September 2Sep 2 Author 14 minutes ago, -rick- said: Sort of, though from what limited stuff I'm hearing it's adding more work rather than taking it away. You have to do the work once for the quarterly report and then do the tax return at the end of the year. Yes the software should eliminate a lot of the duplication but not all. Yeah, this can often be the way with "simplification"!😁 I looked into it as I thought I was going to have to do it (turns out I'm in the group that avoids it). It's very dependent on your software. In theory all you have r to do is the normal admin (allocating payments to invoices and bills and tagging various transactions by type) on a reasonably timely schedule and then hit the upload button every now and again. If you're reasonably on it, there shouldn't be much extra work. But for the people who just chuck all their invoices and receipts in the glove box and then have a mad rush about just before the deadline trying to make sense of scraps of paper from 12 months ago - it's gonna be a change (but probably for the better)
September 2Sep 2 Author 18 minutes ago, SteamyTea said: under my system you would pay tax on a refund as it would be treated as income. Obviously genuine mistake would be an exception. I would tax state benefits as well. Then it just becomes an arguement about how large they should be, not a threshold arguement. That seems rather bad, especially if the government is taking the money at source (eg PAYE) and has not adjusted quick enough to changing circumstances.
September 4Sep 4 Author https://www.bbc.co.uk/news/articles/cj9xe09jz4eo https://www.theguardian.com/environment/2026/sep/04/jackdaw-gasfield-set-to-be-approved-by-ministers-this-month-sources-say Looks like the government is going to approve Jackdaw and Rosebank. We shall be back to 1p kWh gas and probably under £1 liter of petrol before Christmas! /S Well that's what you'd think if you listened to the bosses of those projects. "Chris O'Shea, the boss of British Gas owner Centrica, said any additional domestic gas supply would reduce Britain's reliance on imported fossil fuels, "so it's got to be good"..." But then he tries the pull off the impressive feat of making an argument that he fatally undermined earlier in the same sentence .. "He told the BBC's Today programme: "It wouldn't lower the cost materially, but basic economics would tell you that if you've got a fixed demand for a product and you increase the supply, the price should move." So it won't do anything but basic economics says it will? There is much trumpeting that the gas field will produce, at it's peak, 6% of UK gas output - which opponents point out is only 2% of the UKs actual gas use. It would be really interesting to see exactly what the treasury outcome is in all of this. I know there will be some tax collected but that has to be set against the tax write-offs that this project will enable companies to utilise. I have seen various takes that place the final outcome anywhere from a few billion met revenue for the treasury over the lifetime to a few billion net loss. What would also be interesting would be how much an equivalent saving in gas would cost ie how much would we need to spend driving insulation, heat pumps etc to achieve an equivalent drop in UK gas consumption? IIRC turning down your thermostat reduces your gas consumption by about 10%. So Jackdaw is equivalent to 1 in 5 people turning their thermostat down by 1C.
September 5Sep 5 18 hours ago, Beelbeebub said: Looks like the government is going to approve Jackdaw and Rosebank. About time 18 hours ago, Beelbeebub said: There is much trumpeting that the gas field will produce, at it's peak, 6% of UK gas output - which opponents point out is only 2% of the UKs actual gas use. But it a lot of gas not being pumped from elsewhere, so win win. 18 hours ago, Beelbeebub said: turning down your thermostat reduces your gas consumption by about 10%. But you can't keep claiming that as a win, most people already have and then down another notch as gas prices increased. 18 hours ago, Beelbeebub said: What would also be interesting would be how much an equivalent saving in gas would cost ie how much would we need to spend driving insulation, heat pumps etc to achieve an equivalent drop in UK gas consumption? And how long it would take also, all this takes time, no magic wand. 18 hours ago, Beelbeebub said: So Jackdaw is equivalent to 1 in 5 people turning their thermostat down by 1C. Or a load of LNG tankers, from who knows where. But this doesn't fit your narrative.
September 5Sep 5 By extracting more fossil fuels, it just delays the inevitable transfusion to overall cheaper renewables. Be a bit like not bothering to cover a roof as it seems cheaper to just repaint the ceiling every few weeks.
