Spinny Posted 17 hours ago Posted 17 hours ago Need to temporarily stop the solar gain throught my bifolds to keep the temperature of the floor down while LVT is laid. Looking at window film ? Wouldn't it best to put this on the outside though ? Silver side outwards ?
marmic Posted 17 hours ago Posted 17 hours ago anything to reflect will probably help and yes outside - but better to stop sun hitting glass at all. Brise soleil can take many forms. if only temporary a cheap gazebo outside maybe? but may be worth looking at something more permanent if solar gain in these heatwaves is an issue.
mistake_not Posted 15 hours ago Posted 15 hours ago An option (not saying it's good) is silver foil. Mist spray the glass with water from a sprayer and it will stick perfectly. Just make sure you don't scratch anything.
Spinny Posted 14 hours ago Author Posted 14 hours ago (edited) What about using radiator foil/insulation such as this ? https://www.amazon.co.uk/Radiator-Foil-Reflector-Roll-Metres/dp/B0FHX24FP8/ref=asc_df_B0FHX24FP8?mcid=105a35c7f1383e838b6a3496fbcbce8b&tag=googshopuk-21&linkCode=df0&hvadid=768395591032&hvpos=&hvnetw=g&hvrand=18110053046630382234&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006502&hvtargid=pla-2439067162462&psc=1&hvocijid=18110053046630382234-B0FHX24FP8-&hvexpln=0&gad_source=1 (I think any permanent solution will mean looking up what glass we had in the bifolds and rooflights. I thought it was UV limiting but really can't remember. We havn't got our electric roller blinds in yet and not sure how much effect they will have.) Edited 14 hours ago by Spinny
Russdl Posted 13 hours ago Posted 13 hours ago 3 hours ago, Spinny said: Need to temporarily stop the solar gain throught my bifolds to keep the temperature of the floor down while LVT is laid. If it’s just temporary then an old sheet will do, anything that will stop the sun hitting the glass will do. Long term, the sheet is probably not the best option.
Spinny Posted 13 hours ago Author Posted 13 hours ago Just now, Russdl said: Long term, the sheet is probably not the best option. Indeed, although we did have thoughts about putting hooks into the overhang fascia and having a triangular shade sail. Might be a pain if a wind gets up though ?
Russdl Posted 13 hours ago Posted 13 hours ago If you make it easily put up-able and take down-able it shouldn’t be a massive issue. Big heat (strong sun) normally coincides with high pressure which normally coincides with slack wind. At least that used to be the norm.
marmic Posted 1 hour ago Posted 1 hour ago just put some cheap car sun shades on windows (from halfords - cheaper than amazon etc!) - temporary measure until we decide how to build brise soleil. not going to block it completely but should make some difference. if they stay up!
Nickfromwales Posted 43 minutes ago Posted 43 minutes ago A chuffing tarpaulin. There, I said it. Have the installers asked you to do this?
