shite gets in them.Yes, I did that straight away, I'd just cut those ends and took the pic before I re-taped them!
Tuesday at 14:055 days Author 3 hours ago, -rick- said:That sounds suboptimal. What size are these pipes?I'd try and pick up the phone and talk to a few installers before you screed unless you want a significant chance that the installer doesn't want to use what you put in.The pipes are 25/26mm MLCP.
Tuesday at 14:065 days Author 3 hours ago, JohnMo said:You don't need to split, you can take flow to the first manifold and out the other end of the manifold to the next manifold. The return the same thing. Your flow meters split the flow as you need just the same as a larger single manifold would.So are you saying it's wrong to install these 2 manifolds in "parallel" configuration and I should instead be installing them in "series"?
Tuesday at 14:155 days 4 minutes ago, Mulberry View said:So are you saying it's wrong to install these 2 manifolds in "parallel" configuration and I should instead be installing them in "series"?You can do either, really depends on you routing options. But your previous images shows 2 sets of pipes doing the same route to the first manifold, so why not just do one set of pipes to the first manifold and extend to the next manifold.
Tuesday at 14:375 days Author 18 minutes ago, JohnMo said:You can do either, really depends on you routing options. But your previous images shows 2 sets of pipes doing the same route to the first manifold, so why not just do one set of pipes to the first manifold and extend to the next manifold.My last sketch has really confused things, apologies for that. So I've done it again over the correct layout design to represent what I'm well advanced into laying... Ignore the previous version. Does this make more sense?! The long run is around 20m, the short one is 8m. Edited Tuesday at 14:375 days by Mulberry View
Tuesday at 15:145 days I have not read the whole thread but wondered why you ruled out running the pipes in the ceiling void?
Tuesday at 15:175 days Author 2 minutes ago, Mr Punter said:I have not read the whole thread but wondered why you ruled out running the pipes in the ceiling void?Mainly because it was suggested to run them this way, but I do have a tricky service route to the furthest manifold with a steel beam in the way.
Tuesday at 17:505 days 7 hours ago, Mulberry View said:what I'm doing is OK,Very neat. We had to hack ours out in a hurry. Laying the surprisingly stiff pipes to their curved route then cutting (hacking really) underneath. I'm not showing my pictures.
Tuesday at 19:045 days 8 hours ago, Mulberry View said:Funny you've said that, I'm back here with more questions.I have opted to do just that, I've chased the pipes into the lower layer of insulation. I decided that I would prefer to lay the 80mm top sheet of PIR in the more reliable way and being able to go straight over the pipework sat better with me. In fact, chasing the grooves for the pipes to sit in has been pretty easy. Messy, but not that hard.Here is the first pair curved up the wall in the Mech room and heading off to do the longer of the 2 runs......and here are those pipes passing into the adjacent room. I cored each pipe individually through the blockwork internal wall. I have begun the chasing for the next pair that will run alongside up to the point seen here, but will veer off the other way towards the second manifold....From there, they pass through a third room in the same way, but then have to turn up and into the adjacent space, 600mm higher. I cored through the wall diagonally to reduce the amount of bending needed...Here, they're left long in the Kitchen because I've not put any insulation down yet. But they are pointing in the direction of travel according to the red-line sketch I posted earlier.I set my Circular Saw to 45mm cut depth and made cuts 45mm apart. Cutting the majority of the material out with a wood-saw, then following with the little yellow Surform seen in the first pic, which fits nicely in the groove and makes short work of really tidying the grooves. I have left 40mm between the pipes where possible. Messy, yes, but very do-able.I hope what I'm doing is OK, and yes I'm thinking of pressure-testing the pipes and am researching how that's done, so any ideas are welcomed. I think I need to link the MLCP pipes together at the "manifold end", then pressurise at the other end, presumably with some sort of blanking arrangement with a gauge and schrader valve built in?That's neat work. Does that pipe hold its shape when you bend it? What should I use if wanting to take hot and cold to an island some form of conduit?