September 5Sep 5 Author 1 hour ago, JohnMo said: But it a lot of gas not being pumped from elsewhere, so win win. [emphasis mine] But it's not a lot of gas - that's the point. 1 hour ago, JohnMo said: But you can't keep claiming that as a win, most people already have and then down another notch as gas prices increased. It was more to illustrate the relative size of the change ie not alot 1 hour ago, JohnMo said: And how long it would take also, all this takes time, no magic wand It would take some time, true. So the argument goes - "well those things would be great but we have a supply problem NOW, so we must do this less ideal thing as it will help NOW" But the magnitude of the output means there will be absolutely no discernable change to prices or energy security. So it won't help now, or ever. But starting to install HPs and insulate will have a small and growing effect that will compound over time. To paraphrase "the best time to have started the energy transition was a decade ago, the second best time is today" But I am interested in the overall net effect on tax revenue. Yes tax revenue will be created from various oil taxes and corporation taxes plus keeping people in work (the net increase in jobs is around 25 although it will assure some 200 or so current jobs). But my understanding (and this is why a proper analysis by non-partisan experts like the HoC library would be good) is that the pio companies can use the costs of this venture to offset revenue elsewhere potentially lowering their tax bills. So the question is whether the increase direct tax revenue are greater than the decreased tax revenue elsewhere. If (and it is a big if) the net effect is negative then not only are we not doing anything to help out current and imminent situation (high energy prices) but we are actively hampering the deployment of solutions that will help. 1 hour ago, JohnMo said: Or a load of LNG tankers, from who knows where. But this doesn't fit your narrative. Again the relative size is important UK consumption is approximately equivalent to 1 LNG tanker a day. The 2% of UK demand that jackdaw might provide is therefore 2% of a LNG tanker. So the worst case 7 LNG tankers a year out of 120 or so. Bear in mind the majority of LNG effectively ends up as export (the volume of UK gas exports being broadly the same as UK LNG imports) - we are in effect one of Europe's main LNG terminals Again, the main point is that jackdaw will do jackshit (sorry) about our prices or energy security. What it will do is make a bunch of cash for oil companies and use that reserve of gas up for the future. Imagine and alternate path.... We don't licence jackdaw - yet. We transition away from gas for heating etc to electricity. Of course our electric generation needs to go up, which we do via renewables. However, as the deniers delight in crowing, we will probably still need gas for the few times it's dark and still and for some balancing and backup. The gas use will be a fraction of current use. Maybe 10% maybe even less over time. At this point the government reactivates jackdaw but as the exclusive supplier for the national gas stockpile to power the thermal power stations in emergencies This will provide genuine price benefits (the gas bit being open market) and genuine security if supply (the gas being exclusively used for UK emergency generation). Of course all of this relies on the gas being there rather than having been already extracted for zero before to anyone but the oil companies.
September 5Sep 5 Author 5 minutes ago, SteamyTea said: By extracting more fossil fuels, it just delays the inevitable transfusion to overall cheaper renewables. Be a bit like not bothering to cover a roof as it seems cheaper to just repaint the ceiling every few weeks. Except we aren't even repainting the ceiling. We're dabbing a bit of tipex on 2% of the ceiling.
September 5Sep 5 Author 1 hour ago, Beelbeebub said: Except we aren't even repainting the ceiling. We're dabbing a bit of tipex on 2% of the ceiling. Just realised my "tipex" comment has massively dated me! 😁
September 5Sep 5 2 hours ago, Beelbeebub said: [emphasis mine] But it's not a lot of gas - that's the point. It was more to illustrate the relative size of the change ie not alot It would take some time, true. So the argument goes - "well those things would be great but we have a supply problem NOW, so we must do this less ideal thing as it will help NOW" But the magnitude of the output means there will be absolutely no discernable change to prices or energy security. So it won't help now, or ever. But starting to install HPs and insulate will have a small and growing effect that will compound over time. To paraphrase "the best time to have started the energy transition was a decade ago, the second best time is today" But I am interested in the overall net effect on tax revenue. Yes tax revenue will be created from various oil taxes and corporation taxes plus keeping people in work (the net increase in jobs is around 25 although it will assure some 200 or so current jobs). But my understanding (and this is why a proper analysis by non-partisan experts like the HoC library would be good) is that the pio companies can use the costs of this venture to offset revenue elsewhere potentially lowering their tax bills. So the question is whether the increase direct tax revenue are greater than the decreased tax revenue elsewhere. If (and it is a big if) the net effect is negative then not only are we not doing anything to help out current and imminent situation (high energy prices) but we are actively hampering