Spinny Posted August 19 Posted August 19 (edited) So I have most of my LVT down now only another 15 sqm to do. However as I feared there is another undulation/raised area within the floor leveller applied on the remaining floor area. The bulk of the floor area is between 0mm and +3mm of target. However there is a ridge/raised area where part of the floor rises to +5mm or +5.5mm and then back down again. Rising from say an acceptable +2-3mm to the peak of +5.5mm and back down to +2mm again over about a 1.4m distance. 500mm rising from +2mm to +5mm, then flatish for 400mm, thenback down to +2mm over 500mm. You can rock a spirit level on the ridge and measure up to a 3-5mm gap under the end of a 1.8m spirit level. There was 1 other smaller area on the floor now laid that had a 'hill' and I asked for it to be reduced as thet said it could be sanded down. However the sanding/grinding process did leave some fine ridges in the floor surface - basically like marks from a sanding/grinding disc. And now the LVT has been layed over that area, these marking suprisingly show through. When viewed into the light at the right angle you can see the markings in the LVT itself, which seems to have conformed itself to any lack of total smoothness in the floor surface. So should I not have my other 'hill' sanded down, as 'messing with it' may reduce the hill/ridge, but end up with the floor perhaps looking worse because the working marks will show through in the LVT surface ? Should I live with a lack of levelness in a decently smooth surface - or risk having a flatter but unsmooth surface by having the flooring contractor work on it ? See photos... The hill is where the darker pour area is on the floor - now with levels marked on tape by me. The closer photo of the other LVT laid floor area shows how you can see small arcs in the LVT in glancing light from the open door way. This is where the other high spot was sanded/ground down. Edited August 19 by Spinny
Nickfromwales Posted August 19 Posted August 19 @Spinny I'd suggest copying this to the existing thread on this 'journey', as it would have made much more sense there and have greater context. If you want to do that, I can then hide this one .
Gus Potter Posted August 19 Posted August 19 14 hours ago, Spinny said: However as I feared there is another undulation/raised area within the floor leveller applied on the remaining floor area. The bulk of the floor area is between 0mm and +3mm of target. However there is a ridge/raised area where part of the floor rises to +5mm or +5.5mm and then back down again. Rising from say an acceptable +2-3mm to the peak of +5.5mm and back down to +2mm again over about a 1.4m distance. 500mm rising from +2mm to +5mm, then flatish for 400mm, thenback down to +2mm over 500mm. You can rock a spirit level on the ridge and measure up to a 3-5mm gap under the end of a 1.8m spirit level. I appreciate your desire for level and diligence. Have you considered. If you have an existing house. How level and undulating all the other floors are? If a new house then it is going to take time to bed in, settle. To provide a bit of context. Often as an SE I'll start by designing a house to settle no more differentially by 25mm! Then refine depending on the finishes and how tolerant the structural frame is going to be in terms of differential settlement. A Swedish log cabin might shrink by 75 - 100mm! I would give the floors you have laid so far a "walk over test" not by you, but by visitors. Ask them if they notice much level or issues with flatness. Glancing light is always going to show up even tiny changes. This is building, not eye surgery! 1
Mr Punter Posted August 19 Posted August 19 I have an early Victorian rental and the plinth in the kitchen is out by 50mm over 1200mm. Oddly it is not that noticeable to walk on.
saveasteading Posted August 20 Posted August 20 8 hours ago, Mr Punter said: Oddly it is not that noticeable to walk on. We don't notice the small rises and falls and especially not consistent slopes. Eg we have a dreadfully poorly screeded room with 17mm variance from one corner to the opposite. ( v Big room) You cannot feel it in walking. The tiler has dealt with it skillfully with double buttering which also loses the dips and ripples. But: it is visible and a pain in fixing skirtings. If the floor was thin LVT then it would follow the curves and show every ripple and I'd worry about it not even lying in straight lines. If the floor was thin laminate I'd worry about ridges and hollows being bridged and bouncing. What am I saying? 1. It depends what floor you are laying. Appearance may be more of an issue than performance or final shape. 2. The screeders' work is awful and next time I'd ask very rigorous questions about method and control. Because of seeing it done well once, I assumed a level of competence which was not there. 1
saveasteading Posted August 22 Posted August 22 On 20/08/2026 at 08:38, saveasteading said: cannot feel it in walking. Here's a tip, no charge. To assess if there is a slope, without equipment., walk a straight line with a comfortable gait. Then reverse and walk the same line back. That at a minimum tells you if there is a difference, and which way. I'd say this detects say 2% or more. Whether that difference is significant is another matter.
