Mate has just been touted by a company called Solaredge. He already has 8 PV panels and a Sunny Boy inverter.
This bloke wants to sell him 8 optimizers and a new Solaredge inverter for £4K.  This on the basis his old inverter is only 85% efficient and the new Solaredge one 95% efficient. They'll buy back his Sunny Boy for £500 so £3.5K all in. Rekons it'll make his system 25% more efficient overall.
My mate then rang the crowd who did his panels then latterly storage batteries and they've said they can do the same thing for £2.5K.
All sounds b@llocks to me?
Made the mistake of telling the second lot he's needing a new boiler so they're now after selling him an ASHP.
I suggested Sunamp?
Have they done a full and proper annual generation prediction comparing the two systems? If not, where has the 25% come from? My guess is that it's just sale BS, and that if pushed they won't put anything in writing.
The main reason to consider microinverters or power optimisers (Solar Edge is the latter I think) is if you have a lot of shading. If he doesn't, then I can't imagine that it makes any sense to change. He'd have to look at the maths, but the payback period will be woeful, especially on a relatively small system like his.
Not in shade. At the top of a hill in fact. He has a history of getting conned!
In April 2016 he had EnergyTarget fit 3 extra panels taking him to 8 and a storage battery. £5K.
I think it's them just quoted the £2.5K above and pushing the ASHP.
Solaredge is good, but he is being snake-oiled. Perhaps their business model is creaking?
As a marginal benefit on a new install it can be a significant benefit at maybe £25 per panel if eg shaded. Plus the inverter may cost a bit extra over the equivalent. That could be a good option.
As an aftermarket wonder product. No.
Would this impact on his existing payments?
Ah yes, I believe you've talked about this guy before. Never met a door to door salesman he didn't like!
  • Like 2
This from another forum and a bit of a guru for all things solar imho:
I'll keep it simple - GARBAGE.
Unless he has a very old inverter then the Euro-efficiency rating is 95% for an older Sunny Boy. (unless he has a  very old model which isn't 'transformerless' ).
Optimisers can only add 25% if there are serious shading issues. Even then Sunny Boys have a feature called 'Global Optitracking' which is a shade compensation algorithm. I did have a report on optimisers versus a standard inverter from an independent tester called Photon International (German trade magazine) They can impove output when shading is an issue, but the report used a Grade B inveter, SMAs are 'Triple A' rated, and even then the gain wasn't as high as 25%.. Now optimisers are around £30each, a solaraedge inverter around £800, so that's about £1040. Scaffold, say £600, so that's £1640 - you can pay me £1k to fit it if you like - think that will cover my diesel :slap
A new SB is around £750 if you want the latest spec which runs at 96-98% efficiency at all but the lowest light levels. There's also nothing to stop you doing this work yourself anyway. Somethig like a Chinese Solis inverter is about £600 fitted - doesn't have shade compensation, and won't last as long, but efficiency is on par with SMA (more or less). I'm guesiing tht he has about 2kW of panels,, which should output around 2000kWh per year, so assuing the high original tariff of around 50p, then even if he did get 25% more that's worth about £250 per year, so even at £2.5k, that's 10 year payback.
I've attached a Photon Report - it wasn't the one I was looking for and it's annoying as it doesn't say what the base inverter was. NB where there is no shading or even if the panels  are dirty there can be small performance increases as the system doesn't have to compensate for differences in the panels themselves. I do fit Solaredge where shading is notable, btu other than that the additional cost does not merit the outputs gained.
solaredge-case-study-photon-power-optimizers-1473941071.pdf
So the man came round....from Think Green Energy. Didn't have any brochures or even leave a card.
Seemingly they felt an ASHP was the wrong thing as quite expensive so he tried to sell them a "pv optimiser that limits the voltage going to the inverter". British made in Sheffield. He showed them a photo of a burnt out time clock that was running on 240V instead of 230V! This makes them overheat and give up. AND it would prolong the life of the inverter.
£2500 in the sale that ends today funnily enough!
If he doesn't take his commission he could do it for £2100!
The bloke was there 3 hours!
Amazingly my mate didn't go for it!
  • Like 2
If they are an MCS company, I think they can be reported for that sort of thing.
Not that it would do any good.
Have you spoken to your mate about Bitcoins ;)
Edited by SteamyTea
Trying to source some shiny glass beads at the mo! :)
https://www.thinkgreenenergy.co.uk/
"It all begins with a quick consultation" :):):) then 3 hours later the **** is STILL there trying to get you to sign up!
Edited by Nickfromwales
On 1/29/2018 at 22:55, Onoff said:
I'm going to try and get him to come down to Build It Live at Detling and talk to @AndyT
I would be pleased to chat
People on the 45p/kwh tariff, this may make sense for, for everyone else, just make a consideration when your inverter goes pop, and get the best one which is reasonable in price at the time.
He is on the highest tarrif having been an early adopter of PV.
2 hours ago, SteamyTea said:
Ask him to add up all the money he has spent in the last decade on his 'investments'.
Then work out what he could have done with the cash instead. ;)
PV, PV batteries, funeral plan, 2G windows and doors...to replace existing 2G windows and doors.
(His old front door now my new back door! :) ). Annual Internet support, hot tub...paid CASH???