the deployment of solutions that will help. Again the relative size is important UK consumption is approximately equivalent to 1 LNG tanker a day. The 2% of UK demand that jackdaw might provide is therefore 2% of a LNG tanker. So the worst case 7 LNG tankers a year out of 120 or so. Bear in mind the majority of LNG effectively ends up as export (the volume of UK gas exports being broadly the same as UK LNG imports) - we are in effect one of Europe's main LNG terminals Again, the main point is that jackdaw will do jackshit (sorry) about our prices or energy security. What it will do is make a bunch of cash for oil companies and use that reserve of gas up for the future. Imagine and alternate path.... We don't licence jackdaw - yet. We transition away from gas for heating etc to electricity. Of course our electric generation needs to go up, which we do via renewables. However, as the deniers delight in crowing, we will probably still need gas for the few times it's dark and still and for some balancing and backup. The gas use will be a fraction of current use. Maybe 10% maybe even less over time. At this point the government reactivates jackdaw but as the exclusive supplier for the national gas stockpile to power the thermal power stations in emergencies This will provide genuine price benefits (the gas bit being open market) and genuine security if supply (the gas being exclusively used for UK emergency generation). Of course all of this relies on the gas being there rather than having been already extracted for zero before to anyone but the oil companies. You keep repeating the same stuff. But until there is is a wholesale move over to electric heating, the country still needs mostly gas. No getting away from it. The spark gap is still too big to drive a self motivated change over to electric heating. Reduce the spark gap should be your argument, then everything else just happens, because market force drives it. Until then home grown gas is way better than anything imported. Living in Scotland Jackdaw represents 35-45% of our whole consumption of gas, but we already produce 5 to 6 times our usage. We also produce way more wind power than we consume - so let Scotland bail out England in all thing kWh related, England just needs to reduce it's consumption to make things good. Look on a regularly and our house mostly gets wind power (when we are not generating solar), we are not connected to gas. We export electricity at times of short supply (we know because Agile export prices are good and Axle Energy want to buy). So assume none of your properties have hydrocarbon powered heating or cooking and are well insulated.
September 5Sep 5 Author 2 hours ago, JohnMo said: But until there is is a wholesale move over to electric heating, the country still needs mostly gas. No getting away from it. The spark gap is still too big to drive a self motivated change over to electric heating. Reduce the spark gap should be your argument, then everything else just happens, because market force drives it. No argument there - bringing down the spark gap is a primary task. If that drops below about 3 then all the payback calculations tip in favor of electrification and we're off to the races. 3 hours ago, JohnMo said: Until then home grown gas is way better than anything imported. This is a bit contentious - first off - what do you mean by better? Cheaper? More secure? Lower CO2 per kwh? For cost and security - Jackdaw will make zero difference to the price or security *because the volumes are so small*. It would be like arguing that sticking an 80w* solar panel on your house will make a meaningful difference to your energy costs or your ability to keep the lights on. As for CO2 (which is the argument the oil industry is suddenly extremely keen in) - yes, the Co2 per kwh of LNG is higher than NS gas. How much cleaner? about 15% (https://www.carbonbrief.org/factcheck-north-sea-gas-is-not-four-times-cleaner-than-lng-imports). So Jackdaw will save (or generate) 15% of 2% of the UK's gas emissions - about 0.3% of total CO2 emissions. This is also an argument as to why opening Jackdaw isn't a directly catastrophic for the climate . 3 hours ago, JohnMo said: Living in Scotland Jackdaw represents 35-45% of our whole consumption of gas, but we already produce 5 to 6 times our usage. We also produce way more wind power than we consume - so let Scotland bail out England in all thing kWh related, England just needs to reduce it's consumption to make things good. Look on a regularly and our house mostly gets wind power (when we are not generating solar), we are not connected to gas. We export electricity at times of short supply (we know because Agile export prices are good and Axle Energy want to buy). I mean, great, but it doesn't work like that. You don't get to draw ever smaller boundaries around things to claim you don't have to do anything. If you want to play it that way then Scotland is also responsible for around 1/3 of UK CO2 emissions** 3 hours ago, JohnMo said: So assume none of your properties have hydrocarbon powered heating or cooking and are well insulated. I can see this for the daft argument it is but - good god, no. They are mostly gas and mostly less than EPC C - though to be fair mostly over 150 years old But you have just popped up out of the well: I assume you aren't arguing that nobody on mains water can have any say in the UK water industry? * Average house of 10kwh/day so 2% of demand would be 200wh per day which is would roughly be the average output from an 80w solar panel ** calculated from combustion of the O&G extracted, mostly from Scotland, are around 18bn tons and historic coal emissions are around 36bn tons (assume most of the coal was not Scottish) - very crude estimate