Spinny Posted August 23 Author Posted August 23 I have the contractor coming tomorrow to take a look and give me the benefit of their experience. Very likely the inevitable advice will be to do nothing and just floor over it of course. But any more thoughts on this appreciated. When the builders poured the original underlying concrete slab they said it would be level within 6mm - they achieved about 30mm variation and 10mm higher than target. When the flooring people levelled it the standard for thin-layer flooring is SR1 or <3mm over 2m but haven't fully achieved it. Maybe it is best left as is ? I can perhaps find a carpenter to cut one table leg shorter if it proves a problem 🙃 I get the comment about floors generally, but when new they ought to be very close to level and this should be achievable with the otherwise somewhat euphemistically named 'levelling compound'. What have others achieved on their build with hard floors ? Anyone else that sees subfloor flaws showing through LVT ? The guy laying it uses a very thin layer of adhesive and rolls it down hard - I had imagined that rather like ceramic tile laying that the adhesive bed could be somewhat varied to counter subfloor flaws ? Quote The individual segments of the James Webb Telescope's primary mirror are polished smooth to an accuracy of roughly 20 nanometers—about 10,000 times thinner than a human hair.
saveasteading Posted August 23 Posted August 23 30 minutes ago, Spinny said: should be achievable It is apparent that not only are the necessary skills in short supply, but so is knowledge. I've been 7 years or so out of the industry. Things are much worse, or maybe it needs a lot more project management and toughness. Our floor issues are because the 'specialist' screeder sent in one guy to lay the insulation and he did NOT like supervision or questions, at which point he couldn't speak English. Fast but rough. Then next day the same guy was laying ufh pipes very quickly and quite well. Then a different gang poured the screed and just moved it around...no level control. Again, no Interest in discussing control of levels: other than to say ' of course, this is what we do'. I never saw the boss unless one of them really was but was feigning just bring a worker. Next time, I would have a very serious discussion beforehand. If it added 2 man days and some screed it would be worth the cost.
Nickfromwales Posted August 23 Posted August 23 23 minutes ago, saveasteading said: It is apparent that not only are the necessary skills in short supply, but so is knowledge. I've been 7 years or so out of the industry. Things are much worse, or maybe it needs a lot more project management and toughness. Our floor issues are because the 'specialist' screeder sent in one guy to lay the insulation and he did NOT like supervision or questions, at which point he couldn't speak English. Fast but rough. Then next day the same guy was laying ufh pipes very quickly and quite well. Then a different gang poured the screed and just moved it around...no level control. Again, no Interest in discussing control of levels: other than to say ' of course, this is what we do'. I never saw the boss unless one of them really was but was feigning just bring a worker. Next time, I would have a very serious discussion beforehand. If it added 2 man days and some screed it would be worth the cost. Next time, let me know and I'll send you contact details for my chap. He is shit hot. He asks where the key points are, sets out pads off a laser, then joins the dots (pads) for a flawless result; he literally bends the floors to get what I want, where necessary, and it's totally unnoticeable. One job was 10mm to 90mm undulation, and he walked through it perfectly; only issue was at less than 25/30mm he insisted on a specialist primer so the thinner areas wouldn't delaminate. Which they didn't. I went back to the job some 7 years later, and the tiled floor was still A1. 2
scottishjohn Posted August 23 Posted August 23 this will be why my guys insisted on self levelling then grinding it and checking again the moisture content before fitting the LVT the lvt will only be about 3mm thick --so will follow contours if there are any and as with most things the the preparation is the important bit to get a perfect job 1
