Alexphd1 Posted February 1, 2018 Share Posted February 1, 2018 My sister in Staffordshire has just had a eye watering quote to repoint a brick house from a "specialist". I haven't worked out the £m2 but does anybody have a guide, they have also quoted £10 per brick to replace any damages ones. Link to comment Share on other sites More sharing options...
Ferdinand Posted February 1, 2018 Share Posted February 1, 2018 2 minutes ago, Alexphd1 said: My sister in Staffordshire has just had a eye watering quote to repoint a brick house from a "specialist". I haven't worked out the £m2 but does anybody have a guide, they have also quoted £10 per brick to replace any damages ones. Expensive sister :-). Link to comment Share on other sites More sharing options...
Ferdinand Posted February 1, 2018 Share Posted February 1, 2018 Whatprice repointing page may be helpful. http://www.whatprice.co.uk/prices/building/repointing.html#axzz55sQrvmru Link to comment Share on other sites More sharing options...
ToughButterCup Posted February 1, 2018 Share Posted February 1, 2018 Ok, here's the national guide price as cited in SPONS page 226 (What's that? Click here) Per meter squared Labour: 0.69 m sq per hour Labour cost: £18.25 per hour Materials cost : £1.30 per m sq Local variations to those guide costs will apply. £10 per brick replace is a strong indication that they don't want the work, or have a substance abuse habit. 1 Link to comment Share on other sites More sharing options...
Alexphd1 Posted February 1, 2018 Author Share Posted February 1, 2018 Anybody any recommendations in Staffordshire? Link to comment Share on other sites More sharing options...
ToughButterCup Posted February 1, 2018 Share Posted February 1, 2018 7 minutes ago, Alexphd1 said: Anybody any recommendations in Staffordshire? Move. 2 Link to comment Share on other sites More sharing options...
Vijay Posted February 1, 2018 Share Posted February 1, 2018 Not sure a tenner is too much to replace a brick, it can't be too far off 1/2 hours work?? Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 1, 2018 Share Posted February 1, 2018 3 minutes ago, Vijay said: Not sure a tenner is too much to replace a brick, it can't be too far off 1/2 hours work?? Diamond rake in an angle grinder will zip a brick out in about 3-5 mins tops ( if they hail from this century ) ? Link to comment Share on other sites More sharing options...
Hecateh Posted February 1, 2018 Share Posted February 1, 2018 27 minutes ago, Nickfromwales said: Diamond rake in an angle grinder will zip a brick out in about 3-5 mins tops ( if they hail from this century ) ? This century as in 'the last hundred years' or as in 'since 2000' Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 1, 2018 Share Posted February 1, 2018 14 minutes ago, Hecateh said: This century as in 'the last hundred years' or as in 'since 2000' Errrrrrrrm, the one where brickies own an angle grinder with a diamond encrusted blade, as opposed to the one where they wear small triangles of fur and bash away with primitive tools ( probably made by Silverline ha ha ) 1 Link to comment Share on other sites More sharing options...
Declan52 Posted February 1, 2018 Share Posted February 1, 2018 24 minutes ago, Nickfromwales said: Errrrrrrrm, the one where brickies own an angle grinder with a diamond encrusted blade, as opposed to the one where they wear small triangles of fur and bash away with primitive tools ( probably made by Silverline ha ha ) That's why they will charge a £10 a brick. Hammering out each brick will break at least 3 silverline cold chisels. 2 Link to comment Share on other sites More sharing options...
Bob Posted February 1, 2018 Share Posted February 1, 2018 Reclaimed bricks usually 70p to £1 sometimes a little more depending what they need to match and the local availability 20 per hour ish for labor. The structure may need scaffolding which again increases the cost, it is allot of hard work repointing. I would get a few quotes from local builders and see how they compare. 3 mins to cut a damaged brick out is bloody fast if your using a grinder or not. Once you’ve cut it out you need to replace it and point round all in all it’s hard work. Then you need leave a few hours at the end of the day to wash every car in the street as the grinder will cover everything in dust. Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 1, 2018 Share Posted February 1, 2018 5 minutes ago, Bob said: Reclaimed bricks usually 70p to £1 sometimes a little more depending what they need to match and the local availability 20 per hour ish for labor. The structure may need scaffolding which again increases the cost, it is allot of hard work repointing. I would get a few quotes from local builders and see how they compare. 3 mins to cut a damaged brick out is bloody fast if your using a grinder or not. Once you’ve cut it out you need to replace it and point round all in all it’s hard work. Then you need leave a few hours at the end of the day to wash every car in the street as the grinder will cover everything in dust. Tres bien Rodney Link to comment Share on other sites More sharing options...
Nickfromwales Posted February 1, 2018 Share Posted February 1, 2018 In case anyone is confusing a little grinder with some gi-bungous petrol building slayer....... A diamond mortar rake which fits in a hand held 4"grinder. ? 1 Link to comment Share on other sites More sharing options...
Brickie Posted February 2, 2018 Share Posted February 2, 2018 Weather struck & cut -rake out & re-point £45-£60/m2. Those are the rates I see quoted on social media,varying by region. As for £10/brick,if supply & fit,prob about right. Yes,not long to rake joints out with grinder but cleaning all the old mortar out,damping down the dust,laying replacement brick,packing the top joint in,pointing & then brushing-as said,you wouldn’t see much change out of half an hour. 1 Link to comment Share on other sites More sharing options...
nod Posted February 2, 2018 Share Posted February 2, 2018 On 01/02/2018 at 19:49, recoveringacademic said: Ok, here's the national guide price as cited in SPONS page 226 (What's that? Click here) Per meter squared Labour: 0.69 m sq per hour Labour cost: £18.25 per hour Materials cost : £1.30 per m sq Local variations to those guide costs will apply. £10 per brick replace is a strong indication that they don't want the work, or have a substance abuse habit. Spons is ok as a guide for a trade working for a company. But most would find it impractical running a business based on £18 an hour. Most of the larger companies are paying bricklays that don’t want price work about £18 an hour Extra for weekend work Holidays paid Just turn up with a bucket of tools £18 is pittance if you are trying to run a business 1 Link to comment Share on other sites More sharing options...
