Where to start. I'll try to set this out logically. I thought I'd landed on a plan for how to go about the ASHP (and by close association, UFH), but as we're now going for a smart home using KNX, the ASHP we were looking at doesn't have native KNX integration and so I'm taking a fresh look at this.
Many of my issues chime with that of ___ in this thread - https://forum.buildhub.org.uk/topic/46547-how-can-i-roughly-calculate-ufh-output-at-given-flow-temps/
Bottom-line:
  1. We need an ASHP, 300L DHW cylinder and UFH design.
  2. Passive-level of insulation & air tightness (MVHR planned - DIY, Zehnder Q600). Ground floor height = 3m, First floor is into the roof space (steep pitch) - ceiling = 4m. Open void at the entrance to a double-height space.
  3. UFH - 111sqm ground floor only, single zone, spiral pattern, multiple circuits. Upstairs will have electric towel rails and UFH mats in bathrooms just for the ‘warm floor’ feeling rather than to heat upstairs. I’d like to vary the spacing so that the single zone system heats the rooms at a different emitting rate (bear with me) - the thermostat will only be set in one location, whilst there are 5 separate areas (living room - no opening window), study (small, has an opening window), hall (massive tbh), WC (tiny), Utility room (clothes hanging to dry), Kitchen/diner (massive and huge sliding doors). I’m suspecting that I may struggle to get this ‘done the way I imagine it could be’ as all the companies just roll out a default - same spacing everywhere plan.
  4. AC - detailed modelling shows we don’t need cooling, but we’ll install power to the locations where an AC unit could be installed, but we plan to live in the house without it. Shade is ‘not a problem’ we have plenty.
  5. Smart home integration - we’ve managed to get a KNX designer on board at a manageable cost and so want to ensure we can integrate the heating into it as the KNX controller could negate the need to duplicate having an ASHP controller separately. KNX is a protocol rather than proprietary system and so is widely compatible, but I’m looking to choose one that is directly compatible rather than via a 3rd party controller; I understand Vaillant and Panasonic are just 2 examples that are compatible.
  6. ASHP - I’m no plumber and lots of threads (here and elsewhere) refer to ASHP only being any good if they’re set up well, and getting someone who knows the specific make will know how to get the most out of it etc, etc. I’d love to learn this stuff, but I don’t have much time and this feels like something we should be getting done by an ‘expert’. The plumber (via our builder) doing the rest of the house is not familiar with ASHP and just needs a flow and return to connect up our UFH, but his only experience is system that have a buffer and when I started describing having a simple / optimised system with no buffer, it wasn’t clear to him. He’s clearly practical at all other aspects of the plumbing, but not one for designing a system.
  7. We’re approaching the point of laying floor insulation and being ready for UFH will be straight behind that. I’ve got UFH quotes for design and supply, but I’d prefer to  need a plan, and the relationship between the UFH.
Options (there are undoubtedly more that I can’t think of - it’s late…):
  1. Contract one company for ASHP design, supply & install, with UFH design & supply (some of the MCS quotes have insisted on having upstairs emitters as the calcs won’t work otherwise (apparently - I’ve got no way of knowing if this is correct).
  2. Rely on my heat loss spreadsheet calcs, purchase ASHP direct from a supplier (not sure how to install - is it as hard to set up as I’m led to believe?, do they come with instructions), get a company to design & supply UFH, lay the pipework myself and get our plumber to help connect it up, if we need.
  3. Something else?…
Grateful for your collective advice on ASHP options that will be KNX compatible, and how to go about our design/install.
Our journey so-far:
Pre-buildhub days:
NSBRC, Architect recommendations… approach ‘Renewables company x,y,z’ Single ‘do it all’ coherent blah, blah, (all sounds great until the crazy quote eventually arrives).
Oh, how little we knew then!
Local self-builder:
Sheer luck, came across a local self-builder whose build was almost the same SQM, very similar passive-level performance, UFH downstairs only and only needs a 5.5kW ASHP (Samsung). This gave me a yardstick for what we would be expecting.
Initial research:
ASHP theory, all quite straightforward (in principle - reverse fridge etc…).
Find a local ASHP firm that had a good sales pitch, MCS registered, quote didn’t take the ****, but scratch the surface and they really didn’t know the maths and understand WC curves and flow rate details. Seemed to very much be a UK office where ‘technical’ was more on the practical installation rather than actually calculating how the setup should be done.
