Great_scot_selfbuild Posted April 8 Posted April 8 I'm looking to make sure we document our electrical design and detail of all the layout. I have a very useable and functional method I'm using at the moment, but would like to know what it 'should' look like. We have a principal designer and this detail is exactly what I expect to be provided, but I'll be honest - on some of the nitty gritty drawing detail like this, I think it may fall short of expectations. Hence, I'm interested in: 1. Is there a layout / standard style that an architect would produce (to be clear, our PD isn't an architect - we couldn't afford to use our architect from planning phase for the construction drawings). 2. Are there other methods that anyone has found to be preferable / useful / look good. Thanks
ProDave Posted April 8 Posted April 8 When I have been wiring a new house for the client, the first thing I do is go round with a tape measure, a big black marker pen and put a cross on the wall where all the sockets etc will be according to whatever drawings I have been provided with. Then I walk round with the client and discuss their needs, wants and preferences. Invariable most of the socket positions get changed as do lighting positions. As to kitchens. I have yet to see a new house built with the kitchen layout shown on the plans, another thing that gets changes as things evolve so don't even start the wiring for that until the kitchen is on order. What I am saying is don't get over excited about drawing plans. Unless you are the unusual client where nothing changes when you see the building for real.
Bramco Posted April 8 Posted April 8 Agree entirely - I could send ours through but everything changed - well not quite but a lot did, re position of lights and switches. Like @ProDave says, we went round with the contractor marking up the final position of switches sockets etc. Quite a lot stayed the same though, but this was mainly things like the position of the switches and controllers for the rooflights and external blinds and the kitchen electrics. You do need something though to get trades to quote from. I wouldn't think that changes in position of switches, light fittings etc. should matter but adding or deleting them should increase/decrease the bill. An electrician would need to know about appliances (ratings) and where they will be, so kitchen, as well as things like ASHP and MVHR. They need to spec a big enough CU with components. Use your floor plan and mark the expected position of switches, light fittings and sockets and get the specs for all the equipment like MVHR, ASHP, etc. and also the kitchen appliances.
joth Posted April 8 Posted April 8 7 hours ago, Great_scot_selfbuild said: I'm looking to make sure we document our electrical design and detail of all the layout. One question is your priority documenting if for quotation, construction, or post-completion maintenance purposes? My experience so far is: - For quotation a comprehensive schedule (Google Sheet) of fittings (type, room, wiring required) is sufficient, and indeed preferable to detailed drawings for the reason Dave lists. - For construction, drawings with plans and where relevant elevation show location of each fitting is necessary, but often sockets and lights gets moved about during 1st and even 2nd fix. - For maintenance, ideally one would also have drawings showing the hidden pipework and wire routing. Realistically this would HAVE to be done after 1st fix (but before walls closed) because I've never yet met a trade that will actually follow plans: often times unforeseen practicalities means they can't, but in all cases they will have their own habits and preference and just do it the way they think it should be done rather than how any plan says it is to be done. And in practice I've yet to see anyone actually create such plans: there's too much rush to get started on boarding. These days your best bet is some comprehensive photos (360degree camera is ideal) of every surface of every room. The exception to all the above is if you're literally doing it all yourself in which case you can control a lot more! 1
Spinny Posted April 8 Posted April 8 (edited) Extract from a tender drawing attached. Not sure where the list of symbols comes from. We marked up a drawing ourselves with what we thought we wanted having been told there would need to be an electrical plan to quote against. Our architect, and I guess many, did not offer any kind of lighting design service. Architect did put us in touch with an M&E specialist that I had a chat with but ultimately decided to do without. He seemed to cover the full monty of building M&E from a full life cycle perspective, i.e. considering maintenance as well as design and install. e.g. How are you going to clean your rooflights if you have a roof you cannot stand on, and no window to climb out onto the roof from ? As said above the plan tends to change with first contact with the enemy, but as with the military only a fool has no plan and it is the planning process that counts and helps as you see the shell and make changes. We ended up with our own directly contracted sparky and his quote had a cost per switch/socket type breakdown, but in the end it got messy and we just paid him as we went on a time and materials basis. BIG TIP - Make sure you marry up your lighting plan with the structural engineers beam and joist plan. I think almost no-one does this, we didn't. But you can't put a downlight into a steel beam, or a ceiling speaker into a joist etc. Can get bloody complicated staring up at the actual beam and joist layout and trying to work out how the hell you can distribute your lights sensibly. Got the chippy to modify some joist work to make room for lights over the worktop. Had a LOT of seperate lighting circuits and switches and roughly twice as many downlights as attached. Made my own numbered list of lighting circuits and stuck a square or oblong of alu tape on the wall where we wanted them with circuit number for each switch. I think lighting is difficult - lumens/sqm, beam angle, colour temperature, CRI, circuits, layout, dimming, CCT, baffles, plaster-in, led tape. PS don't forget garden lighting. Edited April 8 by Spinny 1
mjc55 Posted April 8 Posted April 8 electrical symbols are a fairly standard set of symbols. My Architects Pocketbook lists them and they were what I used when I did my drawings as an Architectural Technologist. 1
Great_scot_selfbuild Posted Friday at 09:08 Author Posted Friday at 09:08 On 08/04/2026 at 16:59, joth said: One question is your priority documenting if for quotation, construction, or post-completion maintenance purposes? @joth I’m just returning to this, and hadn’t realised I had failed to respond / thank those who replied. To answer your question, it’s mostly for myself to learn what the ‘proper method’ is as I go - I’ve a very practical method that is working, but I’m keen to use this whole process as a means to learn along the way, and wanted to know if there was a recognised format or style used by M&E designers or architects (I’m finding that the details such as this appear to be outsourced by architects to those who specialise in the different aspects of the build. @Spinny thanks for your reply & the photos - especially useful and similar to ones I’d found elsewhere. This is along the lines of how I’ve done my own annotations on our plans. Since I posted this question I have moved a long way along our first fix and electrical plans are much more mature. Maybe this time I’ll actually write a blog post! 1
Mike Posted Friday at 17:08 Posted Friday at 17:08 (edited) 8 hours ago, Great_scot_selfbuild said: I’m keen to use this whole process as a means to learn along the way, and wanted to know if there was a recognised format or style used by M&E designers or architects Out of interest, in addition to the architectural electrical drawings mentioned above, in France you also need schematic electrical drawings. They're normally drawn by the electrical contractor as part of their contract. Without it the Electrical Inspectorate won't test the installation and, without their certificate, you don't get a mains connection. It's also used for subsequent maintenance. Example below for 1 row of my consumer unit (still in draft, which is why there's a duplicate D2.1): Edited Friday at 17:12 by Mike 5
Great_scot_selfbuild Posted Saturday at 16:46 Author Posted Saturday at 16:46 23 hours ago, Mike said: in France you also need schematic electrical drawings. They're normally drawn by the electrical contractor as part of their contract. Without it the Electrical Inspectorate won't test the installation and, without their certificate, you don't get a mains connection. It's also used for subsequent maintenance. Example below for 1 row of my consumer unit (still in draft, which is why there's a duplicate D2.1): What a great idea. I do like this, especially from a future owner / maintenance perspective. I suspect in the UK it would really sift out the good from the bad (would never be taken up as policy though).
