Ground bearing slab curing
Your biggest challenge will be to get the concrete in the right place, as once it is poured you won't be moving it.  If you can get the lorry near all the trenches, fantastic.  If not you would do well with a concrete pump - either boom or line type.  You will need minimum 3, preferably 4 people, plus the pump guy and concrete truck driver.
Work out exactly what you are doing before anything turns up.  How will the concrete lorries get in and out, traffic management etc.  6m is very wide to screed to.  Can you get some pegs in the ground as levels?
If there is a screed layer on top, the accuracy of the slab doesn't matter too much.
We don't know much about it at all!
The questions are not answered and I fear that the author doesn't know how much he doesn't know.
It is out of concern that I keep trying to help.
@flanagaj please explain what the construction of the floor is and what stage you are planning.
Apologies for the confusion.   I am merely talking about the ground bearing slabs and it has nothing to do with pouring the screed layer.
The slabs are basic.  150mm thick reinforced with A252 mesh and all prep work signed off by BC last Friday.  Slabs for house will eventually be covered with 150mm PIR, VCL and then screed.  Garage slab will be left as is and hoping that SCC will provide an adequate finish and negate having to use another finishing self levelling compound.  So just to reiterate and avoid confusion, this is simply about placing the concrete for the ground bearing reinforced slabs.
OK thanks. This is what I assumed.
It is a slab not a screed.
Flattish will do but it is a shovel, raje and float (or tamp) job, not tripods and dapple bar.
I suggest you bang some steel or batten in to finished level. Not best practise but pragmatic. You'll be too busy shovelling to check with a laser.
How many of you?
Quantity is easy as you have a simple shape and presumably a consistent level.
How many of you?
2 of us.  I think I'll be raking as SCC is too liquid to be shovelling.
I've never used SCC so perhaps others can advise of any special measures.
I.m guessing here, but perhaps a length of 2x2 would be handy to persuade it all the way to the far corner.
Any shuttering will be prone to leakage as will gaps in plastic.
Have you a plan for the surplus and the washout location? Wherever you tell them to put it, it will keep flowing!
If it is like pumped screed, it is like water until suddenly it isn't.
ripples won't matter at all but getting it level +/- 3mm is well worth while.
On 20/07/2026 at 23:38, Gus Potter said:
It's time son to get your big boys hat on and wake up and smell, the coffee.
This is tough love
12 hours ago, flanagaj said:
The concrete company I was planning on using wouldn't put anything in writing, so I've cancelled them and am going to pour SCC slabs myself.  Ordered the items below
Ok, my suggestion is that you don't rush this. It's a key step as if this does not turn out the way you hope you'll store up loads of problems that you'll have to deal with later.
The great thing about BH is that what your are doing is quite common and folk will fesse up the mistakes they have made, so you don't repeat them. We just want to help you out! There are few if any on BH that will relish hearing that it has gone wrong for you when we could have helped.
In that context. You say you have a ground bearing slab and that BC have signed off what you are going to lay your slab on. Thus it may be assumed that it is reasonably flat and level. But BC won't have checked this for you!  In general terms level means that what you are laying on does not vary too much from one end of the building to the other. Flatness is roughly a measure of call it "undulation" between often 3.0m points. A slab can be level for corner extremities but go up and down like a roller coaster in between. I suspect you don't know what tolerances you should be working to. This is your SE's fault possibly, it may be buried somewhere in you specification?
You say you have a 150mm thick slab. Roughly if what you are laying on is 15mm high in places then this can start to compromise the cover to the mesh. If the top side of your slab coincides with a high spot in the sub base it really eats into the performance of the slab as you are reducing what we call the effective structural depth. Ok your sub base is down now. We can have a look at how and where you finish the top of the slab.
Now as you are doing this your self I can tell you that slabs often end up high. Contractors, in  rush often leave slabs high also more often than not, bugger off and leave someone else to fix it. A over high slab impacts on everything that comes after.
But lets turn back to structural strength first and a bit of rough techy stuff. You SE will have specified a basic structural strength of the concrete. If they are doing their job correctly they should specify a level tolerance both on what you are laying on and the top surface. I do this as a matter of course,  it can go horribly wrong if you don't as you can end up with a slab that is only say 120mm thick in places.. and it's sods law that the thin bit will be under the point where there is a bit more load.