Buildhub reading began in ernest:
Jeremy’s heat loss spreadsheet - https://forum.buildhub.org.uk/topic/439-fabric-and-ventilation-heat-loss-calculator/#comment-4407 (everyone seems to find their way to this eventually; I put this off for a while tbh, I deal with too many spreadsheets at work, I wasn’t actively searching for more). Measured everything up, ran the numbers, ~4.5kW before factoring in DHW.
Quotes:
Throughout this journey we’ve had blips of focus at trying to ‘commit’. We’ve had quotes proposing 14kW (WTF!), lots of default ‘buffer + pre-plumbed cylinders, no questions about UFH’ and the list goes on.
Who to trust:
I really struggle with working out which company actually has the competence to *design* the ASHP & DHW cylinder installation optimised for our build.
DIY vs MCS:
As I’ve learned from threads on here, the cost of parts can completely negate any benefit that the MCS grant suggests. There have been 2 quotes that have actually brought the cost down to zero/near zero through an MCS umbrella company, but I seem to recall there was another reason they put me off (will have to dig through the quotes & emails…). I would much prefer to have a system that we have someone to go back to if we have a problem (plus I don’t know if our building warranty will want some guarantee behind the install - just remembered as I type that I need to check this).
Landing towards entrance void.JPG Hall towards plant.JPG Kitchen-Dining.JPG Living.JPG
5 hours ago, Great_scot_selfbuild said:
Missed off @jimseng from here.
How do people learn about calculating the heat output from UFH for a given room size and heat loss? Any recommended books/reference material/youtube accounts/online courses?
I’ve been wondering how the downstairs heating might perform if we had wider spacing in the living room compared to the other areas, and where to put the thermostat as the whole of the GF will be single zone 🤔🧐. Even just as an exercise, I’d like to be able to work through the calculation as an exercise.
Has anyone done this before?
I have not had a chance to work out, how to pair heat requirements of individual areas, into a simple system for my ground floor yet. So i am at the same stage as you, with perhaps a little more time on my side. My ,thick bloke ,understanding  so far suggests that if you can get each individual area to have an emitter that matches the heat requirement as near as damn it. Which would be for the coldest day you have designed for,  means the system works as a whole. I think this is preferable to all the different areas, shouting all at once. Heat...enough heat...heat...etc.
On an underfloor heating system, I have seen where the manifold has been used to balance the system using various flow rates to each loop. Again my, dont know what im talking about suggests that the flow to an area might be dialed up or down a bit. When done well, all the valves on the manifold are taken off.
the way my small brain thinks of it is...and lets go back to Rads... you have four bedrooms. each has a radiator with a TRV. You have the boiler set to come on at 6am till 8am. Bed 1 and 2 get the room up to your desired temp. Bed 3 gets up to temp very quickly, and the TRV closes that rad. Bedroom 4 however has the TRV fully open, and never gets up to temp. That says to me that the design of those 4 rads is a bit rubbish. The rad in bed 4 is too small, the rad in bed 3 is to big. To try and balance this out you would try and use the lockshield valves and trv's. I believe that it would be better to size the bloody rads correctly in the first place..
Sorry, none of this is helping you. I just dont have the heart to delete it, now i have typed it all. The Welsh Wizard, and others will be along shortly to tell me to shut up.
Right, as @Nickfromwales has given me a like.... Now im on a roll.
What we need to know is how much heat our length of pipe buried in the floor can emit, if we put hot water through it at 30 degrees. If we find this out, and lets say it is 100watts at 4 litres per minute, at 30 degrees, over 10 meters of buried pipe. our room/area, needs 500watts. therefore we need,  5x 10 meters of pipe in that area, 50meters to give us the heat output we need. All the areas need to be calculated in same way, in order to give us our loop sizes. ????
I was going to start talking in K/ws, but i always get the kw's mixed up, and @SteamyTea then tells me off.
The thing I’d say is, when you’ve PH levels of fabric, then setting (or attempting to set) different temps for different spaces just doesn’t really work that well in practice. The house seems to achieve one general ambient, and cooler spaces steal heat from warmer ones, ergo none are ever that different.
A few people have commented to that effect, so it’s not a misconception, one of the advantages here is folk being good enough to offer feedback after moving in. Doing this all on paper, even for the great Jeremy Harris, didn’t work out well in practice.
Basic heat loss calcs, to decide the size of the heat source, plus DHW, then UFH spaced uniformly accordingly (avoiding any spaces you simply don’t want to specifically heat such as pantry) and that’s you pretty much done afaic.
