For those members who have a log burner what are the running costof timber fuel  in the winter on average per month?
Am thinking of getting  5Kw or possible 7kw log burner and want to have a rough idea if I was too run it every day for about 4 hours  for the winter months, so at least 4 months,  say November to February how much would it cost to purchase the timbers say per month on this basis?
On average if you pack the burner with timbers how long does 1 burn cycle last?
thanks
1 kg of seasoned hardwood has approximately 4.5 kWh of energy in it, when burnt in ideal conditions.
As wood burners are not very efficient devises, you probably need to halves that. So a 5 kW one will, if run properly, will take 2 kg an hour, but probably closer to 3 kg.
Burners can be adjusted to moderate thermal output, but that not only hurts efficiency, it also changes the combustion chemistry. Depending on the temperature of combustion, you also get varying amounts of particulates.
Then there is the land area needed to grown the timber.
A metre² of land in the UK gets around 950 kWh of solar energy on it, trees convert, at best, 0.25% of that to timber. So sub 0.2 kWh/year.m². So to run a 5 kW burner for 1 hour is going to take, at very best, 15 m² of land.
Then you got the timber transport, storage, conditioning and waste disposal.
Do you really want a wood burner. Most houses got central heating in the 1950s and 60s.
  • Like 3
We get through one bulk bag a month, bought four bags last summer @ £90 each. I used to get most firewood free from work and neighbouring woodland but only getting a few scraps now.
5 Kw Wood burner running 27/7 from 1st Nov. to Mid April  used about 8 cuM of home produced wood. Stove would be shut down on low burn a lot of the time.
Now GSHP UFH etc but still light a stove for 1-2 hrs in winter , don’t need it but it’s nice and we have the wood.
thanks
It's a bit like saying how much gas will I use. The log usage (cost) really depends on the house heat loss and how hard you need to burn. When we run our 6kW log burner, we run it at very low loads, one log at a time, so about 2 logs has burn time of 3 to 4 hrs, you may have a higher heat loss so run 3 to 4 logs and lots of air, so get through loads more than me.
Cost also depends on how you source the logs. We have plenty of wood from cuts down down the build so zero cost, except my time.
Way to many variables to give you a cost that is meaningful.
That is about 2.9 MWh of primary energy.
It was a very large 1890 built unimproved Farm house, took a lot of heating.
  • 3 months later...
thanks
Way to many variable, we can light ours it will run at min burn on one or two logs for several hours.  We would get through one bulk bag a year at most.  So depends on is this your prime heating method, heat loss , where you live - is ab12 referring to Aberdeen (shire) etc etc... We are AB32 but well insulated
Our neighbours have a log burner. They have a tipper truck full of logs delivered once a year. It then belches smoke and crap all winter while they keep windows open day and night. Thankfully our MVHR filters the crap before it enters our place.
30 minutes ago, NSS said:
belches smoke
So it isn't a modern or properly installed appliance. The good ones have secondary air flow which burns  the carbon remaining in the smoke. The tiny mount of ash provides additional proof of how much has burnt.
Actually the house is under 10 years old. I suspect it's more down to the way it's used, and whether the logs are properly seasoned. My point, however, was that it's clearly not needed to heat the property, or else the windows would presumably be shut tight, so the crap coming out of it is in any case unnecessary.
You may be able to make log burners that are relatively clean, but you can't guarantee the owner will use it in the way it's designed to be.
Edited by NSS
Depending on how you source firewood I reckon it's anything up to 22p/kWh delivered energy to the room. At least double gas price is safe to say.
If you really don't give a shite you can buy a tonne of coal for £440 for 8000kWh of energy in the shed. (It'll be less heat delivered by the time you in fumigate your self and the neighbours) It's about the same price as gas.
An A2A ASHP unit with a COP of 3 is amazingly the same price too.
TLDR. Bought firewood is expensive. Coal, gas and ASHP are about the same price.
When you look at the numbers, if you aren't getting the wood for free why would you bother.
But then again most boiler heating systems are set up so badly, they burn through gas at way higher rate than they should. So instead of learning how to set them up people buy a lot burner
Made me laugh - it was a sad laugh tho
How many people would consider setting up their heating system to be more efficient or even getting a heating engineer in to do it
Rads not balanced or correctly sized to the room, flow temps not adjusted with the season just set to a fixed temp and left there all winter - I've said it before but the move from non condensing boilers to condensing boilers was mostly wasted in terms of efficiency improvements for many houses in the UK because the rads stayed the same and so did the flow temps.
Talking through setting up heating with wife's friend earlier in the week.  4 bedroom 70s house, only have the lounge radiator on flow 75 degs. Set for a couple hours or in the morning and same at night, they are there all day. Boiler just short cycles as it can't get the heat away. Only two radiators engaged.
Got them to open most the TRVs to give boiler something to work against, heating on all day and said to keep reducing flow once per day until house doesn't heat up - then add a bit of heat they have a combi.
They had typical cold feet syndrome typical of radiators running stupidly high temperatures.
Most stupid thing, room sealed modern boiler and their plumbers said they need a vent through the wall because they had a boiler.
My sister in law is the same.  Complains heating is too expensive to use.  It comes on 1 hour each morning and one hour in the evening. Radiators too hot to touch.  The rooms heat up quickly, and then cool down again quickly when it goes off and most of the day the house is cold.
I tried suggesting we turn down the boiler flow temperature to something much lower and run the heating for longer.  She could check on her in in home display and see how much gas was used and see if it used more or less gas than the present scheme.  But she would not even let us try it.
"That is the way the plumber set it, so it must be right"
