2 hours ago, JohnMo said:
How it works, day time, bedrooms not used, trickle vents almost fully closed. Downstairs rooms have people so the vents start to open in response to rising humidity, fans draw the air across the room, through corridors and out the house. At night the effect swop, now bedroom trickle vents open and downs close. No-one in house, all trickle vents go to min opening
This is elegant at first glance. It might float your boat.. but I honestly despair at times.
You write a lot of good stuff John but what about say a young couple that come to buy your house. Will you make them aware of any potential maintenance issues?
Now you may have all your faculties at the moment and I'm sure you think this is your forever home, but when you get less "sharp" and need folk to maintain your house who may be less dilligent.. what then?
I totally get that your house is your hobby.. but in my day job I need to give Clients best advice. That includes protecting their asset.
I do love you technical grasp and hope you don't mind me taking a more general view.
Absolutely nothing wrong with a dMEV system, what maintenance, there is none? The trickle vents are controlled by a membrane that contracts or expands to variable moisture levels, zero inputs from anything else. The fans are commercial available bathroom fans. Greenwood make a nice one, but many others available. Way less maintenance than MVHR.
Zero faculties needed, fit it walk away. That cannot be said or MVHR as you need to change filters etc.
Same as any other house, I have owned around 10 houses, no one has ever told me anything about maintenance ever. But as said above dMEV, what maintenance?
