Hello,
I am going to make a doorway between my bathroom and bedroom, making it ensuite.
I've been watching a few videos and reading about how to do it. It seems doable even for a DIYER.
This post is looking for any information people can share about making a doorway.
Points I've noted down, standard UK doorways are 826mm wide. Anyone go bigger? Lintel above the doorway is extra 100mm either side of the door. Would anyone go bigger? What thickness would be acceptable?
Above the wall where the doors going, there is only one beam across it. A builder had a look at it and said there no structural issues/its not supporting anything about it.
Any thoughts/information would be much appreciated. Thanks.
1 hour ago, Russell griffiths said:
Minimum bearing for a concrete lintel is 150 each end I believe.
I think thats rule of thumb but can go smaller like maybe 100mm in some circumstances. I'm sure I've seen it written down before. @Gus Potter
1 hour ago, Nickfromwales said:
100mm in concrete is fine.
How thick would you say it needs to be minimum?
The problem I’ve seen in these situations isn’t having sufficient bearing of the concrete lintel onto brickwork below, it’s the condition and location of the lintel onto small pieces of badly secured brickwork.
cutting a hole up through a wall could end up with the lintel sitting on a small cut piece of brick instead of a full brick.
removal of the plaster is needed as is proper placement of the opening or removing any small slithers of brick and replacing with full or half bricks minimum.
On 31/01/2026 at 00:46, Nickfromwales said:
How thick for what? Wall or lintel?
The reference to 100mm is for each end of the concrete (pre-stressed) lintel to be sat over 100mm masonry the same thickness as the lintel.
For this, you’d be using a 3” x 4” lintel
https://www.diy.com/departments/expamet-concrete-lintel-l-1050mm-w-100mm/150790_BQ.prd
Apologises, I didn't mean thickness either side. I mean thickness of the lintel itself.
I've seen one from jewsons with the measurements of 1200 x 140 x 100mm. Would that be standard spec?
https://www.jewson.co.uk/p/supreme-concrete-prestressed-lintel-r15120-1200-x-140-x-100mm-LNBRN155
The DIY one you shared is £18. The Jewson one is £68. Any reason for such a big difference?
Thanks.
Edited by ECP90
I knocked through a block cavity wall, on my bungalow, a couple of years ago and fitted 1500 x 100 x 65mm lintels and they were about £15 each from the local builders merchants.
Edited by Gone West
Thanks.
Yes. The same reason I’ve been in Jewsons twice in as many decades. Also you’re looking at too big a lintel ;)
You don’t need a 6x4” as a 4x3” (100x65) is plenty for a doorway in single skin in most situations.
You mount this in portrait orientation, not landscape, btw.
On 04/02/2026 at 19:30, carlos21 said:
has the op stated what the said wall is constructed from??
or did i just miss it.
Its of brick construction. Built 1900/10. The brick is the old thick bricks
I have removed all the plaster from the bathroom side of the wall as it was all blown. I will be going from bathroom to bedroom side. So i can make my measurements and cut into half a brick and hopefully have it sat nice and neat.
Beware how you create the opening, as if it is the thin / old / frail brickwork then disturbing it can be the beginning of a long journey.
You may very well need to line this with timber stud frame, and then dress the doorway into that, to give strength back locally to the cut brickwork (drilling fixings into each course, and possibly bonding too).
Some pics would help.
I’ve added some pictures. I am going to remove the bath and go from the bathroom side into the bedroom. The still plastered side is the bedroom I’m going into.