Your basic might be something like a C28/35 concrete, there are lots of way we can specify concrete. It's then up to you / contractor to find a mix that can be work into place / p[properly compacted to meet the level tolerances and concrete strength.
Basic concrete is made by mixing cement, concrete sand and water. When the water evaporates we have voids in the concrete, like the cell structure in wood. Thus we want to design a mix that is workable enough, but does not have too much water as this reduces the concrete strength. We call this the water / cement ratio. We measure how workable the concrete is by using often called  the "slump" test. Google this and read around. It will help you lots!
Now we can also add things to the concrete, other chemicals and powders which also can slow down how fast the concrete cures and remains workable. One easy way is to use what we call an air entraining agent, similar to Fairy liquid (never add Fairy liquid to any concrete of mortar mix, it's dangerous) , the bubbles of air make it more workable. Modern concrete mixes use other chemicals and agents that make the concrete more workable (basically lubricate the mix) but without reducing the matrix strength. You mention SCC (self compacting concrete) this is often also referred to as self levelling concrete.
But the big problem with SCC or other self levelling mixes is that they need to be handled by experts that do it day in and day out. They can very quickly "turn on the novice" within a matter of minutes. If they turn on you then they are totally unforgiving!
My advice is to look at a basic concrete mix with a bit more water, what we call a higher slump. Phone up a few suppliers, tell them what you are trying to do, your labour limitations, the weather you expect and the size and type of slab you are laying.
If you make the right approach nine times out of ten you'll find folk itching to help you out!
In my day job as an SE I often design quite "whacky stuff" I have a good basic knowledge but often find myself phoning the experts on a particular product to see where and when we can safely explore boundaries of design. I do check what they tell me, but I'm long past the point where I feel embarrassed to ask for expert advice, or just ask a daft question.
If it's ok for me to do it then it's ok for you to call up a few concrete suppliers and ask for help? You have nothing to lose but a bit of time.
You need to reflect on what you are doing. It's ok to take one step back to make two forward later.
My main motivation for using SCC was merely due to the following.
1)  Short of labour.  It's just my wife and I
2) Due to the bricklayer rushing ahead and not being very accurate, we don't have the ability to tamp, plus tamping is hard going when only two of you.
Why do you say SCC needs to be handled by experts.  I'm very curious as the video below suggests otherwise.  I appreciate that it's a marketing video, but I wouldn't say there's anything expert going on here.
It is self compacting, not self levelling.  No need to tamp but you need to place it to the correct level.  Do you have a boom type pump lorry?
We are concerned for you, perhaps unnecessarily.
It's what you don't say.
Can the lorry get close?
Can its chute reach nearly all the way so that you don't have to move it?
what quantity is it?
Is the mesh already in and has the bco approved it?
Are you both physically strong in handling the chute and moving it (it's very heavy esp with concrete in it. You'll be doing this while walking in wet concrete on a layer of steel mesh.
NB the driver does not help! He turns the delivery on and off when you shout. Later he washes out.
You've probably got 30 minutes from arrival to completion or they charge a lot.
you are going to get messy.
wellies, waterproofs, gloves.
After the concrete is in and the lorry gone, have you asked how long it is workable?
You have not got the time or luxury of using the laser.
there wont be any break time or rest for these 2 hours. have you a contingency if one of you has a problem?
Can you find a third person?
what is containing the slab? masonry or a shutter?   mark the finished level on there in advance plus some pegs in the middle.
Have you worked out the quantity exactly? what is it? how much have you rounded it up? the leftover is all going on your ground. 1/2m2 is a lot esp when it spreads or makes a solid lump.
and so on. expertise.  I have supervised maybe 300 pours from 4m3 to hundreds. I seldom handled the shovel. But I've seen it go wrong often. I've especially seen it go badly wrong on other peoples projects, esp by amateurs and poor builders, and it is a shame, a waste of money and can have knock-on effects.
to reiterate : It's what you don't say.
If you knew you wouldn't be asking, and you haven't asked the right questions.
