Hello folks! I have gone to fairly extreme lengths to make sure sound doesn't come into my property which included buying Norrsken triple glazed windows / slider / front door.
I have filled literally every gap you could imagine in the property. However my front door is like a massive amplifier. Its actually noiser with it closed than open.
See attached video show the problems and some pictures of the detailing around the door, but I would love some advice. I believe that if I had simply gone for a glazed door as per my windows I wouldn't be hearing this sound. I have gone back to Norrsken support and waiting on a response.
The sound is absolutely coming directly through the leaf of the door the surrounds and roof is silent.
door1.thumb.jpg.7b490d94c16ff980fbf741fbcded552c.jpgdoor8.thumb.jpg.9d7d3d6cb179548e8221a24e5bb2ca15.jpgdoor7.thumb.jpg.31ca4e5d01e9793598dd3aff56266904.jpgdoor6.thumb.jpg.39fe4bcb1d7572b5478d9126fcfb57f0.jpgdoor5.thumb.jpg.28062e7cf8f176e8e72eb03ebe63a829.jpgdoor4.thumb.jpg.4d8b238623fd44e0996fbf359140de38.jpgdoor3.thumb.jpg.34fd91fae534e3b55debd3efe28a84db.jpgdoor2.thumb.jpg.ef13d0a96d02e41b8d035767e809ae9d.jpg
That's a weird one. I have an aluminium door and it definitely doesn't transmit sound like this. It sounds like air coming in/out of a small gap, which may explain why it goes away when the door is open.
Try burning a few matches near the door and see if the smoke gets sucked/blown from anywhere. Do you have MVHR? That could cause negative pressure and a whistling sound from sucking in air through a gap.
MVHR isn't running yet
I've taped fully around the edges with masking tape and also ran a piece of paper all the way around with it shut. It's tight everywhere.
It just sounds like it's coming right through the leaf. Also if you knock on it, it almost sounds hollow
With this gently in front of the door. The majorly of the whistle is gone. Even if the door is open it's miles quieter with this random stack of Rockwool
How about taping a polythene dust sheet around the door, then blowing a fan from the other side?
Does the door feel heavy or light? Can you remove the door handle, or something, to look inside the door?
Can you post an update to let us know what Norrsken propose?  They seem very well regarded here and elsewhere.
Bear in mind the Marmox type board on the reveals won't help block out noise.  I take it that traffic is the issue?
Cor that’s weird!
Have you got a thermal camera you can point at the door to see if it’s a uniform temperature (thus uniformly filled)?
Traffic noise I believe is the issue, but it's a high pitched sound which is basically created by the panel of the door. The sound is obviously coming right through the leaf.
I wouldn't expect the Marmox material to make it worse given its mostly just insulation. I've got it in all the reveals for every window and they are generally fine.
2 hours ago, Russdl said:
Cor that’s weird!
Interestingly enough my friend does have a decent one, he was wondering around last week. But we didn't concentrate on the door
Rockwool is very good at sound attenuation, so no surprise there. You may well find that once the EWI and cladding are completed and everything is properly sealed, the issue will be resolved.
Do you have any updates or further clues on the cause? I'm really curious about whats going on here.
It might not be the Rockwool absorbing sound though. It could be that it's now blocking wind, or if he's lent it against the door, or could be stopping vibration.
New suggestion @boxrick, try taping the grooves in the front of the door. I wonder if they're having a similar effect to when you blow on the rim of a glass and get a whistling sound.
My friend brought round a really decent calibration microphone and we measured different scenarios against a baseline.
In the 1.5khz range there is basically 0 attenuation.
The door is actually rated at 33db in sound reduction. But even the difference between the most drastic sound reduction is well below this.
I'll share some graphs shortly. Also as you knock along the skin of the door, some bits are completely dead and others sound completely hollow.
I'll share some more info when I'm at my laptop.
Edited by boxrick
You can see the frequency here which is almost completely unblocked. This is what is leading to the 'whoosing' sound. The blue is fully open and the red is closed.
You can hear how hollow the door sounds in the centre, this is where most of the sound is coming through:
I have Norrsken doors and windows too.
All I'll say is that they are tremendous at after sales support (in my experience), get in touch with them and I suggest they will fall over themselves to help a polite customer.
Thats me sat with the laptop and microphone in front of Rick's door.
For anyone stumbling across this in the future please only pay attention to the difference in sound level between the peak of the red line, and the blue line, inside the green box Rick has highlighted. You can certainly say that the door as installed allows 1.3kHz from the road noise outside the house to pass through with very little reduction in sound level for whatever reason.
But you can't say much about if the door does or doesn't meet the 33db sound reduction specification at other frequencies. You'd measure that differently.
I do agree with Rick that the sound appears to come through the middle of the whole door leaf rather than at the seals - I heard it myself, the video in the first post shows that very clearly.
It’s very unlikely the slab of the door is hollowed, it’s usually a solid slab of PIR with laminated timber either side. A smoke test will indicate where this is occurring.
I do not suspect the slab but it can’t be ruled out. It’s usually down to adjustment being required as the door isn’t sealing correctly or it’s coming through the perimeter or through the glazing bead area, which is a possibility.
  • 1 month later...
Norrsken admitted they had some website errors and the door is incorrectly showing as 33db instead of the correct 22 or 21db.
They are going to replace the door itself at their cost to the acoustic version but just waiting on info from them.
Will update as I get more info.
  • Like 4
Hearing this would make me very keen to consider them if I were building again, even without the door and window installation nightmare we had with another supplier. A supplier who's willing to take this sort of responsibility is a rare and beautiful thing.
Indeed. A good company to deal with, and from my most recent direct experience, certainly not shy of pouring the requisite oil onto the cogs.
The lads from Elite were great too, and I’ve suggested to my current MBC TF PH client (who’s engaged with Norrsken) to ask to nominate Elite for the installation.
