The display on my Zehnder Q350 shows the incoming air at 17.5 C but air entering rooms at 20 C.
Seems odd to me, is this normal or do I have a problem?
Set on 100% bypass ,cool temperature profile, Bypass on Auto.
Surely the air should be coming in at outside temperature?
5am and still 17.5 outside in a rural area.
Unit Currently showing
Extract air 25 C                        from rooms
Outside Air 21 C                       into unit
Supply  Air  22.5                      into rooms
Bypass 100%
230 CuM /Hr for a 210 Sq M bungalow
Edited by FarmerN
It is still coming through the fabric of the house so maybe it's picking up heat from the ductwork etc?
The figures are all taken from the MVHR unit display
I presume the sensors are all in the unit within plant room. I am not aware of any remote sensors.
That is a good point I had not considered.
If the main pipework is in the loft, which may be 40°C or more, then, even with insulated ductwork, it can easily heat up.
I have the Q450 the sensors are all in the unit, 1 each side of the heat exchanger on both supply and extract.
Mine is the same 100% bypass, I can't connect to mine to show the figures but was the same as yours earlier. I think it's probably the fan warming the air. The bypass takes it over the top of the heat exchanger to miss it.
I think if you look this afternoon it goes into reverse and closes the bypass when outside is warmer than the house.