September 5Sep 5 26 minutes ago, Beelbeebub said: If that drops below about 3 then all the payback calculations tip in favor of electrification and we're off to the races If you have a battery and smart tariff you don't even need a spark gap of 2, and that's without taking into account the boilers efficiency of around 85% and gas standing charge. Our current tariff (runs out in October) we only pay 10p for electricity per kWh, taking into account standing charge and boiler efficiency we only need a CoP of just over 1 to break even. But the press don't talk about that. 26 minutes ago, Beelbeebub said: This is a bit contentious - first off - what do you mean by better? Cheaper? More secure? Lower CO2 per kwh? We generate direct jobs and secondary support jobs. Less transport, the gas comes onshore and is directed to our onshore distribution network. 26 minutes ago, Beelbeebub said: kwh Get your units of measure correct I someone may take your argument seriously kWh doesn't take any more typing the kwh. 26 minutes ago, Beelbeebub said: They are mostly gas Says it all! 6 hours ago, Beelbeebub said: as the deniers delight in crowing, we will probably still need gas for the few times And to heat your properties. 7 hours ago, Beelbeebub said: The gas use will be a fraction of current use. Maybe 10% maybe even less over time. So Jackdaw provides a good proportion of gas to keep the lights on and mains power on.
September 5Sep 5 Author 3 hours ago, JohnMo said: 4 hours ago, Beelbeebub said: If that drops below about 3 then all the payback calculations tip in favor of electrification and we're off to the races If you have a battery and smart tariff you don't even need a spark gap of 2, and that's without taking into account the boilers efficiency of around 85% and gas standing charge. Our current tariff (runs out in October) we only pay 10p for electricity per kWh, taking into account standing charge and boiler efficiency we only need a CoP of just over 1 to break even. But the press don't talk about that. 100%
September 5Sep 5 Author 3 hours ago, JohnMo said: We generate direct jobs and secondary support jobs. Less transport, the gas comes onshore and is directed to our onshore distribution network. The direct jobs are not substantial - 27 according the the owners. A further 250 or so will be more secure at the hub. Again the issue with jackdaw is that it doesn't do much either way. It's a sideshow. Whilst I think it would be better if we didn't licence it and spent our efforts elsewhere (transitioning) I'm not that bothered of we do - part of me thinks it might be a good idea because it will shut up all the idiots who think it'll sort all out problems and the UK will become the Saudi Arabia of Europe. 3 hours ago, JohnMo said: Get your units of measure correct I someone may take your argument seriously kWh doesn't take any more typing the kwh. It does if you mostly type on a screen. What unit do you think I am describing when I say "an average home uses 10 kwh a day"? Unless it genuinely causing you to think of another unit it's just pedantry. 4 hours ago, JohnMo said: 4 hours ago, Beelbeebub said: They are mostly gas Says it all! It says that,like the majority of the country, my houses use gas. I'm trying to electrify but am being stymied by regulations, cost and the biggest issue is I don't want to spend money to make it more expensive for my tenants. Ideally an air to air alongside the current gas system would be the safest but I won't get a grant, I need planning for the outdoor units and in the case of all electric flats I get fewer points than swapping to modern storage heaters. All of the above doesn't invalidate my arguments any more than you being on mians water prevents you from complaint about water companies 3 hours ago, JohnMo said: So Jackdaw provides a good proportion of gas to keep the lights on and mains power on. Only if you define 2% (at best) as a "good proportion". If you got a 2% bonus would you describe that as "a good proportion of my salary"? If you lose 2% of your body weight would that be "a good proportion of my bodyweight"? This is the point I keep trying to drive home. Jackdaw (and Rosebank) will make no discernable difference to: - energy prices - energy security - job figures - CO2 emissions* - tax revenues** It does send the wrong message though. It will make i harder for the UK to pressure other countries to live up to their commitments. *This is a point that can be used to justify licencing despite the climate situation. ** I would like to see what the net tax revenue situation actually is. Hopefully it is positive but I have a suspicion that once tax deductions are included the net position will be much smaller than trumpeted and possibly even negative
September 5Sep 5 27 minutes ago, Beelbeebub said: If you got a 2% bonus would you describe that as "a good proportion of my salary"? Yes as I never gets bonuses - getting 2% would be good, better than zero. My last bonus was in 2001. But I do work as a contractor. 29 minutes ago, Beelbeebub said: does send the wrong message though. It will make i harder for the UK to pressure other countries to live up to their commitments. Sorry - who are we to be telling any other country what to do. Besides everyone knows we are just green washing, by importing everything that look CO2, oil, gas, bricks, most out goods come from other countries - but makes our CO2 numbers look fantastic, but it's not real.