Spinny Posted August 24 Author Posted August 24 (edited) So flooring man came today. As expected he said my levelled floor was excellent (and he had congratulated the leveller) especially given what they started with (why would that make any difference TBH). And recommends leaving it as it is (no surprise). Although I don't swallow it, I am going to go with leaving the 'hill' now because at least it should be smooth and I don't want the sanding/grinding marks showing through like in the other spot. Where it is positioned it might put a 3mm fall on my dining table, but hopefully not a wobbly leg. LVT does truly show every flaw. Experience is the mother of wisdom - I'll know to be an insistent stickler next time, though there probably never will be a next time for me. The reality is likely that most customers never measure or consider the flatness of their floor - and thus standards are not always brilliantly high. Edited August 24 by Spinny 1
scottishjohn Posted August 24 Posted August 24 (edited) 51 minutes ago, Spinny said: The reality is likely that most customers never measure or consider the flatness of their floor - and thus standards are not always brilliantly high. thats down to the professional floorer to point that out --before he lays it maybe to afraid not to get the job if they told you the real story up front I measure a spare bit I had today -- 2.5mm --thats all so its not going hide anything when rolled down tight the thing my guys used looked like avery clean garden roller and it took 2 of them to lift in in another wee picture before they started laying the lvt -- they did it with skirting all fitted a picture i took today -nearly 2 years after being done Edited August 24 by scottishjohn 2
saveasteading Posted August 24 Posted August 24 On 23/08/2026 at 11:46, Nickfromwales said: contact details Thanks. We also have a good contact in Nairnshire. Seemed a bit amateur at first but doing the prep and pour himself ensured it was thought through. His oppos were entirely for carrying and cleaning up. But this time, I told them what they needed to know but it was either beyond their understanding or they didn't want to know. I'd have held money back but it's a democracy here.
Alan Ambrose Posted August 24 Posted August 24 I wonder whether you can grind and then fill the grinding marks. Car body filler comes to mind, although it’s a long time since I used that
scottishjohn Posted August 24 Posted August 24 (edited) 7 minutes ago, Alan Ambrose said: I wonder whether you can grind and then fill the grinding marks. Car body filler comes to mind, although it’s a long time since I used that his problem is poor preparation nothing else it needs to be flat like a slate bed from a snooker table -absolutely dust free before you start laying -- then it easy any imperfections in floor slab will show through using a hand held 9£ grinder will never work --needs to be the unit that looks like the old school floor polisher with extraction --big and heavy Edited August 24 by scottishjohn
Spinny Posted August 24 Author Posted August 24 (edited) 6 hours ago, scottishjohn said: a picture i took today -nearly 2 years after being done Looks excellent. Did you put a spirit level across it checking it yourself ? How flat do you reckon it is ? Edited August 24 by Spinny
Spinny Posted August 24 Author Posted August 24 2 hours ago, Alan Ambrose said: I wonder whether you can grind and then fill the grinding marks. Car body filler comes to mind, although it’s a long time since I used that Yes they have 'feathering compound' which they used in a few places. I think the youngster laying mine should probably have used some feathering compound on the grinding marks but didn't. I didn't see the grinder/sander being used but the machine was substantial and with vacuum extraction; I get tired of all the bullshit, salesmanship and and attempts at asserting authority over customers because - 'I have measured floors for 25 years and I can tell you this one is excellent'. I still think someone should make something like a robot vacuum that could crawl around a floor measuring and marking contour lines.