Having digital control of the input temp and a good thermostat or WC will allow you quite a lot of accurate control over what that ambient will be. The mix becomes more of a thing when you ttt to balance the heat over upper and lower floors, but some will omit FF heating, and some won’t.
Finding the sweet spot is just about tweaking up or down on the flow temps (for heat source efficiency) and thus altering the room temps to suit. How much more control you actually need after this basic commission is the real question.
MVHR is introduced and you’re off to the scientific calculator to attempt to factor that in.
PHPP is slightly helpful, largely for identifying overheat risk %, but tbh common sense and basic practice will get you most of the way here.
Self builders can focus on this until they get dizzy and self destruct, but the mainstream heating people just rock up and fit a bunch of boxes, almost always a buffer (they need an insurance policy against client interference, or the manufacturer does so mandates it in their installation instructions) and a stat gets slapped on the wall, zoned per floor.
Why we fight this so is a question I am finding myself asking, as, once it’s set up and you’re happy, you just leave it alone to do its thing. Most of my clients are happy with a box on the wall that gives them control to the nearest 0.1-0.2°C (plenty good enough hysteresis for PH) and they can walk away from that as happy as Larry.
The one great thing about these types of dwellings is the way they hold an ambient temp so well (effectively) and you can just set these systems up to ‘just get on with it’, minus human intervention.
One system we did in Leicester had zones, AHU, heat & cool, a room thermostat centrally mounted, and a buffer and ESBE mixing, etc, etc, and had an SCOP of 5.3. It’s a Stiebel Eltron setup and the company who supported dialled in to it to show me live data. So this is a fact.
Performing incredibly well, running extremely efficiently, and has been doing so for a couple of years now.
I'm beginning to accept the two different types of client (all self builders); there are those who want to know / understand / fiddle etc, and those who simply don’t.
It is defo more complicated than just bunging in as much pipe as you can, to each area. Then it all gets even more complicated. The room at the front gets a fair bit of solar gain, and the one at the back gets none, and faces north. But only sometimes... You have One thermostat on the ground floor, and stick it in the wrong area. All the other areas either overheat, or are bloody cold.   As i said, i think it is complicated. However, perhaps my teachers were right, and I am just a bit thick.
UFH design get a a free trial version of loopcad, do your own design. Design by room heat loss and balance system out of the box by loop design.
Keep everything simple. If you only want heating downstairs you need to design heat output to meet whole house heat loss. Some are ok with that, some hate it. If you have a big hall upstairs stick a big radiator or two and run at UFH temps, if room are a little cool you just open the doors and let some heat in. If you like warm bedrooms you may need heat in every room. But everything needs to sized correctly.
Smart homes crap and heat pump is a utter waste of money and effort. Not needed will not help anything. Sorry to be blunt and to the point.
Either run WC or a simple centrally located thermostat to drive heat pump on and off (if you do this you also need to run a hotter flow temp so get slightly worse CoP/running costs).
Pre plumbed cylinder is an utter waste of money - as 90% of the equipment on a pre plumbed cylinder isn't really needed.
@Nickfromwales I'm defo in the want to understand camp. Up to a point. But then just want the bloody thing to run. On its own, with no intervention from me. Oh, i forgot, i want to keep me at 21 degrees (southern softy) provide me with ample hot water, and cost me pence per week to run.
That’s what I do, to get the volume, and nobody’s called me to say one end of the room is hotter / cooler than the other. These just seem to blend into each other, from my direct experience(s).
If doing this on paper then you’ll get number-drunk, just so many variables to try to balance out, but doing it in real life, in real homes, for real clients gives me an eye into the world of ‘did it, it was fine’ and then on to the next one.
Same remit as the last lot of clients, for the latter part.
Some lap up the design and complication, and others just stare straight through me. I’m fine with either option as they’re employing me to gauge their needs and expectations, and meet or exceed them. So far so good I guess.
We all want that - in our dreams, you can 1 or 2 of your choices - never all 3. Unless you move to another country (not inside the UK)
1 minute ago, Big Jimbo said:
@JohnMo You have just dashed my dreams Sir.
Relax, I’ve got you covered ;).
This.
These clients have all 3, so you can go to the ball, Cinders :)
Am i correct in thinking that a snail layout is better than an up and down ? In my head it is, as the heat is more evenly distributed.
Yes and no. If the flow goes to the ‘coldest end’ of the room first so the heat lessens as it comes into the centre of the room then pretty moot in these circumstances tbf.