September 5Sep 5 39 minutes ago, JohnMo said: Besides everyone knows we are just green washing, by importing everything that look CO2, oil, gas, bricks, most out goods come from other countries Other countries are decarbonising as well. Not studies this in detail, and we are certainly not the best, or worse. https://ourworldindata.org/consumption-based-co2
September 5Sep 5 Author 37 minutes ago, JohnMo said: Sorry - who are we to be telling any other country what to do. Besides everyone knows we are just green washing, by importing everything that look CO2, oil, gas, bricks, most out goods come from other countries - but makes our CO2 numbers look fantastic, but it's not real. If we are going to tackle a global issue we need to work with other countries. It's really hard to encourage other countries to cut emissions or not start more fossil fuel exploration when we are granting drilling licences - it's not a good look. And as for the argument "we are just green washing, by importing everything that look CO2, oil, gas, bricks, most out goods come from other countries..." It s true that the 50% fall in our "Territorial" emissions measure excludes goods and services from abroad, But our "footprint" emissions which includes that, plus aviation and shipping and pretty much everything else has also fallen albeit not by as much- but still over 20% down from the peak (just under 1bn to just over 750bn). Given you describe 2% as a "good proportion" what would you describe +20% as? "Very good proportion", "Bloody good proportion"?
September 5Sep 5 Author As a side note the "it's green washing - all we've done is shoo emissions abroad and decimated our industry" is straight up FUD from the fossil fuel industry. It sits alongside "the UK is only 1% so nothing we do makes a difference" It is in the fossil fuel industry's interes to make us think we cannot achieve anything so it's not even worth trying. It's stage 3 of the 4 stages
September 5Sep 5 10 minutes ago, Beelbeebub said: If we are going to tackle a global issue we need to work with other countries. It's really hard to encourage other countries to cut emissions or not start more fossil fuel exploration when we are granting drilling licences - it's not a good look. And as for the argument "we are just green washing, by importing everything that look CO2, oil, gas, bricks, most out goods come from other countries..." It s true that the 50% fall in our "Territorial" emissions measure excludes goods and services from abroad, But our "footprint" emissions which includes that, plus aviation and shipping and pretty much everything else has also fallen albeit not by as much- but still over 20% down from the peak (just under 1bn to just over 750bn). Given you describe 2% as a "good proportion" what would you describe +20% as? "Very good proportion", "Bloody good proportion"? But the point is importing stuff from elsewhere when we have it available is plain daft. No-one (or at least me) is saying don't go net zero or better, but don't pretend - by importing all the nasty stuff from elsewhere. Get your heat pump(s) installed - lead by example (as you quote) do it without grants, many on here have, including me. It's generally cheaper that the grant chaser will charge you anyway. I love doing the green thing, it generally saves me money it cuts my monthly bills. So I can preach as I have been there and done it, with my own money - once you move away from gas yourself come back and preach. Until then you may need Jackdaw and other gas producers, if we have a hard winter and gas is in short supply (now Putin's gas isn't available) that 2% may make all the difference.