scottishjohn Posted August 25 Posted August 25 8 hours ago, Spinny said: Looks excellent. Did you put a spirit level across it checking it yourself ? How flat do you reckon it is ? flat as a pancake-- no swirl marks no dips they just did it the right way and used a proper floor grinder and over that length any undulations would show i did ask about non glued at the beginning and even wood flooring and they said with all the heat coming through the big windows would move and warp and fade over time due to the size 8m wide and 15m long
scottishjohn Posted August 25 Posted August 25 (edited) On 23/08/2026 at 11:46, Nickfromwales said: Then a different gang poured the screed and just moved it around...no level control. my screed contractor had little crab type things with adjustable pointers they put all over the floor - checked and adjusted with laser then started at one end levelled and removed them as they went all done in about 6hrs and last hour was spent cleaning out their equipment Edited August 25 by scottishjohn
saveasteading Posted August 25 Posted August 25 33 minutes ago, scottishjohn said: little crab type things with adjustable pointers I likd the crab simile, albeit 3 legged. I called them triffids. That is what the first guy (steading) did and must be best practise I'd say. I would do that. Given that the latest people didn't have them and didn't have a decoiler or fixing gun ( they used ours which i had bought with the ufh kit), I suspect they are one of these sudden experts, seeing a market and not knowing how much they don't know. Not everything was poor.. they set out and fixed the ufh pipes very well. 1
Spinny Posted August 25 Author Posted August 25 The flooring guy that did my levelling used small self adhesive sticks (see photo). Snapped them off to height and then stuck them onto the concrete surface, they then stayed there embedded in the levelling compound aftwerwards. These were his levelling guide. However... When setting out he used a spirit level and seemed happy as long as the bubble was 'somewhere between the lines' rather than dead centre. He didn't actually put that many level indicators in - may be one every 1.5-2m (I had to explicitly ask him to put one next to my floor length window). Using a level end over end across 8m is not that accurate tbh. I had taken quite some time using my water level to put reference marks around the room at skirting board level - but there was no interest in these and they were ignored. The pour was done straight from a mixing tub without a tipping frame or spout. The mixes were made up by the junior outside. They only had 2 mixing tubs. So it was gradually work across the floor pouring one while the other was mixed. The actual level was generally a little below the marker sticks (obviously if the pour went higher they disappeared and became useless as guides). For some reason the levelling compound dried to somewhat different tone/darkness on some pours - makes me wonder how consistent the water mix was. Though the second layer used a different compound with the liquid mix supplied with it - no water to add. A lot comes down to how patient, hard working, diligent and conscientious people are. From photos on their facebook page it looks like most of the time they are doing small rooms around 8-15 sqm, rather than my 38 sqm. The problem is most people have someone that gives a good sales speel, and a bunch of good online reviews, and photographs. Getting references out of most tradies always seems to be a challenge - 'I don't like to bother my customers with that', 'people don't want to be disturbed', it is on the website, all my mates haves posted 5* onto my facebook page, or just no response etc. If you are going to take every single trade, then contact 5 and get them come, look, get a quote out of them, get references out of them, follow up references including visits and impertinent questioning - well it is bloody hard work. One customer might be blissfully happy in their ignorance that their levelled floor isnt actually that level. No housewife uses a spirit level. 1
Spinny Posted August 25 Author Posted August 25 Am I doing the wrong thing 'letting them get away' with it here ? It is always hard to know.