Spinny Posted Sunday at 08:58 Posted Sunday at 08:58 Has anyone ever had an electrician or a plumber that did drawings or sketches of what they proposed to install, or indeed did any drawings or sketches of what had actually been installed (which can differ from any original design) ? Has anyone ever known a house builder that provided as installed electrical or plumbing drawings ?
Alan Ambrose Posted Sunday at 10:32 Posted Sunday at 10:32 Not sure that Mike's example leaps off the page, but it's a lot better than zilch. I'm planning on labelling the end of the cables with a shrink wrap labeller, which should help a lot - ever found a misc T&E and wondered where it ends up?.
Nickfromwales Posted Sunday at 10:38 Posted Sunday at 10:38 4 minutes ago, Alan Ambrose said: Not sure that Mike's example leaps off the page, but it's a lot better than zilch. I'm planning on labelling the end of the cables with a shrink wrap labeller, which should help a lot - ever found a misc T&E and wondered where it ends up?. Which is where a tone generator comes into it's own. Check for zero volts, check for zero continuity between conductors, then attach the tone set and you'll find the other end in minutes; even gives a feint tone when the cables behind plasterboard. When you find the cable, short out the conductors you put the set onto, and the tone goes silent to confirm 100% that you have the right cable (tone can be induced into adjacent cables when these are grouped). 1
Great_scot_selfbuild Posted Sunday at 15:19 Author Posted Sunday at 15:19 5 hours ago, Alan Ambrose said: Not sure that Mike's example leaps off the page, but it's a lot better than zilch. I'm planning on labelling the end of the cables with a shrink wrap labeller, which should help a lot - ever found a misc T&E and wondered where it ends up?. My wife & daughter have done a cracking job with white elec tape and permanent pen labelling ready for the electrician. They all match up with our floor plans that I’ve annotated on Procreate (iPad app). I plan to label them at the end with dymo tape printed labels, as I have found ‘permanent’ pens are often not what they claim to be 😂. 1
joth Posted yesterday at 09:01 Posted yesterday at 09:01 23 hours ago, Spinny said: Has anyone ever had an electrician or a plumber that did drawings or sketches of what they proposed to install, or indeed did any drawings or sketches of what had actually been installed (which can differ from any original design) ? Has anyone ever known a house builder that provided as installed electrical or plumbing drawings ? Almost. I worked on a project with a large London based passivhouse building and their preferred electrical contractor. The contractor actually had office staff updating autocad drawings, but this was mostly architectural for placement of fittings, not wiring or electrical schematics. The builder promised a comprehensive set of drawings of all M&E, but it never materialised. In fact as they had 2 different plumbers work on it (one doing the pre-slab unground routed pipes and another on 1+2 fix) without any drawings, they ended up with some duplication of pipework and I had to help them diagnose and remove redundant loop in the system. In the main post-build user & maintenance documentation is still a very unsolved problem, even on high end builds I like that French system, the schematic looks very elegant with neutrals omitted, but in a modern build using RCBOs would be a lot more busy. 1
Mike Posted yesterday at 13:00 Posted yesterday at 13:00 3 hours ago, joth said: I like that French system, the schematic looks very elegant with neutrals omitted, but in a modern build using RCBOs would be a lot more busy. The neutrals & earths are there, but indicated rather than individually drawn: I don't think RCBOs would make it more busy (they would take the place of the breakers, marked D2.1, D2.2, etc.), but there would be some differences. A UK build using rings would normally be have fewer circuits, but with more on each. Radials are required in France and the number of outlets / points / devices per circuit is also limited limited - for example power circuits are limited to 6 / 8 / 12 outlets (where a double outlet counts as 2, not 1), depending on location and whether 1.5 or 2.5mm² wire is used. So, barring late changes, I'll have 28 circuits.
Spinny Posted yesterday at 14:55 Posted yesterday at 14:55 On 23/08/2026 at 12:32, Alan Ambrose said: I'm planning on labelling the end of the cables Yes, my electrician was working with another mate that did most of my first fix. They tend to write on the end of the cable with a sharpie, which can be tricky to read sometimes months later and gets cut off at second fix. I have been sticking coloured labels on speaker and network cables. (Maybe scope for someone inventing a clever labelling gizmo.)