The time you lose the choice is when the cc of the pipes are less than the minimum bending radius of the pipe, eg at 150mm cc you will seriously struggle to perform a U -turn at the end of every serpentine loop.
If you lay ‘snail’ or inverted loop then you are only performing 2 U-turns per loop, with all others just a 90° turn (if the space is a perfect square or rectangle eg).
At 100mm cc as per this…
…you’d have zero chance of going serpentine.
TBH, unless it’s a job with 200mm cc, I’d just go to snail layout as default. Just a better job imho.
This was at 150mm cc iirc…
…still note just the 2 U-turns at the centre of each loop. Much easier.
Low flow temperature makes little or no difference, what layout you do, as dT for loops is so low. It's currently 2 degs outside and on 300mm centres our flow dT is closed to 2.5 degs. Our pipes are 100mm down, so by the time the heat has migrated to the surface, there is very even surface temperature. I have just up and down pipes, nothing fancy.IMG_20201114_152847.thumb.jpg.3b39131469575142f8442e390eb694f5.jpg
10 hours ago, Great_scot_selfbuild said:
  • Smart home integration - we’ve managed to get a KNX designer on board at a manageable cost and so want to ensure we can integrate the heating into it as the KNX controller could negate the need to duplicate having an ASHP controller separately. KNX is a protocol rather than proprietary system and so is widely compatible, but I’m looking to choose one that is directly compatible rather than via a 3rd party controller; I understand Vaillant and Panasonic are just 2 examples that are compatible.
A couple thoughts on this:
  1. KNX is not a smart home solution, it's a communication protocol. If you want automations and phone or voice control, you need a home server / controller of some sort to run the Smarts, and it can use KNX as one of likely a number of protocols of varying levels of standardisation to control devices. (Dali, DMX, Modbus, 1Wire, and wireless things like Zigbee, Bluetooth, Thread and of course Wifi/IP are all possible)
  2. Once you've selected the smart home controller, and figured out what use cases involve it talking to the ASHP, the integration with the ASHP may be via KNX but I'd be happy to bet that's an uncommon and awkward pairing compared to having the controller talk something more natively supported by the heat pump (most often modbus RTU or eeBus)
  3. As others say, the use-cases for integrating the smart home and heat pump are not that compelling so it's definitely not something I'd prioritise over getting a robust self-contained ASHP install from a reliable installer. Here's a few things I do do in my install, but they're all in the nice-to-have bucket: Load compensation, SW tuneable weather compensation based on a forward looking forecast, TOU optimization, automatic "away" mode, automatic DHW boost when more people are staying in the house, remote monitoring and error reporting with automatic fallback to immersion and resistive heating when the ASHP fails (needed more often than I'd like; see above comment about prioritising a robust installation!), energy & COP monitoring.
  4. The one thing I *do* value is having the controller (Loxone miniserver in my case) coordinate the heating and cooling requirements across the house to avoid systems fighting each other; this can cover shading, passive stack ventilation, active boost & MVHR bypass ventilation, aircon, UFH, etc. But this doesn't need a very deep level of integration with the ASHP, on off control (and a way to switch heating/cooling mode, if supported) is sufficient.
Well spotted (I know a little and am learning a lot fast) - looking at GIRA app control, but not seen what the other hardware and equipment will be.
Good point, it may be very little indeed. I’ve added this to the list of things to discuss with the designer.
completely agree here, just trying to make sure in making one choice I don’t *unknowingly* create a problem or challenge elsewhere (it’s fine if I’m making a conscious choice aware of the implications) - part of the reason for asking this question is to glean any experience and knowledge from others who might do things differently or recommend things that worked out well etc.
I like the sound of all of this, though not all applies in our design. Added to the list to discuss. Thanks @joth
Ok many will disagree with me but here is my take on it. I did my first UFH heating system when many here were in short pants. I'm now a designer. My appoarch is pragmatic and absolutely driven by what is achievable on site, buildablity and cost driven. I honestly despair when I see folk trying to desing pipe layouts room by room! I can go on at length but it is complete bonkers! Thoery is taking over reality.
To start. You are going to install pipes in a screed say and that has to be made as simple as possible. You want someone that is going to do this right, that is experienced and they will need a labourer. Take the experienced person at £300 a day and a good labourer that is going to uncoil the pipes and and not be a bit hung over, (kink them) at say at "£120.00 a day. So the labour is £420 a day. Save a day and that extra can get you more pipes.. for 50 years!