Spinny Posted Thursday at 20:10 Author Posted Thursday at 20:10 Stupidity is as stupidity does. Nothing can go well, not even for one day it seems. Yesterday I spent a long day dry laying almost all the remaining 15sqm of my LVT in the main open plan area. It was a difficult process given that the Amitco unique image area is only 1.2sqm. Random laying does not work. You have to really try to avoid lots of identical knots, or identical 100mm planks, or all dark/light planks going down next to each other. And equally to avoid an overall look that seems to have an artificial or regimented arrangement. Imagine 150 planks, even 2 minutes each is 5 hours. Probably took me 11 hours including finding pieces to cut into each row end and labelling them all up by row and with cut position for the fitter. Everything ready, a simple jigsaw puzzle for the contractor to stick down today. He arrives, I briefly describe what I have done as prep, he nods and agrees, gathers up the planks by row and in sequence so he can start some polishing and a little feathering. Sparky arrives and I am busy with him finding bits, sorting smart modules, defining switch positions, next tasks etc. As flooring guy starts I glance over a few times, has laid 2 or 3 rows and it looks ok. Later in the day he has got to the last rows and I get a window to have a further look. Start noticing things - two identical knots right next to each other - and again - two identical planks alongside each other, a small area with 7 knots in it, 2 planks that were adjacent now separated. Turns out he decided for himself without any communication or attempt at communication that he was going to shift the position of every row 'to randomise cut positions'. Cut positions I had already randomised, and marked on the planks with tape. Somehow he had also rotated some planks 180 deg, used a plank from one row to fill in on another row. So planks shifted up to 900mm one way or the other, a row backwards or forwards, rotated 180, end pieces where a knot was being cut off shifted to include the knot/feature. Hence destroying the dry layout he was supposed to be sticking down. All my effort wasted. Nearly 6 months since I engaged these muppets to do my floor. Now it means them ripping many selected planks up again, removing the glue, me trying to find new/different pieces to fill the gaps and 'look right' (actually a harder task than free dry laying), dwindling stocks of remaining planks from the batch. And yet more delay. I am so so so angry. Give an idiot an incredibly simple task, and within 4 hours, they will screw it up and leave you far worse off than when you started. Rinse and repeat. Apparently it is called 'building'. Apparently you are actually supposed to reach an end point, however it is not logically possible. Never ever do it. 2
Nickfromwales Posted Friday at 00:47 Posted Friday at 00:47 If you want (need) to micro-manage at this level then the blame lands in your lap, sorry. You 1000% should NOT have had ANY other trade on site whilst the floor was being laid. You want things done in an extremely particular way, beyond the comprehension of most ‘typical’ trades, which means you need to engage in hand-holding; each plank laid down as you wish, then it gets drawn around with a sharpie, then each plank has a piece of masking tape applied so it is numbered, when lifted the number is written on the floor (inside the sharpie rectangle), and both are complimented with an arrow so the installer knows which way around to then fit each plank. Zero ambiguity, zero personal preference, zero chance of it going any other way. History keeps repeating itself here, so either change what you’re doing or don’t expect a different outcome. Sorry to be brutal, but without this info you won’t succeed. I am principal consultant on site currently and I take this approach with the trades that require direction from me. I explain that it may sound like I am teaching my father how to (expletive deleted), but that is how it is, take it positively or walk away. The good ones actually appreciate this as they can push back, stating that the additional quality etc will add time & money, which my client agrees to and accepts. Sometimes trades just need to know (be told) if it’s a sprint or a marathon. 5
Great_scot_selfbuild Posted Friday at 05:47 Posted Friday at 05:47 @Spinny really sorry to hear about this. I realise you’ve put a huge amount of prep, thinking and planning in advance, but could you live with it? I realised that you may not be able to ‘unsee’ what they’ve done, buy just a suggestion before you throw it all in and start ripping elements up: 1. Have a friend/colleague (who doesn’t know about the issue) visit and give their opinion on the floor. Try not to lead the witness, but invite them to cast a critical eye over it as you’ve been so close to the detail it can be difficult to step back and see the wood for the trees. 2. Is it flat? 3. What are the edges like? 4. Are there ripples/other aspects separate to the sequence and configuration of the planks? Building a house definitely comes with a free pair of retrospective 20:20 vision specs and ‘I wish I I’d just done … differently’. I’ve had my own experience of these. Just trying to offer an alternative way of looking at the situation - you may only see these details, but how important are they to resolve *now*? Obviously this doesn’t detract from the frustration of having briefed someone, checked understanding and been on hand for any questions / points to check and then had them just go and do this: 9 hours ago, Spinny said: Turns out he decided for himself without any communication … 4 hours ago, Nickfromwales said: If you want (need) to micro-manage at this level then the blame lands in your lap, sorry. @Nickfromwales Bit of a harsh opening line imho. 4 hours ago, Nickfromwales said: You 1000% should NOT have had ANY other trade on site whilst the floor was being laid. We’re a way off floor being laid, and I could understand that a glue-down floor can’t have anyone else who may generate dust / in the vicinity, but why wouldn’t you have any other trade on the whole site if they’re working in a completely different area? I could have easily fallen foul of this (but have taken note 😁) 1