My question and I wish I hadn't bothered asking was merely to understand whether SCC is a suitable choice for ground bearing slabs.  All of the other due diligence regarding shuttering / vehicle access / ensuring DPM is sealed with butyl tape and edges taped, mesh correctly installed, BCO signed off has been done.   Just for the record, I am not a complete muppet.
The truck can reverse right up to the slab area and with the 2.4m chute will pretty much be able to get the concrete into the middle of each bay.
OK. So good luck with it, and report back please, as I've never used SCC.
Yes.  I will report back, even if it goes horribly wrong.  Hopefully, it won't.  Would be nice if the weather a bit cooler, but I need to get the slabs down as I don't like leaving the membrane and still uncovered as one will degrade with UV and the other will just rust more.
Wednesday looks hot as hell, so worth avoiding.
That doesn't matter. In fact it grips the concrete better than non-rusted, and without water it won't change.
You have not read and taken time to read and understand what I have written.
Go back and read what I have written. Then take what I say and check with your concrete suppliers, seek advice. You may doubt what I say, but it would be a very good idea to check to see if I'm wrong.
We are trying to help you here. It's not my money, I and others are giving you this advice for free!
I do this stuff as a day job! I do the SE design, I kind of know how to do this. I've even written the structural calculations that go into some of the software packages that are used by the biggest supplier of cold formed steel buildings in the UK for their floor slabs.  At what point are you going to wake up and think that maybe myself and others kind of know what we are talking about?
If I was to bet on this I think SCC (self levelling concrete) is not your way to go as you are a novice. To hedge you bets and as you are not listening to the advice you are getting, what about just getting a part load and do one small slab to see how you get on.  This way you get to practice.
But I bet you have not taken any time to read the rest of my post about concrete strength ect. Look if you want to do this then it's you money. If you want to cut corners then fine, but it's false economy and your risk.  I suspect you don't even understand the risk element and the risk / potential cost balance and I'm absolutely sure you have no idea how anything you change may impact on structural safety.. you should especially if you have kids.
  • 2 weeks later...
So feel free to have a chuckle to yourself, but the SCC pour went really well and the stuff is absolutely amazing.  Slabs level to 2mm.  What didn't go well and this was partly due to a lack of information available and me not appreciating the associated risks of trying to pour slabs in weather that is so hot, was the curing.  Slabs unfortunately look like crazy paving.  Curing agent was applied, but when it states "immediately after finishing" they don't mean dappling and when the concrete is still fluid.
Cemex also advised that microfibers should be added, but then somehow didn't adjust the order (yes! I should have double checked) so that didn't help.  Having A252 mesh has probably saved me from having to condemn them.
But I would still recommend this can be done as DIY.  So long as you can use a laser level and set up screed levelling tripods, then you will be amazed at how flat and level you can get slabs just by using a dapple bar.   Just be careful of doing it in hot weather, as SCC has low water and a high cement content so not as forgiving as normal concrete.
Note - I purposely didn't dapple a shallow pass on this slab as the finish from the first pass was perfectly good enough for below PIR
As to pouring the remaining slabs.  Well.  I'm too nervous now.  Especially, given the weather and previous attempt.  Was considering using Hessian and water curing, but even then I am unsure.  It's 15c at 8am when I poured and by 10am it's absolutely roasting and probably 26c
Well done. If it is hard and flat you will be OK.
Thousands of tiny cracks will be better than a few big ones. Even with fibre you would have cracks.
Photo of the surface please?
51 minutes ago, Nickfromwales said:
The lads I watched were literally spraying immediately behind the dapple, as it was being worked along. Absolutely zero delay, and the stuff cured on top of the concrete like clingfilm PDQ.
So I did apply it correctly.  Maybe not enough or should have used a Wax or Resin based agent.
Well the SCC looks like it saved a lot of work.  Was it expensive?  Is the next pour to a different level?
I think there might be 2 kinds of spray or that could just be bull. I've had it before when someone has said ive put the good spray on for you in case tiling the floor or something. Maybe acrylic vs non acrylic?
As requested.  Here are some pictures.  I’m seriously gutted at how it’s cracked.  But it is one of those things and although I’ve done a garage slab before when it was 10C using traditional concrete and a poker and that had no shrinkage cracks.
the SCC was £178/m3
