Hi guys
I'm rewiring my 177 sqm house. I will carry out first fix.
Electrician to make final connections at consumer unit.
I would be gratefully if you could give me feedback on my circuit design:
🏠 SOCKET CIRCUITS
1. Ground floor ring (32A)
lounge 1
lounge 2
hall
WC sockets
One external socket at front of house.
2. Kitchen ring (32A)
all kitchen sockets including oven.
One external socket at rear of house.
3. First floor (32A)
Bed 1
Bed 2
Bed 3
Bed 4 (extension)
Bathroom
first floor landing
home office (light load)
4. Loft ring (32A or radial)
Bed 5
loft office (light load)
Loft bathroom sockets
5. Outhouse radial (20–32A SWA)
36 sqm outhouse
One external socket.
6. Basement sockets (20–32A)
2 rooms, currently damp. To be waterproofed within the next 10 years.
Most critical infrastructure here. Eg router
🔥 HIGH LOAD / INFRASTRUCTURE CIRCUITS
7. Cooker (32–45A radial)
8. Heat pump (dedicated radial)
9. EV charger (40A dedicated)
10. MVHR (small dedicated supply / FCU)
11. PV inverter AC circuit
grid-tied feed into CU
protected by dedicated MCB/RCBO
12. Battery storage system feed
13. Fire Alarm (6A Radial)
14. Security PIR (6A radial)
💡 LIGHTING CIRCUITS
15. Basement lighting (6A)
16. Basement Emergency light at consumer unit (6A)
17. Ground floor lighting (6A)
18. First floor lighting (6A)
19. Loft lighting (6A)
20. External lighting front and back (6A)
Is any of the above insufficient or overkill?
Thanks in advance
P
Are you intending to have a hob - that will need its own feed.
What are these for - bathrooms have very specific restrictions?
We have been in our new build for 2 years.
Wiring I wish we had done different.
External lighting done with the wrong cable for PIR lights ( 2core used should have been 3core ? )
Only got rear external sockets , used a  lot but should have had one at front as well, perhaps by EV charger.
Wiring for towel rail did not allow for timer.
Things I like.
2 consumer units only one supported by battery in event of outage, so heat pump and towel rails do not drain battery. Because of automatic gateway often do not realise we have a power cut.
5 amp lighting  sockets for side lights in lounge , hall and kitchen family room, switched by door.
We put high level sockets for extra bathroom heat, been here 2 winters and not used them, but who knows when I’m 90 ( a bit too close for comfort)
Put small distribution box in Garage, so easy to take an extra feed to greenhouse or summer house etc.
Edited by FarmerN
Wish we did electric towel rails, so we could warm towels in shoulder seasons when we don't have the heating on.
We wired CAT6 everywhere which worked very well.
Sockets on walks for wall mounted TV we did which also worked well.
Circuit 7
We like to have washer dryer in bathroom. I know sockets and appliances need to be positioned in the right zone.
This sounds interesting. Can you tell me more please. How does this work exactly?
Thanks again for all the comments.
Put the washer & dryer on a dedicated ring and take the outside socket(s) off that. Feed the outside sockets via a 20a DP switch, off that ring, and if there’s any issue (damage or water) to the outside socket you can isolate it; the washer / dryer can carry on being used then without the RCBO tripping. Treat both of those bathroom power circuits as the ‘utility ring’, extending it to the loft.
You want anything outside segregated so any issues you may have outdoors won’t take anything indoors with it.
Have the basement emergency light fed off the basement light loop, not off a dedicated breaker, just way OTT to segregate that; it’ll have the same functionality that you seek.
I’d put another em lgt on the first floor landing close to the stairs to allow someone to come down safely from the upper level in a power out, as I have done here. You can convert almost any generic light fitting to an em lgt with an add-on pack.
1 hour ago, Pappa said:
Circuit 7
That will do a hob or large oven.
Single ovens and fixed (integrated) microwaves both need dedicated circuits, whereas a ‘loose’ microwave sat on a worktop doesn’t.
CAT6 to all TV’s, solar inverter, desktops, network printer, and WAP locations. Include duct grade CAT6’s to the outbuilding (garden wifi) and EV charger location.
Consider xmas lights, and a single socket (where a chuffing airwick will live forever) and also which ones would be useful if it’s a USB double socket; buy a tidy high-powered one if charging a tablet is a must at the bedside(s) etc. Saves losing a socket outlet everywhere you need to plug a charger in.
When did this come in? In my flat the integrated microwave is fed via a fused isolater off the 32A ring. Does the fused isolater count as a dedicated circuit in this case?
* The microwave has a normal 13A plug on it
I'm not an electrician but something I've seen elsewhere is to not install any rings. Make them all radials. Might be a bit more expensive in wiring (4mm vs 2.5mm) or from having 2x20A radials vs 1x32A ring but makes testing and future changes simple.
If you want to be able to put in any smart light switch modules at the light switches then putting in oversize/deep back boxes is goint to help a lot.
Second fix, but you might want some smart sockets in due course - e.g. for the outside sockets to turn Xmas/Garden lights on/off remotely from inside the house, or in awkward to reach locations.
Cabling and transformer niche's anywhere for LED strip lights ?
Wire for a video door bell ?
And the non leccy stuff - cat6, speakers cables, HDMI, telephone (though POTS is dying), fibre internet connection.
Run conduit where feasible
Are you going to have a small network rack/cupboard/shelf anywhere ? (Router. switch, NAS, assorted hubs)
Edited by Spinny
  See Thread        Wiring for freestanding lights?
Edited by FarmerN
I'd be spitting off the oven (due to the potential load) and fridge/freezer (to protect the contents if the ring trips) onto separate circuits.
Been 'a thing' since the 18th iirc.
No, a dedicated RCBO and a single cable to an FCU is required for an integrated microwave, but things like Quooker taps and warming drawers can go on a ring main socket.
Oven cannot go on to a ring main, again ( @Pappa ) this needs a dedicated RCBO and it's own cable to an isolator.
Not heard this, and I would not be doing 4mm radials unless someone had a gun pointed at my last beer in the fridge.
Thanks guys
I will put in an extra circuit for oven.
Any thoughts about external electrics?
In my original plan, I was thinking of appending an external socket onto kitchen ring and an external socket on to ground floor ring. Also a dedicated circuit for external lighting that combines both front and back.
Does this sound sensible?
I don't want the external sockets to trip my kitchen circuit or my ground floor circuit.
Same question regarding lighting... Should front external lights be on the same circuit as rear external lights?
Or stick them with the ground floor lighting circuit?
I could easily create more circuits...
20a Front external socket radial
20a Rear external socket radial
6a front external lights
6a rear external lights.
However is this overkill?
Thanks again.
I recently ran a 4mm² radial in the garage, a couple of double, metal clad sockets under the cu culminating in an outside socket. Only because I didn't have any 2.5mm² swa but I did have two full rolls of white FP200 Gold I got FOC.
We have this in our current place - all as switched fused spurs. Proper outside sockets are fairly reliable, so shouldn’t be a problem. The outside BG sockets have their own rcds.
Century? I wonder what the logic is as a typical microwave is ~1kW and a Quooker is ~1.8.
Edition (of the regs).
I'm curious of the reason too. Built in microwaves are more likely to be combination units (with oven as well) and microwaves are also relatively inefficient so they consume a lot more than the output power rating might suggest. But still, if it's not a combi then its continuous draw shouldn't be much different than a powerful kettle. (I can't think of a use case for a microwave that demands full power for more than a few minutes).
All the built-in microwaves I see have a factory fitted moulded 3 pin plug.