Now to save labour and reduce risk its easier to make all the pipes at the same centres. Design for the nearly worst case.
In real life the concrete guy turns up and may squash a pipe. You won't know.  So you want some more loops as a bit of redundancy. There is a thread about how folk cock stuff up.. take my advice and avoid this scenario. Of course I'm not going to be BH angel of the month but best to be honest and give it to you straight about how things often work out on site for self builders. Yes you may think that you will be up to site checking everything.. but that is often wishfull thinking! Even then ask do you really know what you are checking.. do you have the experience / constructionknowledge to know how to argue if you find something wrong?
At the end of the install you want something that has some contingency built in. But if you consider the labour saving vs the extra length of pipe it is a good balance of risk when you consider that the pipes need to last 50 years.
As an SE that is used to balancing real life cost vs risk, and done UFH long before BH was even invented, I must say that much stuff you see on BH about folk trying to save a few quid is frankly complete pish! But it's not my money!
My advice is to install plenty and easily buildable spare capactity in the floor and once the pipes pop up you can play with your controls to your hearts content. It's a good apporach as boiler and design technology develops.. to have spare capacity in the floor slab.. even if you don't need it right now.
Put in plenty loops as a guard against the builder catching you out or say in the heat of battle you are doing the screed concrete your self.. you can easily miss a trick here. Don't think for a minute that while it looks great on paper.. on site when the concrete is coming you will likely not have the experience to say to the concrete guys,, hang on.. the may bully you and play to your wallet.
So to finish.. I say to many armchair techy folk that are trying to refine UFH pipe layouts.. stop having a laugh and lets look as what happens on site and the labour cost of fannying about with different pipe spacing. Many folk on BH end up moving walls or end up with a diferent kitchen desing layout.
Self building is hard enough without getting over enthused about some hot water pipes in the floor.. keep it simple and that way you'll save on labour and reduce you risk of something going wrong.
That's my view in the round.
Edited by Gus Potter
Thanks @Gus Potter, a useful reminder to follow the ‘KISS’ principle. I’ve been wondering about the strength of these pipes once they’re laid (before screed goes down) - some of the spacing is quite narrow, do we need to make sure that no-one steps on any of the pipe once it’s laid? (I’d have assumed that the practicalities of a building site would make this very unrealistic)
I’m not doing the loop design myself (I’m drawing the line at buying a windows laptop just to use LoopCAD), and although the suppliers don’t share their designs before we commit to using them, we’ve had some say their design has 7 circuits and others say they have designed for 11 circuits. Are you advising that we make sure we ask for more than one circuit per room for the redundancy (just to make sure they factor it into their design)?
Almost always ‘no’ 🤣
Thanks for the reality sense-check
I filled mine with water glycol mix and pressurised - they are not get crushed by anything. My pipes were installed as part of the foundations, so pre walls. Survived a Scottish winter.
All I can add is that I checked the pipes on a Friday, with the screed coming in Monday. There were 2 x severe kinks in one room. Supposedly expert plumber declined to spoil his weekend to sort it.  Fortunately. I managed to straighten them.
Works nicely.
So I don't assume that other people care. Certainly not the £150 guy who poss has no experience.
How many homes still  have the kinks? Presumably it works well enough normally.
So I agree on some redundancy.
A pre-requiste before pouring any concrete is testing loop flow and pressurising the loops. If flow is not right it needs fixing before the pour. Ideally monitor the pressure during the pour. If something goes wrong (unlikely), then reaslising it as the pour happens likely makes it easier to isolate where the problem is. You obviously wouldn't stop a concrete pour but if you get on to the repair straight away before the concrete has full cured the job will be a lot easier.
Having said that, I believe that modern Pex-Al-Pex pipe is significantly more robust than pipes used in previous decades so as long as everything is tested in good condition before the pour then the pour shouldn't be an issue.
Edited by -rick-
In terms of redundancy, what exactly are you referring to? Is it to run extra loops in parallel - for example, if I need 300mm spacings, I add additional loops so that I essentially have 150mm spacings - or is it something else?
I'd like to know more Gus as I'm keen to understand your perspective and reasoning for this. What are the thermal characteristics that are better and how is the system output controlled once it's in?
I'm from the school of calculating heat load requirements in the room and designing emitters to satisfy this at a low temperature as possible and avoiding external controls as much as possible although I recognise and use room influence where needed. This approach does use the method of designing both radiators and ufh to the demand of each space.
I'd like to understand more from your experience.