Tuesday at 19:425 days 34 minutes ago, Oz07 said:Does that pipe hold its shape when you bend it?Ours were very stiff and were not keen to be smoothed from their coil shape.For an island it's exactly the same but allow for the gentle bend that avoids kinking... perhaps it's ok to box out the screed locallyto give easy access for a bend.
Wednesday at 12:164 days Author 17 hours ago, Oz07 said:That's neat work. Does that pipe hold its shape when you bend it? What should I use if wanting to take hot and cold to an island some form of conduit?Yes, the pipe does hold it's shape. It's not been too hard to work with, but definitely needs two people at least when working over the lengths we are and passing through walls.I guess it would be suitable for running your island feeds. I bought a simple mechanical pipe bender, which can put 90° bends in it once the insulation is pulled back. The bender cost me about £60.
20 hours ago20 hr @Mulberry View On the software side: Heatpunk and LoopCAD are awkward when the plan has level changes. For your case the useful check is simpler: room heat loss vs loop length and spacing, then whether the primary run to each manifold stays sensible at your total flow.Rough ballpark (plug in your consultant's kW): at 5 K ΔT, 5 kW is about 14 l/min. 26 mm MLCP handles that fine over 20 m; half the flow to the far manifold is even quieter. Parallel feeds beat series if both manifolds can see the ASHP.On the Heatpunk-style layout fight: tools like heatlosspro.cloud are lighter if you mainly want rooms, emitters and pipe runs visualised without fighting a full CAD import.
12 hours ago12 hr Author 8 hours ago, gac said:@Mulberry View On the software side: Heatpunk and LoopCAD are awkward when the plan has level changes. For your case the useful check is simpler: room heat loss vs loop length and spacing, then whether the primary run to each manifold stays sensible at your total flow.Rough ballpark (plug in your consultant's kW): at 5 K ΔT, 5 kW is about 14 l/min. 26 mm MLCP handles that fine over 20 m; half the flow to the far manifold is even quieter. Parallel feeds beat series if both manifolds can see the ASHP.On the Heatpunk-style layout fight: tools like heatlosspro.cloud are lighter if you mainly want rooms, emitters and pipe runs visualised without fighting a full CAD import.Yes, I found both really hard once it came to dealing with the level changes, maybe I was trying to make it too perfect! I'm glad I got someone to take care of that side of it.I have been getting set up to pressure test these pipes before laying the rest of the insulation over them.I wonder if we'll end up with a 7kw heat pump for a bit of comfort room, but once I get someone on board, I'll take their advice.I'm finding ASHP installers hard to pin down. A highly reputable local company came to see me in June and were very keen, then just dropped off the face of the earth. They've replied this week basically saying they don't want the work as they're so busy.I mailed 3 last week and only one has replied. They are persistent that I install my UFH at 150mm centres, despite the numbers simply not needing it. I'll get their quote though and see where we land.
Just now1 min 12 hours ago, Mulberry View said:Yes, I found both really hard once it came to dealing with the level changes, maybe I was trying to make it too perfect! I'm glad I got someone to take care of that side of it.Makes sense on the level changes. On centres: if the room loss at your design flow temp is covered at 200 mm (or whatever your calc shows), 150 mm mostly buys shorter loops and a bit more even floor temp. Worth asking them what ΔT and floor output (W/m²) they’re designing to, and to show the room-by-room loss that forces 150.On the 7 kW vs smaller: comfort margin is fine if the unit can modulate low enough for shoulder season. The risk is short cycling when it’s mild, not a cold snap. Once you’ve got a serious installer quote, compare their heat-loss figure to your consultant’s kW and a couple of cold-day gas (or heat) readings if you have them.Installer ghosting is painfully common right now. Getting one written quote that shows centres + design flow temp + emitter/UFH output side by side would be great, even if you don’t take them.