September 6Sep 6 Author 11 hours ago, JohnMo said: But the point is importing stuff from elsewhere when we have it available is plain daft. The economic theory of comparitive advantage says otherwise. 11 hours ago, JohnMo said: Get your heat pump(s) installed - lead by example (as you quote) do it without grants, many on here have, including me. It's generally cheaper that the grant chaser will charge you anyway. I love doing the green thing, it generally saves me money it cuts my monthly bills. So I can preach as I have been there and done it, with my own money - once you move away from gas yourself come back and preach. Easy for you to say, but when it will cost upwards of £300k, be extremely hard to physically achieve and you will see zero financial payback it's a harder question. 11 hours ago, JohnMo said: Until then you may need Jackdaw and other gas producers, if we have a hard winter and gas is in short supply (now Putin's gas isn't available) that 2% may make all the difference. Again, 2% will make zero difference to the price or energy security. As I have repeated, it makes no difference to our prices or energy security if we do or don't licence Rosebank/Jackdaw. There is a narrative pushed by some parties that going all in on the North sea will solve all of the UKs energy issues and obviate the need for "stupid net zero". People need to understand our problems (and need to transition away from oil and gas) will not disappear or even slacken one iota if we licence them. In one sense it is good of they are licences because it will end the discussion, except I worry the next stage - when the promised rewards don't appear - will be to argue "ah, that's because we didn't do a proper job! We need to go even further!". We have seen this tactic for the exact same parties in other areas.
September 6Sep 6 12 hours ago, JohnMo said: Sorry - who are we to be telling any other country what to do. Besides everyone knows we are just green washing, by importing everything that look CO2, oil, gas, bricks, most out goods come from other countries - but makes our CO2 numbers look fantastic, but it's not real. Agree with this. We have already cut our emissions substantially from prior levels, but any serious analysis just shows we've exported the emissions (and to some degree damaged our future economy by doing so). In international forums now we are among examples of 'how not to decarbonise', whether we extract 2% more of our needs domestically or not won't make any difference to that.
September 6Sep 6 19 minutes ago, Beelbeebub said: Easy for you to say, but when it will cost upwards of £300k, be extremely hard to physically achieve and you will see zero financial payback it's a harder question. I await your explanation of how it will cost upwards of £300K to install your heat pump........
September 6Sep 6 19 minutes ago, -rick- said: We have already cut our emissions substantially from prior levels Isn't that because we have stopped burning coal to generate electricity? 20 minutes ago, -rick- said: and to some degree damaged our future economy by doing so But our economy has changed to a service one. I don't think there was a debate about climate change, or energy pricing, when BL went under. The UK has always imported goods in relatively recent history, why we had such a large Navy and administratively controlled a third of the Earth's land. 30 minutes ago, Beelbeebub said: The economic theory of comparitive advantage says otherwise Yes. A theory that, if it was a science, would be called a Law. Not many electricians, brick layers, accountants or consultants build their own rockets and launch satellite to get broadband in rural areas. Similarly SpaceX does not farm potatoes, even though they control a lot of land.
September 6Sep 6 Just now, SteamyTea said: Isn't that because we have stopped burning coal to generate electricity? Partly, but also our demand for electricity has gone down a lot because we now buy products made abroad (mainly using electricity from coal) vs making here. Just now, SteamyTea said: But our economy has changed to a service one. I don't think there was a debate about climate change, or energy pricing, when BL went under. BL? British Leyland? Obviously, our past economy had lots of problems and we didn't decide to move from production to importation for climate reasons. But my point was we are not a good example of decarbonisation. A good example of decarbonisation would be an economy that has shifted away from carbon emissions without changing the domestic industry mix.
September 6Sep 6 1 hour ago, Beelbeebub said: The economic theory of comparitive advantage says otherwise. So you really don't give a chuff about what is correct climate wise, so what are you trying to achieve? 1 hour ago, Beelbeebub said: Easy for you to say, but when it will cost upwards of £300k, If that's the cost you must have a lot of properties - sell one - job done, if it's costing £300k you must have between 50 and 100. You make your choices and then live by the consequences. I only have one property now, my heat pump cost under £3k to install. If your properties are all electric, let all your tenants to choose there own tariff and add a battery. That may make more financial and environmentally sound solution. Get your own house in order, before preaching to those that have. Edited September 6Sep 6 by JohnMo
September 6Sep 6 54 minutes ago, -rick- said: good example of decarbonisation would be an economy that has shifted away from carbon emissions without changing the domestic industry mix. Like China is working towards, very rapidly. And India, sub Saharan Africa as well. I get the feeling that people that think 'Net Zero' is expensive rubbish think that we should have done it already, not done anything, blame others, not blame others, we are a good example, not a good example, it will make a difference, won't make a difference. I suggest that you all get together and come up with a coherent plan as why we should drop the policies and just carry on as normal, rather than divert the climate change debate to one about personal finances.
